Darken Fretboard
Discussion in 'Historics & Reissues' started by clutchcargo, Sep 24, 2017.
  1. clutchcargo
    clutchcargo Bionic Member
    864
    835
    Apr 16, 2012
    Has anyone had any dramatic success with making their fretboard very dark. I'm looking to get mine like my old HM, which was like playing on a smooth piece of volcanic glass. Black as night. I tried using Minwax ebony and it got a shade darker, but not the dramatic degree I'm looking for.
    Who likes this.
  2. Natural1
    Natural1 Premium Member
    174
    105
    Jan 3, 2013
    I haven't really tried anything to specifically darken, but I do like the MusicNomad F-One oil. Been using that for about a year and a half and it does seem to do the job nicely, and I think it might darken a little too.
    As far as the smoothness goes, you might want to try the last few grits in the "micro mesh" pad set. I've done that on my R0 and it made a world of difference. Although I had to work more-or-less in the direction of the frets, those pads are so fine you really can't see any evidence of it. Clean the board with naptha first, hit it lightly with small pieces of those pads, clean it again with naptha, and then finish with the oil.
    Jer and clutchcargo like this.
  3. clutchcargo
    864
    835
    Apr 16, 2012
    I can give that a try. Better than going with a sharpie.
    Who likes this.
  4. Natural1
    174
    105
    Jan 3, 2013
    definitely don't use a sharpie. I'd be shocked if anyone ever had success with that.
  5. clutchcargo
    864
    835
    Apr 16, 2012
    Does the rosewood fretboards come with any kind of sealent from the factory? It just seems like the stain sits on top and doesn't absorb. The only reason I'm experimenting so liberally is because I plan on eventually swapping out this board for Brazilian.
  6. Natural1
    174
    105
    Jan 3, 2013
    To my knowledge there is no sealant, but it's fairly dense and most boards won't exactly soak up oil. You can leave it on there for a few minutes before wiping down. It may also help to use a q-tip or similar to apply rather than spraying the board. That's what I do simply because spraying the board is going to make a bit of a mess.
    From all the other info I've seen on this over the years, I wouldn't leave it sitting for more than 5 minutes. There are stories of frets coming loose due to too much oil over time.
  7. rockinlespaul
    rockinlespaul Oxblood Addict V.I.P. Member
    10,292
    10,444
    Aug 12, 2007
    I've used Fiebings black oil dye with great success on a historic or two in the past.
  8. BBD
    BBD Senior Member
    2,049
    8,139
    Jan 16, 2017
    Fret Doctor works about the best of the oil treatments, but it won't turn the board super-dark. Several applications over the course of a year, with constant play, and the board will darken nicely but you can't really make a light board into a dark one without resort to HM magick (whatver it is they do).
  9. jkes01
    jkes01 Senior Member
    2,297
    1,227
    Jan 10, 2011
    mrfett and clutchcargo like this.
  10. BBD
    BBD Senior Member
    2,049
    8,139
    Jan 16, 2017
    Okay, never tried that, but I would be very cautious of actually dyeing the wood as opposed to simply oiling.
  11. rockinlespaul
    10,292
    10,444
    Aug 12, 2007
    Why? It's not going to hurt anything. If you want it darker, this is the way to go imho. Never had any issues with using it.
    jbat likes this.
  12. BBD
    BBD Senior Member
    2,049
    8,139
    Jan 16, 2017
    Because wood dyes that make more than subtle changes to the colour can look off, artificial. And it's much harder to get them out than it is to apply them.
  13. rockinlespaul
    10,292
    10,444
    Aug 12, 2007
    If you check out the link above to the Stew Mac stuff and read it you will see the recommended procedure for use.
    You do it a little at a time until you've reached the desired darkness.
    Most people like a very dark, almost black board so I don't see how it would look "off" or artificial anyways.
    jbat and clutchcargo like this.
  14. Wailing
    Wailing Senior Member
    280
    395
    Dec 22, 2014
    How often do you folks oil your rosewood fretboards ?
  15. BBD
    BBD Senior Member
    2,049
    8,139
    Jan 16, 2017
    Under bright interior light or sunlight, you see an artificial-looking tint, especially when very dark dyes are used. Dye pigmentation just doesn't look like natural wood pigmentation.
    clutchcargo likes this.
  16. RAG7890
    RAG7890 Premium Member
    14,486
    22,968
    Jul 11, 2010
    I would not overdo the Board Oiling. Once a year is more than enough IMHO.
    As for dying, if I had to, I'd go find a gun furniture restorer in my local area who's been working with furniture for years &7 looks like he has been around for ages.
    Then I'd ask him what he thinks & what he'd do to achieve whatever it is I was after............& do it with a natural dye so you don't come in to contact with something potentially hazardous.
    I know one of these guys because we had him restore two pieces of really old furniture when my Mother in Law passed away. If I remember I might ask him what he thinks. Can't hurt.
    I'll also ask my good mate who is a gun Luthier.
    My 2x FWIW. :)
    :cheers2:
    Sct13, clutchcargo and Callaway like this.
  17. jkes01
    2,297
    1,227
    Jan 10, 2011
    The big guitar companies have been dying real ebony boards for year because it’s a lot harder than it used to be to get true black ebony. In reality, what they use today was tossed away back then.
    A note about the StewMac finishing oil is that it has dryers in it so there is no oily residew left behind.
    I condition once maybe twice a year.
    Who likes this.
  18. Left Paw
    Left Paw Senior Member
    4,019
    2,409
    Dec 29, 2013
    I do roughly once a year, or so. On all my guitars,
  19. rockinlespaul
    10,292
    10,444
    Aug 12, 2007
    I've never noticed anything like that and have been very happy with the results.
  20. Sct13
    17,289
    20,543
    Sep 18, 2011
    I use bore oil (Fret Doctor)...It darkens but you need to play it and the wood will oxidize naturally. My light boarded R8 is darkening nicely...
    I will oil once every six or seven string changes, as soon as it looks like it needs to be cleaned, just to wipe it down so its very thin application... But I change strings often....
    I also hear ....that Boiled Linseed oil will darken a fret board...in fact Its what Gibson uses or used in the past....but I cant be sure what Gibson does. And I have not tried Boiled Linseed Oil....
