CS-336 build
Discussion in 'Luthier's Corner' started by Voske, Sep 11, 2016.
  1. Voske
    Voske Junior Member
    21
    32
    Sep 28, 2014
    Hi guys,
    Just after a year of thimking, reading and so on I decided to start with my own CS-336 scratch build.
    I've build a Tele in the past with prefabricated body and neck, but this is my first scratch build so I'm really curious how this will turn out!
    The body is made from 3 pieces of mahogany which have been laying around in my shop for ages.
    I haven't made any pictures of joning the parts together, so the first pictures are from the body and neck after the first routing.
  2. Voske
    Voske Junior Member
    21
    32
    Sep 28, 2014
    Next, I've hollowed the body with a drill and a router.
    This is the result:
    As you can see in the upper right corner, the height setting from my router got loose during routing so I went a bit to deep. But no problem, there is flesh enough :)
  3. Voske
    Voske Junior Member
    21
    32
    Sep 28, 2014
    I had a really thick piece of hard rock, quarter sawn maple lying around which I wille be using for the top.
    The circular saw wasn't big enough to cut through, so I had to do some little "hand work" to split the parts.
    Sawing the top:
    Glueing the top:
  4. agiehler
    agiehler Senior Member
    354
    223
    Oct 17, 2013
    Nice work so far :thumb:
  5. fordmugg
    fordmugg Silver Supporter
    158
    311
    Jun 19, 2015
    Looking good....
  6. Voske
    Voske Junior Member
    21
    32
    Sep 28, 2014
    Thanks!
    I will post more pictures along the way as the project continues.
    Cya,
    Marc
  7. Voske
    Voske Junior Member
    21
    32
    Sep 28, 2014
    So... I guess this is going to be a slow build ;)
    Today I carved the top.
    I'm very satisfied with the result of the carve!
  8. mux164
    mux164 Senior Member
    2,595
    1,821
    Sep 1, 2012
    :thumb:Awesome mate:thumb:
  9. Voske
    Voske Junior Member
    21
    32
    Sep 28, 2014
    One thing though which I'm a bit worried about is the body to neck weight ratio.
    I've hollowed the body a bit too deep. The plans call for a hollow out of 2,5 cm (one inch) which results in a 1,7 cm thick back.
    I've hollowed 3,2 cm which leaves a back of 1 cm.
    Would this be a problem weight wise or acoustic wise?
    Thanks for your thoughts!
  10. ARandall
    ARandall Senior Member
    11,510
    6,754
    Apr 16, 2012
    Nice maple!!!
    Do please make sure you make a nice low colour burst or similar to show off that lovely grain and fleck!!
    As to the hollowing, the back is carved too with the 336 I think. So the depth is needed to allow for the back wood removal....which would leave the body in the same sort of wood thickness as what you have. But with 2 pickups, TOM and t/p plus electronics there tends to be more weight in the finished article anyhow. And if you use Kluson style tuners there should be no issue
  11. Voske
    Voske Junior Member
    21
    32
    Sep 28, 2014
    Alright,
    Now my SG project is almost ready I will be continuing with this project!
    As I mentioned before I routed out the body too deep to make a curved back.
    I decided to make the body all over again since I would really like a curved back...
    I've recently bought an old overhead router which I restored completely and used for a new body.
    It's such a nice job routing with this machine.
    Normally I would have cut out the body with the bandsaw first but I thought to route it completely with the overhead router. Starting inside first and the outer once finished.
    First round...
    There was a bit of tape stuck at the bottom of the template, therefore the route at the bottom was not good at first.
    Lucky it was on "the good side"
    ready, one Inch deep.
    Second round on the outer side.
    I think I need to sharpen my router bit soon....
    Done!
    The complete process took around half an hour... what a thrill to be working with this machine!
    Now I have enough flesh on the back to make a nice carve in the Mahogany.. Looking forward to do that!
    Next, I will be working on hollowing the maple top.
    My first idea was to do this also on the overhead router for quick results. BAD choise!
    On one of the first runs I almost went through the top while I didn't used the correct angle on the top regarding the router bit.
    Fortunate enough the damage was little, so I could repair it with wood repair. I think that it will not be visible when the burst is on.
    Damaged area... :(
    After a lot of drilling with a depth stop on the drill press, I started chiseling out the wood.
    That's starting to look good!
    Almost ready!
    Now..... sanding...
    I'll keep you posted on this project...
    Marc
