Custom Neck Builder
Discussion in 'Luthier's Corner' started by misterhatter6, Jan 3, 2018.
  1. misterhatter6
    misterhatter6 Senior Member
    176
    199
    Nov 20, 2016
    Not sure if this is the right place to post this, but who is the seller on EBay that will make custom necks? I'm thinking of having a baritone conversion done on one of my bolt-ons
  2. Pesh
    Pesh Senior Member
    332
    165
    May 4, 2015
    Not sure if there's one on eBay, but you can certainly get them from Warmoth.
    They assume that you're starting with a 25.500" scale on the guitar, and offer a conversion neck which takes it to 28.625", with all the placement of frets and build set accordingly.
    http://www.warmoth.com/Guitar/Necks/ConversionNecks.aspx
  3. ARandall
    ARandall Senior Member
    12,452
    8,057
    Apr 16, 2012
    Yep, for bolt-ons the places like Warmoth are best.
  4. misterhatter6
    176
    199
    Nov 20, 2016
    Well, the guitar(s) in question would be Epiphone Special models...not sure that Warmoth would do a neck to fit that
  5. ARandall
    12,452
    8,057
    Apr 16, 2012
    You'll have to measure your neck then, and see what dimensions the pocket is.
  6. misterhatter6
    176
    199
    Nov 20, 2016
    I can do that. I'll look into what I can get done at Warmoth. Thanks for the replies! :)
  7. Duane_the_tub
    Duane_the_tub Senior Member
    2,104
    3,601
    May 31, 2015
    P Scott Tucker, PST Guitars. A+++++
  8. ARandall
    12,452
    8,057
    Apr 16, 2012
    Warmoth has a couple of LP styles which are bolt on, so check those types first.
