DIY patch cables - is heat shrink tubing necessary?
Discussion in 'Pedals' started by Kilometers Davis, Jul 4, 2017.
  1. Kilometers Davis
    Kilometers Davis Junior Member
    7
    12
    Jul 3, 2017
    I'm putting together a new board and DIYing patch cables so everything is nice and tidy! I haven't made my own cables before but it seems pretty simple.
    Title says it all really, is heat shrink tubing necessary?
    Kris Ford likes this.
  2. Who
    Who PM me if you need me. I'll get the e-mail Premium Member
    13,817
    22,582
    Mar 15, 2012
    nope.
    Welcome to the forum!
    Will your cables deal with a lot of movement, flexing/rearranging?
  3. northernguitarguy
    northernguitarguy SWeAT hOg
    25,812
    40,687
    Feb 22, 2009
    I make my own when I need a custom size. I buy cheap right angle plugs by the dozen off ebay and use old cables, works like a charm.
    pillbug and Kris Ford like this.
  4. Kilometers Davis
    7
    12
    Jul 3, 2017
    Thanks:cheers2:
    No there won't be much rearranging if at all, I've gotten to a point with pedals that I know what I like and in what order I like them in.
    Kris Ford, northernguitarguy and Who like this.
  5. pillbug
    pillbug Senior Member
    840
    562
    May 29, 2013
    It's not necessary but I prefer using heat shrink or at least some kind of shroud over the soldered connections before screwing the plug together, just to keep a physical separation between the shield (ground) and the connections.
  6. Kris Ford
    Kris Ford Senior Member
    4,637
    3,792
    Dec 17, 2011
    Electrical tape has worked for me..downside is the gooey reside..the shrink has to be sacrificed if if repair is ever needed (which if done right won't be for a loooooong time, unless a traumatic event happens to it.)
    It does look crisp and professional though!
  7. rjshare
    rjshare Senior Member
    4,932
    5,030
    Feb 13, 2011
    No definitely not necessary and to be honest, with the neutrik and hi-con jacks that I use, I don't think you could use it because of the way they go together.
