Changing Kluson Tuners to er, Kluson Tuners ?
Discussion in 'The Custom Shop' started by scovell001, May 4, 2017.
  1. scovell001
    scovell001 Senior Member
    187
    85
    Sep 3, 2015
    Hiya to all on the forum.
    On my Trad I have Kluson Deluxe tuners with the nut on the front. Is it 'possible' to change these to the press fit Kluson Tuners as found on older LP's ?
  2. chrisuk
    chrisuk Senior Member
    2,649
    1,923
    Sep 19, 2010
    Yes but you might need some bushings as the bolt through tuners are fatter. Personally I wouldn't bother.
    SparkyJones likes this.
  3. kakerlak
    kakerlak Senior Member
    1,318
    391
    Feb 5, 2014
    Yeah, you'll need conversion bushings, which work fine and are readily available for under $10. Beware that sometimes the headstocks on guitars with screw-down bushings are thicker than those with press-fit ones and the vintage style Klusons may sit sort of deep in the headstock, such that the fluted parts of the shafts don't sit fully proud of the face of the headstock. They should still be functional, but the sunken look might annoy some folks.
  4. scovell001
    187
    85
    Sep 3, 2015
    Brilliant,
    Thanks guys. I feel a 'leave it alone' coming on !
    Thanks again
  5. moreles
    moreles Senior Member
    2,355
    952
    Apr 16, 2011
    The threaded, screw-down ferrule tuners are more stable than the press-fit ones, so you're better off mechanically as-is, even if you do want the look of the pressed-in bushings. The conversion hardware does work, though. If you make the change, be careful removing and inserting hardware, as it's easy to lift off the finish around the post holes if you're careless. Having said this, I confess that I install Grover Rotomatics (old style) on all my Gibsons because I think Kluson tuners suck. I think their quality control may be much higher now, though I wouldn't know because I refuse to buy them ever again.
  6. korus
    korus Senior Member
    995
    304
    Apr 10, 2007
    Use wooden dowel for furniture to hammer bushings out from the back of the headstock, several mild hits till it moves/separates from the front of the headstock, to avoid damage.
