Complete EPI custom setup
Discussion in 'Epiphone Les Pauls' started by Roman, Jul 30, 2008.
  1. dogdew
    dogdew Senior Member
    414
    279
    Feb 22, 2010
    great thread! thanks so much!
    i'm not sure what this picture is meant to suggest?
    is the pick snug between the string and the 12th fret?
    if the neck relief is right and the frets level when using a pick like this roughly how much clearance is ideal?
    thanks again!
  2. Hack
    Hack Senior Member
    16,168
    43,546
    Jul 15, 2010
    Indeed you are.
    ...show us some pics of your guitar! :dude:
  3. paruwi
    19,973
    26,634
    Dec 24, 2009
    I smell SPAM......:D
  4. straybeat
    straybeat Senior Member
    2,629
    1,460
    May 11, 2011
    Hey Roman,
    If you're still following this thread, they make collars with a set screw to put around drill bits. With a pair of calipers you can then measure the exact depth you want and tighten the collar at that point. This is what we use in machine shops. A collar will usually fit a dozen different drill sizes, beyond that you just buy a different size collar.
  5. rodm717
    rodm717 Junior Member
    25
    7
    Aug 7, 2011
    Many thanks, not only to the OP, but also to everyone who posted. This has to be the most infomative setup thread I've read and continue to reread. It has inspired me to be more hands on with my own guitars setup. Much appreciated.:thumb::applause:
  6. 2themax
    2themax Senior Member
    662
    262
    Sep 26, 2011
    This is excellent information - the pix really help out.
    Roman: When you say scrape the fretboard to get to the wood, are you using a single edge razor blade or a special tool?
  7. jbutler
    jbutler Senior Member
    349
    21
    May 14, 2008
    Roman has a video up on this exact subject... doing a youtube search should find it for you.... But in the vid he uses one of those stiff, single edged trapezoid shaped razors... the kind you would use in one of those Sears utility knives.... I've scraped the boards on all my necks using Romans instructions and they look and feel great.... take it slow and you should be happy with the results...
  8. 2themax
    662
    262
    Sep 26, 2011
    Thank you - I'll definately do the you-tube search. Lots of great info there. I've been learning basic neck setup - this is really great stuff. :D
  9. KzooKid
    KzooKid Member
    60
    1
    Nov 16, 2010
    Roman,
    Great information! Can't say how many times I've read through this. I'm ready to start this on my Epiphone standard. Figured if I take my time, I should be able to do it. Heck I work on aircraft and sailboats, should be able to tackle a guitar. One question, when leveling the frets, do you use a flat file, or as I have read somewhere else a wood block/sand paper with the radius of the fretboard?
  10. KzooKid
    KzooKid Member
    60
    1
    Nov 16, 2010
    Roman,
  11. KzooKid
    KzooKid Member
    60
    1
    Nov 16, 2010
    For some reason the computer burped, and posted twice?
  12. LiquidIce
    LiquidIce Senior Member
    282
    130
    Nov 20, 2011
    scraping the neck wood with a razor makes me nervous....
    Steven and prolific.jones82 like this.
  13. emerald81
    emerald81 Senior Member
    373
    269
    Jul 4, 2010
    The picture show the string height. Maybe 2mm for the 6th string & 1.5mm for the 1st...
    The fender heavy pick is the reference.
  14. LiquidIce
    282
    130
    Nov 20, 2011
    hey, could the owner of the guitar post a current pic of the back of the neck where it was sanded? Thinking I might try this, but will probably experiment on an acoustic.
    Funny, went to hardware store today and could only find 150 fine paper...
  15. rdbear7d
    rdbear7d Senior Member
    170
    103
    Jan 23, 2012
    hey Roman barry here, read and watched your post of coarse i love it.very detailed.i have a very unique question..on your post here you said to get the wider thicker bridge.is the roller bridge for gibson a good one /please let me know.and if not what was the name of that bridge you talked about. ,well had a bit more meat on it?thanks and God Bless. Barry
  16. Todd_6c
    Todd_6c Junior Member
    1
    1
    Feb 18, 2012
    After reading this thread I decided to give this a shot on an old cheap Ibanez I've had for years. It's amazing what a few files, a razor blade, masking tape, steel wool, and a little lemon oil can do for a guitar! I didn't get to go so far as changing the nut, but just re-working the frets, scraping the fretboard, and adjusting the action and innotation have done wonders. It's gone from a guitar I couldn't even stand to look at to one that I can't put down again. I'm amazed.... I'm not a skilled luthier by any means (before this the extent of my guitar care was changing strings) so I would suggest this for any one. It doesn't even really require any special tools at all (even though I'm sure it would be easier with specialized fret files). I just used regular small hand files and a straight edge for fret filing and leveling. Thank you so much Roman for inspiring me. I've got the luthier bug big time and my wife doesn't appreciate it :)
    1 person likes this.
  17. Mikey1969
    Mikey1969 Banned
    79
    62
    Feb 23, 2012
    Great thread, thanks for making it! I am going to be late for work if I study it now. I'll be back later :thumb:
    Edit:
    What is your opinion of this method for a guitar that has a fret so high that is has become a dead spot?
    http://youtu.be/c527_CtazOQ
    He makes it look so easy.
    ...I have some Dan Erlewine's books/DVD's I ordered that I plan on studying before starting any work. I purchased his fret basics, repair series, how to make a guitar play great. I think those might get my foot in the door.
  18. Hectgore
    Hectgore Senior Member
    483
    3
    Jul 1, 2008
    I am WAY late, haven't visited this place in ages.
    Not sure if I could fulfill your request, but I will try and get some shots up.
    Woah, I haven't touched my guitars in a while. It is time for me to sell my gear and move on. I still love music, i've just branched out past the genres I use to listen to but I realized that when it came to guitar I was always more of a tinkerer and gearhead vs spending time to ACTUALLY play the instrument. A shame, but I learned alot throughout the proccess.
    I am going to be listing this guitar for sale on the net sometime soon. I tinkered around with this guitar A LOT more than I played it. After taking it to Roman, I changed out the pots and pickups myself and I also decided to experiment with the glossy finish. I liked how the sanded neck looked on it, and decided to bring down the whole body down to a matte black finish. Didn't exactly turn out as I wanted too. I accidentally sanded off too much in some spots (the back looks like it has buckle rash) but it was a good learning experience. Pictures will be up here, as if it still possible to sell gear on here, I will give you guys dibs at this Epi at a good price.
    EDIT: Woah, re-reading my comments; it's like a time machine...
  19. Stage Fright
    Stage Fright Banned
    1,297
    1,307
    Mar 8, 2012
    Love this thread! I have a 1985 Strat w/System III that played like crap. I figured I'd try a simple scrape and oiling last night just to see what difference it made. It feels and plays completely different! I didn't want to put it down but had to go to bed at some point so I could get up and go to work this morning.
    I removed the strings, scraped between the frets, cleaned and oiled the neck only. I did not mess with the frets at all. The strings had never been played (the guitar barely has) but were corroded so I took a greeny weenie and car polish and cleaned G, B, and E off. It feels like a $1500 guitar now.
  20. Hectgore
    483
    3
    Jul 1, 2008
    I forgot to post up here. This guitar is For Sale. I'm in need of cash and want this to go to someone who enjoys tinkering or playing the hell out of it. Shoot me an offer if you're interested! It doesnt hurt to try :thumb:
    I think I put a picture of the neck, behind the fretboard.[forgot who asked]
