Delay pedals
Discussion in 'Tonefreaks' started by bsm9981, Jan 16, 2018.
  1. bsm9981
    bsm9981 Senior Member
    688
    292
    May 20, 2011
    Hey guys. I need some advice. I recently acquired a blues Jr and the clean is great but the drive is not so great. So I'm relying on a pedal for my gain. It's a wampler plextortion, I need recommendations on a delay that'll sound decent running in front of the amp since it has no loop. I saw Pete thorn do a video on this using an exhoplex. I'd like to stay under $100 used if possible. Thanks in advance. Also, does anyone here run a green back in their blues Jr, it's my favorite speaker, I was wondering how it might sound. Mine blues Jr is the Tweed one with the Jensen in it.
    Side Burns likes this.
  2. Angus Blackmore
    Angus Blackmore Member
    90
    45
    Aug 15, 2011
    Marshall pedals are often sniffed at, but my Echohead is versatile, compact, very solidly built, has a great delay range, and can be had v cheap on the used market. They’re also good value new. I use mine pretty hard and it hasn’t given me issues in many years. I use it on the Analogue and Tape settings and it’s very unobtrusive. Switch it to HiFi and you’re in The Edge’s neck of the woods. YMMV.
    lakeburst and dsmcl77 like this.
  3. penguinchit
    penguinchit Senior Member
    1,261
    1,070
    Jul 20, 2015
    I run a DD-20 into my tweed BJR. They can be found for a little over $100. And I love it...It's simple to use, clear (especially through that amp) and the two make a great pair. I have the stock Jensen, but did have the amp modded by ToneTron Amps. I asked Jeff to take some bite out of the top end, bump the low end, add a bias adjustment and put in a Switchcraft input jack. All for $110!
    lakeburst and bsm9981 like this.
  4. Mockbel
    Mockbel Senior Member
    1,930
    1,383
    Nov 2, 2015
    If you are not desperate for a real analog pedal, I would strongly recommend the flashback from tc electronic
    Very versatile and has the toneprint feature.. sold new at around $150 so I believe it can go below $100 used
  5. northernguitarguy
    northernguitarguy SWeAT hOg
    26,100
    41,266
    Feb 22, 2009
    BOSS DD-7 does far more than I need. Great modulation setting.
  6. bsm9981
    688
    292
    May 20, 2011
    Thanks guys. I'm not much of a pedal user. I would just assume plug straight in and go, but this amp needs an OD pedal, and I gotta have a delay for the kind of music I'm doing.
  7. Duane_the_tub
    Duane_the_tub Senior Member
    1,217
    1,520
    May 31, 2015
    I am also a pedal minimalist, and I've been really happy with my Boss RV-3. Versatile, gives you delay and reverb (and both together) in one standard-sized pedal, has a lot of very cool sounds in it and can be found for reasonable prices on the used market, with a little patience.
  8. elephantrider
    elephantrider Senior Member
    2,370
    1,822
    Oct 23, 2015
    this little guy....
    bsm9981 likes this.
  9. Matt_Krush
    Matt_Krush Senior Member
    904
    548
    Nov 5, 2014
    Electro Harmonix Memory Toy.
    Simple.
    Analog.
    sounds excellent.
    lakeburst and tolm like this.
  10. Travis19
    Travis19 Senior Member
    436
    496
    Apr 26, 2013
    you can probably find a Maxon AD-80 for around 100 bucks, that would be my choice.
  11. scooter500
    scooter500 Senior Member
    311
    99
    Mar 30, 2014
    I've been thinking about the ehx Canyon. Has some awesome settings.
    Duane_the_tub likes this.
  12. dissaffected
    dissaffected Senior Member
    429
    322
    Feb 1, 2015
    Mockbel speaks truth. Toneprint software on the Flashback mini($99 new) and full size are worth the price of admission. Use the software or presets to shape the tone. There are many good delays but none with this option.
    BlueCajun and Mockbel like this.
  13. j5jarod777
    j5jarod777 Senior Member
    361
    166
    Oct 8, 2009
    Flashback Mini
    You will never need another delay
    dissaffected likes this.
  14. Greg's Guitars
    Greg's Guitars Senior Member
    5,313
    2,741
    Feb 11, 2009
    Under 100.....possibly a BOSS, pretty hard to beat older BOSS pedal.
    dissaffected and bsm9981 like this.
  15. Mockbel
    1,930
    1,383
    Nov 2, 2015
    +1 for the mini
    I didn't know that it has toneprint too...
    To be honest I don't use most of additional options in the full size Flashback as they are more towards stereo application of the pedal which is not the case with me.
  16. bsm9981
    688
    292
    May 20, 2011
    Does the flashback play well in front of an amp since I have no effects loop, does it play well with OD pedals?
  17. Jymbopalyse
    Jymbopalyse Senior Member
    1,204
    1,493
    Oct 3, 2016
    Just make sure to put it after the OD in your chain.
    At least to start with.
  18. northernguitarguy
    26,100
    41,266
    Feb 22, 2009
    I play my Boss in front of a clean amp. It could likely sound like ass if you are playing into a dirty amp. Like Jymbo said, dirt needs to be in front of delay.
  19. dissaffected
    429
    322
    Feb 1, 2015
    Flashback mini works on all my amps plugged into front of amp. Like all have said. Put it after OD. I put it after OD/Distortion but before clean boost. YMMV
    northernguitarguy likes this.
  20. Mockbel
    1,930
    1,383
    Nov 2, 2015
    I use it in the loop but from other replies seems like it should work fine
