Different stud tailpieces in Les Paul
Discussion in 'The Custom Shop' started by luis, Mar 11, 2017.
  1. luis
    luis Senior Member
    436
    98
    Jan 13, 2008
    Does anyone put different tailpìecemetal made studs?
    I own a Les Paul with a very ligth sounding low E string. The guitar has steel tailpiece studs by Pigtail (long) and bushings and I am wondering if brass one would give a stonger bottom on low E,.....
    Thnaks for sharing your knowdldge
  2. kevinkjs
    kevinkjs Senior Member
    112
    34
    Dec 16, 2014
    I just can't see that making much of a difference. First I would check
    your pick up heights and also that you have good solid string contact
    on your nut and bridge saddles. I like to make sure at least half of the
    string is seated down in the slot on my wound strings. Good luck and
    report what you end up doing. Cheers
