Conversion bushings.
Discussion in 'Vintage Les Pauls' started by jeggz, Aug 31, 2017.
  1. bossaddict
    bossaddict @david.beason on IG Premium Member
    6,477
    8,399
    Apr 4, 2013
    Is that an SG? Have you ever seen it on a Les Paul?
    Kris Ford likes this.
  2. Kris Ford
    Kris Ford Senior Member
    4,754
    4,035
    Dec 17, 2011
    No..have bever seen one..yet..could be though!
    This is a SG Special. Has to be post '65 due to TRC.
    bossaddict likes this.
  3. bsteff666
    bsteff666 Senior Member
    303
    426
    Mar 5, 2010
    I un-Grovered my 56 TV. I also wanted a little less weight on the headstock... Plus I just like the original look.
    I used that kit from Ebay. The wooden cylinders that are drilled out & the bushings that fit & look pretty close to the originals. I glued them in.
    Well... the Grover holes were not neatly or evenly drilled. I didn't realize this would be such an issue until after it was done.
    A set of 3 on a plate Klusons dropped right in... but because of the imprecise fit...some of those tuners rub & fit really tight. It affects tuning stability.
    I haven't had a chance...but my plan is to dowel & redrill. It think that is the best way.
    RAG7890, Kris Ford and jeggz like this.
  4. jeggz
    jeggz Senior Member
    3,499
    2,918
    Aug 19, 2008
    Who sells em?
  5. bsteff666
    303
    426
    Mar 5, 2010
  6. bsteff666
    303
    426
    Mar 5, 2010
  7. RayTorvalds
    RayTorvalds Senior Member
    1,066
    878
    Apr 29, 2015
    I have never changed tuners on a guitar before. Can you actually feel it when playing the guitar ? I guess, balance wise ? Considering it's so little of a difference.
    I'm genuinely curious about this.
  8. deadlyweasel
    deadlyweasel Silver Supporter
    1,439
    1,101
    Mar 25, 2011
    Yeah man, if you use slick guitar straps removing grovers can really reduce neck dive
    RayTorvalds likes this.
  9. bossaddict
    6,477
    8,399
    Apr 4, 2013
  10. jeggz
    jeggz Senior Member
    3,499
    2,918
    Aug 19, 2008
    I guess we'll see how these work.
    I'm gonna use that Stewmac fish glue for the first time as well.
  11. Kris Ford
    4,754
    4,035
    Dec 17, 2011
    It's the norm, rather than the exception I have seen that "less than professional" tools and installation techniques were used to mount Grovers then..
    jeggz likes this.
  12. kakerlak
    kakerlak Senior Member
    1,538
    572
    Feb 5, 2014
    Yeah, that's exactly what I was talking about.
  13. Kris Ford
    4,754
    4,035
    Dec 17, 2011
    Me too! :D
  14. FF_Pedals
    FF_Pedals Senior Member
    2,125
    216
    Jan 22, 2009
    My special needs these :eek:. Doesn't look like he ships to Canada...
  15. jeggz
    jeggz Senior Member
    3,499
    2,918
    Aug 19, 2008
    Took off the Grovers, looked like Howe opened the holes with a blunt screwdriver.
    Grovers went back on.
    Is what it is.
  16. bsteff666
    303
    426
    Mar 5, 2010
    Yep. That's what my 56 was like.
    Unless those holes were enlarged perfectly straight with a drill press... those little wooden cylinders won't do it.
    They are a great idea though.
  17. jeggz
    jeggz Senior Member
    3,499
    2,918
    Aug 19, 2008
    The holes were almost oval.
  18. Kris Ford
    4,754
    4,035
    Dec 17, 2011
    On my '64 Sg Jr, you could tell where the electric drill twisted when it poked through...also ovaling the holes out making it egg shape..thank gawd the washer covered that mess..MAYBE that's why Grover used to send 'em out with the almost nickel sized washers? They KNEW folks would use what ever was on hand to install..and the washer would close any gap and make for a tidy appearance afterward..
    BUT..I have used a electric hand drill to install a set (NON vintage, of course..I'm no dummy), and the secret is to use reverse speed..and makes for much cleaner, straight holes, but is more time consuming.
    jeggz likes this.
