Counting the Budokans...
Discussion in 'Epiphone Les Pauls' started by Tenacious T, Jul 30, 2012.
  1. musicfan57
    musicfan57 Member
    50
    92
    Jan 24, 2013
    I'm with you on this. Epiphone really knocked it out of the park on this one.
    Played mine again last night for a couple of hours, still amazed at the sustain it has.
    Unfortunately for me, I didn't get to see KISS until 1983 and didn't know
    until I got to the concert that Ace wasn't there. I was mad. But I did
    get to see the original line up 3 times when they reunited.
    Saw Ace a few years back at the House of Blues. I was drunk, but I think
    he was sober, but I was too drunk to know for sure. lol
    1 person likes this.
  2. 93LPStudio
    93LPStudio Senior Member
    1,461
    1,141
    Dec 19, 2013
    Just want to thank you for taking it upon yourself to find what was the issue with these tuners and for taking the lead in contacting Grover. I contacted Grover and although they didn't have the replacement ferrels/collars in stock they assured me that they would take care of me. Took about a month but they came in the mail few weeks ago now. Not wanting to replace the original pearloid buttons with the plain looking replacements that Grover sent I seperated the originals and installed them onto the replacement ferrels/collars. ALL, absolutely ALL the slop is gone and the tuners do Not slip at all. Absolutely the only issue besides the wrong size pup rings concerning these Les Paul Customs from the factory. Thanks! Thanks! Thanks!:applause::applause::applause:
  3. rtcook
    rtcook Senior Member
    135
    99
    Sep 26, 2013
    You're welcome. Glad it worked out for you. I got the correct rings from Epiphone. But, I put them on like Ace had them.
  4. 93LPStudio
    1,461
    1,141
    Dec 19, 2013
    When I got 185 from XTN he included a correct size rings from Classic Ax in Nashville, first thing I changed out as matter of fact. Those ferrels/collars are a lot bigger than stock ones were as well. Amazing the difference it made.
  5. 93LPStudio
    1,461
    1,141
    Dec 19, 2013
    By the way RTCook...did you install that wiring harness you mentioned a few threads back? If so I missed it and curious as to your thoughts on it.:thumb:
  6. rtcook
    135
    99
    Sep 26, 2013
    Wiring harness is installed. But, have an issue I need to sort out. One of the wires must be touching as I get alot of noise from it. Haven't had time to diagnose it. Will let you know though.
  7. rtcook
    135
    99
    Sep 26, 2013
    Ace installed his rings like this. The neck is a neck ring but installed 180 degrees opposite. Taper is towards the bridge. The middle ring is actually a neck ring in the proper orientation. Taper towards the neck. This arrangement allowed more room under the strings so you are not hitting the pickup with your pick. Since Ace did not actually use these pickups, the pickups are adjusted down to the top of the ring for maximum clearance.
  8. 93LPStudio
    1,461
    1,141
    Dec 19, 2013
    That is interesting as I never knew that he had done that with the neck pup ring!
  9. rtcook
    135
    99
    Sep 26, 2013
    I got that from an actual picture of Ace's guitar.
  10. 93LPStudio
    1,461
    1,141
    Dec 19, 2013
    Just for posterity and for those that have not dealt with this issue of the sloppiness of the tuners on these Budokans, or at least some of them. Here are a few pics of the ferrels/collars, stock/replacement. Well worth the "fix" as mine stay's in tune now, and possibly a minor tweak of the button to get her into pitch after days of sitting in the case. Please excuse the bad pics!
    Stock on the left/Grover replacement on the right. You can see the difference in the middle hole, the replacement has tighter tolerances. It is also bigger as you can see.
    Stock on the left and replacement on the right. Although pic is blurry but you can see the size difference as well. Once placed on the tuner shaft you realize this little difference made a world of difference.
  11. Parasite68
    Parasite68 Senior Member
    1,112
    671
    Dec 5, 2013
    I personally own a signed one from Ace directly. The ones he got were only abut 25 or so and he signed them all. They are not included in the 1000 and the coa is different it mentions that it is a specially signed guitar with no number out of 1000, but should have the serial number on it., I'm confident the seller is BSing you about the unsigned one coming from Ace because it didn't. It still may be a legit budokan.
    When Ace sold them thru his website he sold them for $1700.00 when they were still on the market for 699 usd. Numbered of course.
  12. XTN
    XTN Senior Member
    214
    112
    Feb 20, 2015
    I second that emotion. Huge difference.
  13. rtcook
    135
    99
    Sep 26, 2013
    Take a picture of the bottom of those ferrels and post so people can see why there was so much slop. It's that's connection that causes the slop.
  14. 93LPStudio
    1,461
    1,141
    Dec 19, 2013
    To late I didn't think to do that! All I know is they are perfect with this fix. So glad again you persued Grover!:thumb:
  15. XTN
    XTN Senior Member
    214
    112
    Feb 20, 2015
    The replacement ones have less turn play.
    I urge Budokan owners to contact Chuck at Grover chuck at grotto dot com and ask for replacements.
  16. hogdaddy
    hogdaddy Senior Member
    279
    272
    Oct 21, 2012
    I got my fix yesterday. Thanks for the heads up~:dude:
    2 people like this.
  17. musicfan57
    musicfan57 Member
    50
    92
    Jan 24, 2013
    I did exactly that, and in one week I had the replacements in the mail. Got them yesterday.
    Thank you so much for the heads up on this one.
    Now, all I need is patience and better eye sight to make the swap!! lol
    2 people like this.
  18. XTN
    XTN Senior Member
    214
    112
    Feb 20, 2015
    A public 'Thank You' to rtcook who dealt with Grover and got them to offer up a solution. It was a glaring defect that had been angering me since day 1 of my first Budokan. And with my second.
    2 people like this.
  19. rtcook
    135
    99
    Sep 26, 2013
    And a public 'Thank You' to rtcook who dealt with Grover and got them to offer up a solution. It was a glaring defect that had been angering me since day 1 of my first Budokan. And with my second. [/QUOTE]
    You are most welcome and I sincerely appreciate the recognition.
    2 people like this.
  20. NRVPaul
    NRVPaul Senior Member
    1,051
    771
    Nov 19, 2011
    Just called Chuck at Grover today and he is sending my fix out!
