DI for recording passive bass
Discussion in 'Recording Studio' started by Pwrmac7600, Jan 22, 2018.
  1. Pwrmac7600
    Pwrmac7600 Premium Member
    8,012
    6,257
    Jun 17, 2014
    Countryman Type 85 or Radial J48?
    I currently own a sansamp bass driver for years, but just not happy with it. I have tried just going directly into my interface, but get meh results.
  2. yeti
    yeti Senior Member
    3,475
    3,373
    Aug 19, 2008
    Find yourself a used GrooveTubes "Brick", they can be had for around $250.00 on the used market, best Bass DI that I've ever used and I've used a few. And it's a mic pre as well, 55dB of gain and tons of color, what's not to like?
    Pwrmac7600 likes this.
  3. Freddy G
    Freddy G V.I.P. Member
    11,291
    23,520
    Mar 18, 2007
    Also the Avalon U5 is excellent for bass DI.
  4. yeti
    yeti Senior Member
    3,475
    3,373
    Aug 19, 2008
    I have used the countryman and it's ok. 10MOhm input impedance vs the 220KOhm on the radial might be the deciding factor since it'll determine how the volume and tone controls of your passive bass interact with the DI box. I've heard good things about the Avalon as well, never tried one though. The thing about the Brick is that it seems to give the DI signal an "amped" feel. I used to always mic the bass cab in addition to the Countryman DI but with the Brick I don't need it. A P-Bass into the Brick, no EQ , just medium compression and it just works. However, I'm not crazy about it for electric guitar , makes it kinda mushy and slow.
  5. mmd
    mmd Senior Member
    2,454
    2,390
    Sep 24, 2012
    I have used the Avalon U5 for years. Still my DI of choice, even though I often use modeling for my bass sounds.
  6. Pwrmac7600
    8,012
    6,257
    Jun 17, 2014
    Not gonna lie, the U5 looks very nice, but more than I was looking to spend at the moment. Leaning towards the radial t the moment, was going to go used, but thinking maybe going new from somewhere that carries both the Countryman and the radial so I can AB and return the one I don't go with.
  7. kfowler8
    kfowler8 Senior Member
    4,933
    4,670
    Mar 1, 2011
    I have you looked at using the Axe? I've seen a couple of videos with really good results. Especially running two amp lines and having one dirty and one clean. He basically chopped off all the low end of the dirty and all the high end on the clean and then combined them. So you had this really tight punchy low end but higher end that cut through the mix.
  8. Pwrmac7600
    8,012
    6,257
    Jun 17, 2014
    Yeah I have played some with it a little, but haven't really gotten any results that I was crazy about. Admittedly I didn't dedicate much time to dialing anything in. Kinda just looking for something quick and easy since bad isn't really my primary instrument but still necessary to fill out a mix.
  9. Nicky
    Nicky On The Road Less Traveled
    16,926
    24,985
    Aug 28, 2007
    The U5 can't be surpassed as a bass DI; the tone presets are quite useful. I've actually been using the U5 for several years on stage as a DI for my NORD Stage2 into the house mixer. Mic or Line out to mixer, thru connector to my personal monitor (so I can hear myself above the out-of-control guitarists :jam:).
