CTS 500K pots the Long & Short Explained with Pics
Discussion in 'Tonefreaks' started by jonesy, Dec 19, 2012.
  1. tubehead
    tubehead Junior Member
    29
    8
    Feb 25, 2013
    This is a great post! Thanks for doing this.
    1 person likes this.
  2. jonesy
    17,138
    4,368
    Mar 28, 2008
    You're welcome bro, glad to do it. :)
  3. flats750
    flats750 Senior Member
    411
    220
    Nov 12, 2012
    Did the top actually get thicker? Or did they just not route into as deep from the backside?
  4. jonesy
    17,138
    4,368
    Mar 28, 2008
    Not sure, might be a good question for the Luthier section. :)
  5. donepearce
    donepearce Banned
    456
    362
    Jan 19, 2013
    One overall thing. Whatever the pot type, buy the right tool (like a socket wrench with a built-in handle) to do it up. I hate seeing people trying to fit these with a pair of pliers. I know that at some point they are going to slip and wreck a beautiful finish.
    2 people like this.
  6. CRAZYokiSKATER
    CRAZYokiSKATER Senior Member
    151
    19
    Feb 22, 2013
    Very valuable information here!! Just wondering, but do Epis use short and long shaft or just the cheepos. I recently got an Epi Les Paul, and I figured that I could change the pots right away. would the tone be better?
  7. jonesy
    17,138
    4,368
    Mar 28, 2008
    Pretty much all the epi's and other import LP's all take the short shaft pots. Yes you would notice a dramatic difference in how your V & T controls function, and you will reduce the muddiness with 50's wiring, better pots, caps and switch. Not all CTS pots are made the same so the taper and quality will vary.
  8. jonesy
    17,138
    4,368
    Mar 28, 2008
    :thumb:
    I use a 1/2" nut driver with a rubber coated handle and it works great for the CTS control nuts.
  9. BJunior
    BJunior Senior Member
    105
    43
    Apr 30, 2013
    I am thinking about changing the 300k volume pots on my 2012 Classic Custom, would i need the longer or shorter ones?
    Bit of a noob at this.
  10. jonesy
    17,138
    4,368
    Mar 28, 2008
    If it is a Gibson Classic, long shaft pots.
  11. BJunior
    105
    43
    Apr 30, 2013
    Thanks!
    I have heard good and bad things about changing the volume from 300k to 500k, what can you expect if you do change them?
  12. jonesy
    17,138
    4,368
    Mar 28, 2008
    The 500K or 550k will add more clarity and reduce muddiness, the 300k will sound a little more compressed with less highs. The tapers will also vary a little from pot to pot, some smoother than others.
    2 people like this.
  13. BJunior
    105
    43
    Apr 30, 2013
    Thank you
  14. jonesy
    17,138
    4,368
    Mar 28, 2008
    You're welcome bro.
  15. UEF
    UEF Senior Member
    345
    239
    Feb 23, 2011
    My 06 Custom has 2 short and 2 long - is that normal? I assumed it was to account for the contour of the body face
  16. jonesy
    17,138
    4,368
    Mar 28, 2008
    Hmm, I have never seen a mix of long and short shaft pots like that in a stock factory harness, but they did that because the carved top is thicker by the neck volume and tone controls then it is by the bridge controls.
  17. Freudster
    Freudster Senior Member
    295
    71
    Feb 20, 2012
    My 05 Custom also had 2 short for the volume and 2 long pots for the tone. That was a head scratcher!
  18. lespaul1765
    lespaul1765 Junior Member
    22
    0
    Dec 12, 2007
    just something i recently found,,i changed the stock pots on my 2011 lespaul with duncan jb in bridge and jazz in neck to a 50's wiring kit i bought online,,which has cts 500k pots and luxe capacitors..
    it made guitar so bright sounding i reverted back to stock gibson pots and wiring..
    maybe the original 57 classics would not have sounded so bright,,but i wanted to keep the duncans.. just an observation,,hope this might help anyone thinking of making the change.
  19. cynic79
    cynic79 Senior Member
    5,360
    2,167
    Jan 9, 2009
    The JB has a reputation for being a pretty bright pickup. It works great for hot-rodding a Fender-style guitar with 250k pots, but your mileage may vary with higher value pots.
    2 people like this.
  20. Tchap
    Tchap Senior Member
    692
    466
    Jun 11, 2011
    Thanks for posting this thread Jonesy. I'm just glad there are people like you on the net. I've figured or been shown most of the info you are imparting during my 40 some year internship with guitar playing, but, it's taken so long. At least the younger generations will hopefully appreciate what you're doing; the fact that instead of calling all over the place or driving all over the place, they can just tune into threads like this from you to understand what manufacturers used to do or do now to figure out how to improve their instruments.
    2 people like this.
