Conn Les Paul copy
Discussion in 'Other Single-Cuts' started by truetone6, Nov 4, 2013.
  1. NRVPaul
    NRVPaul Senior Member
    1,051
    771
    Nov 19, 2011
    Looks like plywood.....But if it plays nice who cares.
  2. truetone6
    truetone6 Senior Member
    2,476
    1,243
    Nov 12, 2009
    At the top of the neck pickup rout it looks like ply but at the bottom and in the bridge rout you can see a maple cap under a laminated veneer glued to the mahogany back.
    PermissionToLand and truckermde like this.
  3. emerald81
    emerald81 Senior Member
    373
    269
    Jul 4, 2010
    Nice guitar, I think the top could be alder and some plywood then (I see ┬┐two? caps of laminated wood or something like).
    Looks fine condition. Congrats.
    1 person likes this.
  4. truetone6
    2,476
    1,243
    Nov 12, 2009
    Thanks! Here is a CONN Les Paul in Studio A at Bass Propulsion Labratories in Dallas(recording studio owned by Todd Pipes of "Deep Blue Something")
    Clayton Ferrell(Hedgehog and Frog) recording with the CONN at BPL
  5. truckermde
    truckermde Senior Member
    14,204
    18,044
    Oct 21, 2012
    Badass!
    I've had several Conn (brass) instruments over the years, but I didn't even know they made guitars! Those all look great, and I'll bet they are.
    Now I want one of these, too. Damnit!
  6. ben_zep
    ben_zep Junior Member
    15
    3
    Nov 11, 2013
    i knew someone who had a conn
    pretty good instrument from what i saw and heard
  7. warmachine
    warmachine Senior Member
    670
    161
    Jul 16, 2008
    I think the best description I can give on the construction of these Les Paul copies is to picture that thin plywood top removed from the guitar, then what your left with is a solid wood guitar body that resembles a LP Jr. These "bent ply tops" are just there to mimick the shape of a real Gibson Lp's expensive thick solid carved maple cap.
    I've got two of the heralded Ibanez lawsuit les pauls and they don't have that much wood beneath the top like this Conn. The Conn has the same "bent ply top" as the Ibanezs but underneath it has that nice piece of solid wood filler where normally there would be a void. Now if it that solid piece extends below the bridge and stoptail and not just the pickup area, then thats a treat. Give it a good old knock a few inches beneath the tailpiece and see if it sounds hollow or not.
  8. truetone6
    2,476
    1,243
    Nov 12, 2009
    Thanks for the post! Yes,below is a photo of the Ibanez 2386 which has a setneck but a bent plywood top which is hollow
    The Conn has solid wood between the top and mahogany back
    It looks(and sounds) solid. But there is some plywood around the neck as you can see in these photos below.
    PermissionToLand likes this.
  9. warmachine
    670
    161
    Jul 16, 2008
    Very cool pic of the Ibanez 2386! I have an equivalent to that model which is just devoid of the Ibanez logo. It has a very cavernous interior, yet despite this un-Les Paul like construction, sounds excellent and only weighs a tad over 8lbs. Here's some pics of the pickup cavity and the whole guitar.
    With that being said, there is at least one owner who told me his Ibanez 2386 has a filler portion of plywood under the bent ply top. Very similar to what Aria Pro II did on some of it's Les Paul copies.....and seemingly similar to what you have going on with the Conn. It was called a "solidified hollow-less body" See link below for the catalog pic showing this.
    Catalog Image
  10. warmachine
    670
    161
    Jul 16, 2008
  11. truetone6
    2,476
    1,243
    Nov 12, 2009
  12. truetone6
    2,476
    1,243
    Nov 12, 2009
    [ame=http://www.youtube.com/watch?v=zfaKj5RH76A]T. Rex in Concert - March 18, 1972, 5:30pm Show - YouTube[/ame]
  13. hardangerfjol
    hardangerfjol Senior Member
    231
    27
    Nov 19, 2009
    interesting construction but hard to see and to be sure about the details.
    at one point i thought i saw a two layered solid body...also as stated its obviously different from the usual ibanez type ply top...
    food for thought indeed !
    h.
  14. LarryC
    LarryC Junior Member
    15
    28
    Dec 20, 2007
    Nectro thread,but I just picked up one of these Conn Les Pauls and I couldn't be happier.I noticed that one pictured doesn't have the CONN inlay on the fretboard. Anyway,I found it interesting about the "solidified" hollowbody design.
  15. PermissionToLand
    PermissionToLand Senior Member
    515
    229
    Sep 1, 2014
    I think what we're seeing at the neck is just the wood grain going horizontal, making it look like ply/laminate. I don't think any guitar exists that would have a half solid wood and half ply cap (not talking about the bent ply top here, but the cap beneath), split across the width of the body. Just doesn't make sense.
  16. Uncle Salty
    Uncle Salty Senior Member
    588
    159
    Mar 18, 2007
    If the mini switch is hooked up to the Dimarzio it probably came with the pickup.
    Dimarzio called it a Dual Sound humbucker. It is a super distortion at heart
