Darken Fretboard
Discussion in 'Historics & Reissues' started by clutchcargo, Sep 24, 2017.
  1. irocdave12
    irocdave12 Senior Member
    2,372
    2,883
    Jun 22, 2011
    Forget oils Stew Mac makes an actual dye you brush on to darken or blacken fretboards. That's what you need. Then applying the fret doctor will help smooth everything out
  2. Sharky
    Sharky Senior Member
    4,899
    4,177
    Jan 19, 2012
    but giving it a good run or two with different grids MicroMesh will leave a lot slicker surface without taking off too much material. Really barely noticeable. Polishs frets fantastic too BTW
    Sct13 and RAG7890 like this.
  3. Tim Plains
    Tim Plains Senior Member
    12,472
    7,662
    Feb 11, 2008
    Fret Doctor once for 90 minutes always does it for me. Apply, wipe off after 45 minutes, apply again, wipe off after 90 minutes... dark. :thumb:
  4. rockinlespaul
    rockinlespaul Oxblood Addict V.I.P. Member
    10,026
    9,989
    Aug 12, 2007
    To oil the board, bore oil for me.
  5. rogue3
    rogue3 Senior Member
    1,223
    1,502
    Apr 22, 2017
    I don't.If you play it enough,your skins natural oils will darken it over time...at least mine has.I bend a lot so that probably helps,as i notice the rosewood has gotten shiny and smooth between frets..and darker.I'll bet oxide from the strings leaves a little dark too.
    winexprt, jlb32 and rockinlespaul like this.
  6. jlb32
    jlb32 Senior Member
    5,026
    4,104
    Oct 17, 2009
    Yeah, with play and age the fretboard will darken naturally.
  7. RAG7890
    RAG7890 Premium Member
    14,058
    21,978
    Jul 11, 2010
    ...............if received a Standard with some of the Fretboards I have seen lately, I'd be pretty dark. :squint: :rofl: :rofl: :rofl:
    :cheers2:
  8. Metal Guru
    Metal Guru Member
    97
    112
    Aug 20, 2015
    Also, you can accidentally dye the neck binding and inlays, which won't look too cool.
