Did you change pickups?
Discussion in 'Historics & Reissues' started by Sitedrifter, Jul 9, 2018.
  1. Sitedrifter
    Sitedrifter Senior Member
    1,336
    1,598
    Jan 17, 2014
    With the amount of tone chasing people do and the fact that there ARE better sounding pickups on the market then what can come stock in a guitar, I always wondered if anyone has changed their pickups in a Historic Reissue LP? Were you happy with the result?
    bulletproof likes this.
  2. DrSte31n
    DrSte31n Senior Member
    333
    349
    Oct 4, 2016
    Many have changed pickups. Some are happy with the results, some are unhappy with the result. Many (like myself) have NOT changed the stock pickups, and are happy with the results. You get the idea. Same with the other electronics. Some change the entire harness, some change just the capacitors, just the pots, etc., etc. Some are happy, some unhappy. Just search the forum (including the classifieds) to learn about particular experiences.
    And don't get me started on how much plastics affect tone ;).
  3. hackenfort
    hackenfort Senior Member
    1,101
    349
    Apr 22, 2008
    I used to change they out all the time before Custombuckers.
    Some favorites of my are: Antiquities, Seth Lovers, OX4, Rewind, Wizz and there are many others great one too.
    LeonC and bulletproof like this.
  4. flamesarewicked
    flamesarewicked Senior Member
    882
    1,095
    Feb 12, 2013
    I’ve toyed with the idea of swapping mine to Wizz. I may put some Wizz in my SG instead because it could use an upgrade more so....
  5. rockinlespaul
    rockinlespaul Oxblood Addict V.I.P. Member
    10,590
    10,982
    Aug 12, 2007
    I usually end up changing mine. About 90% of the time. Swapped pups in my current #1 for Throbaks and ended up putting the stock pickups back in. Go figure.
    Frogfur, Dilver and bulletproof like this.
  6. SoCal Flood
    SoCal Flood Silver Supporter
    380
    667
    Aug 3, 2017
    Wizz in my R9 and they’re never coming out :)
    bulletproof and mfolet like this.
  7. GitFiddle
    GitFiddle Senior Member
    11,045
    13,859
    Jun 2, 2010
    I've had a 99 R7 since about 2010. Stock pickups were great. First thing I did was replace the harness with a Jonesy 50s harness. The pickups went from great to fantastic since I started using the volume and tone more effectively. After some time (gigging with it about every weekend) the bridge pickup went microphonic. I just removed the cover and solved the issue. Not long after the neck pickup did the same thing. Around that time I bought a set of Pearly Gates from a member here. I ended up swapping the stock pickups for the Pearlys. Gigged with those for about six months and they never really lived up to what I was expecting.
    I ended up swapping the Pearly Gates back out for the stock pickups. With some advice and help from a few MLP members I replaced the covers using a small bead of silicon caulk between the dummy slug and the cover. This worked like a charm. The stock pickups are back in and sound as fantastic as ever. The guitar is simply a beast for live gigging.
    rogue3, bulletproof, mrfett and 3 others like this.
  8. asapmaz
    asapmaz Senior Member
    1,368
    1,472
    Oct 13, 2011
    Ever since installing OTPG's into my no. 1, my hunt has been over.
    But I am a firm believer in 1) not fixing something if it ain't broken and 2) matching the right pup to the right guitar.
    alnico59 and bulletproof like this.
  9. blackie2
    blackie2 Senior Member
    991
    968
    Aug 12, 2011
    I didn't like the Custombuckers in my guitar and replaced them with OX4's. Very good choice for my R8 but you never know until you swap a set.
  10. goldenugly57
    goldenugly57 Member
    87
    86
    Dec 20, 2008
    Before the Custombuckers were introduced I put Amber Classic Standard Pickups in all my Lesters. After I got my 2014 r9 with Custombuckers, I sold all my Amber Pickups and tried to get hold of any Custombuckers offered second hand to put them in my Lesters :laugh2: Very happy now :)
  11. jwehrman
    jwehrman Senior Member
    229
    284
    Oct 22, 2016
    Duuuuuuuuumb newbie question, but how can you tell what new pickups will sound like if you can't try them out first, or can you...? Please don't throw more than three rocks at me : )
    bulletproof, GitFiddle and Subterfuge like this.
  12. Brewdude
    Brewdude Senior Member
    1,045
    1,771
    Jun 26, 2014
    :slap:
    Bad newbie, how dare you ask questions on a guitar forum
    Thats the hard part for sure, youtube videos are a good start to get general impressions of pickups but there are a ton of variables going on that take it with a grain of salt. If you can, talk with the winder and describe the tone you are hearing in your head and maybe some examples of guitarists or songs that have that sound. They may have an off the shelf option for you or be able to wind something for you.
    Past that, and its expensive, but the best way is to just try out a handful and see what winder's style you best agree with and beyond that what set matches your guitar the best. Keep an eye on the classifieds as used sets pop up pretty often.
    Some will say its madness with an electric guitar, but I've done a lot of pickup swapping between guitars and each one definitely does have its unique underlying sound and will work better or worse with a set of pickups. Part of the reason Gibson pickups are the way they are, is so that they work in a wide range of guitars. With the nice PAF clones things get a little more difficult and it can be a bit more work to find the right set for a guitar.
    I've had first hand experience with Electric City and ReWind and they both wind amazing pickups, James at ReWind (@cooljuk here on MLP) is amazing at describing tonal qualities and talking to you about sounds so I would highly recommend him if you are in the market.
    Lastly, on my one and only historic I went vintage:dude:
  13. Bobby Mahogany
    Bobby Mahogany Senior Member
    21,520
    31,883
    Feb 25, 2012
    Start by narrowing down your "style" to a "style" that has already been defined.
    :D
    Listen to samples on Seymour Duncan's site.
    Listen to samples on other sites.
    Talk to other musicians.
    Stay awake at night in your bed and wonder what would be best for you.
    Consult the "Internet". It's a vast area full of knowledge and bullshit too.
    Stay awake at night consulting that "Internet".
    If you are a Classic Rock and Blues type of guy,
    buy a Seymour Duncan's 59 set (or a Whole Lotta Humbucker" and be happy.
    My '92 Standard (SD '59s) sounds like "The Shit".
    My '93 SG (SD '59s) sounds like "The Shit".
    And they smell good too!
    Best of luck on your quest!
    :D
  14. jwehrman
    229
    284
    Oct 22, 2016
    Okay, next dumb question: Why change the pots? I swear to Pearly Gates and Page Tone I'm not trolling...
  15. DrSte31n
    333
    349
    Oct 4, 2016
    Usually a lack of clarity and treble will warrant a pot change. Sometimes people are also looking for better volume sweeping (e.g. no trebble bleed, etc.). I believe recent Historics have decent/good pots, though (e.g. 500k), so it's a less common mod nowadays. I have never tinkered with mines, though, but I'm sure someone with actual experience will chime in.
  16. Bobby Mahogany
    21,520
    31,883
    Feb 25, 2012
    bulletproof and jwehrman like this.
  17. JeffH66
    JeffH66 Pelham Blue Addict
    963
    1,536
    Oct 31, 2010
    I haven't owned a guitar yet, historic Les Paul, USA Les Paul or other that I haven't changed the pickups on. I'm a pickup change junky, though it's been mostly with Seymour Duncan pickups in the past. My next set of pickups will be from James at Rewind without a doubt.... as soon as I'm working again.
    I'm always happier with my choice of pickups vs the manufacturer's choice, even if their choice was Seymour Duncan. Most stock pickups are too hot and muddy for my taste; or at least too hot..... but that's just me.
  18. jenton70
    jenton70 Premium Member
    2,907
    3,592
    Feb 3, 2009
    I've changed so many times I have to stuff toothpicks down the mounting holes.
  19. flamesarewicked
    882
    1,095
    Feb 12, 2013
    I’ve considered the custom shop version of the PG pickups. I’ve had the normal off the shelf ones... I’ve read where people who have had the custom shop ones say that they’re better.. anyone experience this ?
  20. 1all's Pub
    1all's Pub Senior Member
    3,413
    3,487
    May 26, 2015
    Yes, I almost always change pickups... even on my RIs. The CBs are good, but IMO/IME can definitely be improved upon.
    YMMV, WAFH! :D
    That said, I have a new (to me) R8 enroute. I’ll give the CBs in it a fair shot, but if past experience is any judge, I’ll probably end up swapping them out. :)
    bulletproof and modavis99 like this.
