Chasing a hum '85 LPC
Discussion in 'Tonefreaks' started by Becker34, Jun 22, 2017.
  1. Becker34
    Becker34 Senior Member
    217
    387
    Feb 27, 2017
    Got a helluva hum on my '85 LPC. I'm pretty green on dealing with electrical stuff, so any help/links are appreciated. Search made me more confused.
    The guitar is factory stock except for the straplocks. I've never farted around with the electric. The hum is there in every pickup selector position. It's a bit louder when switched to the bridge pickup. It goes away when I touch anything metal on the guitar except the straplocks. It goes away when I touch a tuner, string, bridge, tailpiece, pickup cover, jack plate, the metal part of the pickup toggle, you get the idea. It also pretty much goes away when I turn the volume pot - either one and/or both - all the way up to 10, or when I turn them down to 0. The hum is also there regardless of where, what amp or which cable I use. My '80 Standard is dead quiet.
    Again, thanks for any help.
  2. C_Becker
    C_Becker Dat Gibson smell Premium Member
    1,862
    1,743
    Jul 7, 2015
    If the hum goes away when you touch any metal parts, that indicates that your bridge ground is OK.
    Did you always have the hum or did it just turn up recently ?
    I would check the ground connections on the back of the pots and on the output jack first.
    Make sure the lugs on the volume and tone pots are properly connected to the back as well.
    A certain amount of hum is normal when playing high-gain (do you ?), even with humbuckers.
  3. DarrellV
    14,618
    28,312
    Nov 1, 2016
    Any chance of getting pics from the back with covers off?
  4. Becker34
    217
    387
    Feb 27, 2017
    The hum has been there for a while. I don't remember if there was a particular event that led up to it. I chalked it up to being crappy electrical in the house, but it does it wherever.
    The hum is there regardless of if I'm playing it clean or high gain.
  5. spitfire
    spitfire Senior Member
    1,706
    1,776
    Sep 21, 2009
    Are you sure it is the guitar and not the cable or amp? Try another guitar and if possible the '85 LPC with another cable and amp.
    Also, try a different AC outlet for the amp. As always, simplify as much as possible. Guitar strait to the amp, no pedal board or stomp boxes.
  6. Becker34
    217
    387
    Feb 27, 2017
    I've played it with different amps, different cords, different places. Hum's still there, still the same. I tried switching all of those things. It's the guitar.
  7. chasenblues
    chasenblues Senior Member
    20,396
    29,673
    Apr 2, 2007
    Have you checked the ground wire connection on the output jack?
  8. Becker34
    217
    387
    Feb 27, 2017
    Output jack looks good.
    Control cavity pic for DarrelIV
  9. DarrellV
    14,618
    28,312
    Nov 1, 2016
    Ok, here's my guess from what I can see in the pic (thanks,BTW!)...
    The output jack may be soldered well, but I'm wondering about a cold or bad solder joint on the terminal strip.
    I see the bare wire attached to the top and the experts can tell me if I'm wrong, but I think that would be the ground to the tailpiece for grounding the strings. From your description, this is working.
    But what about the connections from where the shield from the jack is soldered to the lug and down from there to where it grounds to the plate?
    It looks to me like all the pots and associated parts (like the pup grounds) all go through that plate by way of the pots being screwed down onto it.
    A lifted ground here would un-ground all the components except the bridge wire, which is soldered on the top.
    Just a guess....
    C_Becker likes this.
  10. C_Becker
    1,862
    1,743
    Jul 7, 2015
    What @DarellV said, I'd solder a wire to all the pot casings, see if it goes away
    DarrellV likes this.
  11. chasenblues
    20,396
    29,673
    Apr 2, 2007
    Theoretically that's what the plate is doing.
  12. C_Becker
    1,862
    1,743
    Jul 7, 2015
    I know, but I trust a solder connection more.
    EDIT: And it would definitely rule the ground connection out.
