CAN MINI HUMBUCKERS BE MOUNTED IN A 2015 LES PAUL DOUBLE CUT?
Discussion in 'Luthier's Corner' started by Woman Tone Man, Dec 9, 2018.
  1. Woman Tone Man
    Woman Tone Man Senior Member
    105
    8
    Mar 13, 2012
    I want to install a pair of Seymour Duncan mini humbuckers which have 3-48 nuts soldered to the lugs I think due to them originally not being factory threaded?
    Does the 2015 Les Paul Double Cutaways have mounting plates in the pickup cavities that accept both P90's and mini-humbuckers? What would I need to do with the pickups if they have nuts soldered to what appears to be non threaded lugs to mount them in my 2015 Les Paul Double Cut?
    I also want to install a push/push pot for coil tapping options. Should I go with a 250K or 500K pot? Would there by anything else I need to consider as in values of tone capacitors and how are they mounted in a
    Thank you! :dunno:
  2. slug_maine
    slug_maine Senior Member
    1,559
    3,460
    Dec 11, 2012
    Not sure if I understand what you're asking, but the Gibson minis have a screw (longer) with soldered nuts.
  3. Bobby Mahogany
    Bobby Mahogany Senior Member
    21,297
    31,443
    Feb 25, 2012
    You must be aware that there's gonna be a world of difference in tone and output
    between the Neck and Bridge pickups.
    Just sayin'.
  4. Woman Tone Man
    105
    8
    Mar 13, 2012
    Kind of like the Seymour Duncan JB and Jazz combination?
  5. Bobby Mahogany
    21,297
    31,443
    Feb 25, 2012
    The JB is an Alnico 5, not a Ceramic.
    But anyway, unless you install them you won't know how that guitar sounds with those pickups, right?
    :D
