Clapton maestro tailpiece mod for 63 SG
Discussion in 'Vintage SG' started by Blacksheep, Jul 18, 2017.
  1. Blacksheep
    Blacksheep Member
    70
    57
    Apr 19, 2010
    Anyone know where I can get a modded tailpiece like this?:
    http://i.imgur.com/wLJag3k.jpg
    My 63 SG plays fantastically until you get right up the dusty end (17th fret) when it suddenly becomes very plinky (technical term) with no sustain at all.
    I'm pretty sure this is because of the bad break angle caused by the Maestro. So I though I might try the Clapton The Fool mod. Don't want to mod or otherwise tinker with the original Maestro for obvious reasons.
  2. chasenblues
    chasenblues Senior Member
    18,990
    25,268
    Apr 2, 2007
    My comments are just observations/suggestions..Sorry if they seen obvious or that you've already contemplated them.
    I poked around some and haven't seen a Maestro for sale in that configuration but..
    Do you have the tools-ability to mod one yourself or maybe know of a machine shop that could do the work?
    It appears that what was done was that the "Comb(?)" of the tailpiece was removed(Cut off and the remnants ground off/cleaned up).
    Then holes were drilled in the bar for the strings.
    Then re-chromed..
    Having typed all that..Looking at this old image of the real guitar when Rundgren first owned it, it doesn't look like the mod actually helped/did much for the break angle of the strings. (Maybe that's why it eventually ends up with a Stop TP?)
    Soo if you've read this far:laugh2:, It might turn out that your only option would be to buy a Maestro or copy of one(Depending on how much you're looking/willing to spend) and have the Mods done.
  3. Blacksheep
    Blacksheep Member
    70
    57
    Apr 19, 2010
    Yes I've come to the same conclusion as you. I think I'd need the machining done by a pro, the chances of maiming myself are probably quite high.
    The_Nuge likes this.
  4. chasenblues
    18,990
    25,268
    Apr 2, 2007
    I'm mostly all thumbs myself.:rofl:
  5. kakerlak
    kakerlak Senior Member
    1,299
    382
    Feb 5, 2014
    You might get a little extra break angle by leaving the "comb" in place, drilling the holes through the bar like the modded one, and running the strings under the comb/spring plate. Then again, string tension might be enough to pull them all the way straight anyway, but it could provide a little damping behind the bridge, if nothing else.
  6. Al Walker
    Al Walker Senior Member
    988
    969
    Sep 14, 2014
    If that guitar has the wrap around bridge on it. Why not just slide the top part of the trem out and just use the wrap around bridge? If it's an ABR then use the above mentioned method. Mine didn't have a trap style ,but, here is my Melody Maker.
  7. chasenblues
    18,990
    25,268
    Apr 2, 2007
    :hmm:
    Just more general observations/comments,I've never held or seen one in person.
    Does the bottom section of the "comb" on your guitar sit/rest on top of the guitars body?
    If it sits on top of the guitar i would imagine that it won't make changing the strings particularly easy if you had to force them under the comb to go over the bridge.
  8. Al Walker
    988
    969
    Sep 14, 2014
    Looking at the last picture, I'd just leave it alone. Nothings going to change as far as angle. Maybe a 335 trapazoid? And then that may not change anything either. Did you check if the frets were level?
  9. chasenblues
    18,990
    25,268
    Apr 2, 2007
  10. Blacksheep
    Blacksheep Member
    70
    57
    Apr 19, 2010
    Thanks for suggestions. I emailed Dan who said he could make me one . . but would really need the guitar. My need isn't so great that I'd risk sending a 63 SG from UK!
    The comb on mine is not flat on the felt, there is a small amount of play.
    I'll probably try to get a repro Maestro and find someone near me who can do the metalwork.
  11. sikoniko
    sikoniko Senior Member
    1,178
    1,509
    Sep 4, 2011
    That's my SG in the initial post. Unfortunately, photobucket has removed the pictures...
    I'm not clear I understand your issue, but I have no problems playing above the 17th fret.
    I didn't originally look to go this route. I traded a HM for a '63 husk that someone bought to part out. The vibrola that he had installed rattled and I wanted a vintage one to restore it. I was looking on ebay and happened upon this option and bought it, partially due to price and partially because I don't imagine I will use the vibrola anyways, so it just removed something that was in the way.
  12. kakerlak
    1,299
    382
    Feb 5, 2014
    I bet drilling through the hook-back/leading edge of the comb would give you lots of break angle...
  13. spikeymikey
    spikeymikey Junior Member
    24
    31
    Oct 7, 2010
    Just a little point Blacksheep? What tuners are on the guitar?
    Also, is it an SG with a "Fool" paint job applied?
