Can I darken my fingerboard?
Discussion in 'Epiphone Les Pauls' started by vindibona1, Jun 7, 2014.
  1. vindibona1
    vindibona1 Member
    88
    51
    May 7, 2014
    Below are pictures of my newly acquired (just today)LP (red one on the left) and my old one that I traded in (brown burst on the right).
    I like everything about the new one except the color of the fingerboard. I think it is too light and the guitar could really use some contrast.
    Is there as (good) way I can darken my fingerboard on the new guitar to get closer to the old fingerboard?
    Thanks in advance.
  2. LowThudd
    LowThudd Senior Member
    2,221
    2,373
    Apr 26, 2014
    I use Dr. Ducks Ax wax on my rosewood. Works great at cleaning and conditioning. It will also darken rosewood. I'd give that(or similar) a try first. Rosewood is often dry on new guitars.
    2 people like this.
  3. MrKensei
    MrKensei Senior Member
    2,151
    1,830
    Nov 13, 2011
    If i have a fretboard that is too light i use black t-cut. As a cutting compound its great at polishing frets and the plack stained wax darkens the fretboard.
    1 person likes this.
  4. Spookytooth67
    Spookytooth67 Senior Member
    115
    72
    Mar 27, 2014
    I use Dunlop 65 after dressing the frets on my trad pro. It worked very well.
  5. Brians Evil Twin
    Brians Evil Twin Poophoria Sōtō Zen V.I.P. Member
    11,335
    28,181
    Apr 24, 2012
    If you want to stain it, you can use black dye, the type you can get at a shoe repair shop. Be careful with that stuff though, it permanently stains binding, nut, finish, your hands, the bench, the cat, anything that it comes in contact with. It's better to do if you're doing a complete restoration and you have everything removed and taped off.
    Otherwise, any fretboard conditioner will darken the wood. Personally, I've switched to this from lemon oil: Fingerboard Serum | FretFactor
  6. vindibona1
    vindibona1 Member
    88
    51
    May 7, 2014
    Thanks for the replies. Until now I have been using linseed oil for my fretboards. But all the options sound good. The only one I know I can get is the Dunlop 65. The fretboard serum sounds good because the photo from the link shows what the result I'm looking for. Never heard of Dr. Ducks axe wax or the black t-cut.
    Shoe dye sounds like a great idea, but I'm afraid it will stain the inlays and binding. If I was doing a restoration I would probably look into this. Thanks.
    Other than the Dunlop 65 where can I buy the other stuff? I'll probably take a drive down to where I know there are two guitar shops and a luthier within 10 minutes of each other. I opened the guitar last night and found mini pots. This thing needs a rewire ASAP. Hope to find some PIO caps locally.
    Thanks again everyone!
  7. Brians Evil Twin
    11,335
    28,181
    Apr 24, 2012
  8. Alty
    Alty Senior Member
    589
    501
    Oct 9, 2013
    We use Boiled Linseed Oil but a 50/50 mix with Turpentine on all our Acoustics and never looked better....at the end of the day though it's only a piece of dead wood, you can dye/stain it any colour you like, paint it if you want to or varnish it....you don't really need any special guitar juice, just a bit of research into wood and how to use/treat/care for it.
    T-Cut is a car product:
    T-Cut - Car Care Products
    So you'll have to look for your countries alternative name....
    I do like it when products are used for things outside of their intended use.
  9. LowThudd
    2,221
    2,373
    Apr 26, 2014
  10. jaysmall
    jaysmall Senior Member
    117
    87
    Jun 5, 2013
    Mineral oil, pure as you can find from your local pharmacy. It's inexpensive and a bottle will last years.
    When you take off old strings for a change, just wipe a bit on the board using a clean cotton rag. Let sit a few minutes, then wipe off excess. Over time, the board darkens. Good for the fretboard wood and relatively inert vs. other surfaces/finishes on the guitar.
    Mineral oil is also a base ingredient in a lot of string conditioners (Fast Fret etc.).
  11. rabidhamster
    rabidhamster Senior Member
    6,202
    6,093
    Jun 4, 2008
    You could rub it with Brazilian rosewood oil. It's surprisingly easy to find
    You can also wipe the oil from your brow and nose after a hard days work and rub it in - that'll darken up quick.
  12. kysrsoze
    kysrsoze Senior Member
    1,392
    475
    Nov 19, 2008
    I'll echo Dunlop 65 lemon oil works very well on Rosewood and Baked Maple. Nice and dark, and it seems to last a long time.
  13. edselman
    edselman Senior Member
    1,241
    679
    Mar 19, 2010
    I have been a woodworker for many years, primarily building custom flintlock rifles. Wood contains no oil and to add oil, especially an oil that does not harden or dry can have negative results. I have seen gunstocks that were turned almost to pulp by applying non-drying oil excessively and repeatedly. Raw linseed oil and lemon oil are two offenders. If either of these is used only on occasion and wiped off immediately to clean and lubricate the board, then there is no harm. But allowing these oils to soak in repeatedly is not so good. Drying oils like boiled linseed oil acts as a varnish. If used repeatedly, you will end up with a varnished fretboard. My practice is to use lemon oil very sparingly. Actually, lighter fluid is a better cleaner, followed by a very small amount of oil.
    One thing I see for sale is bore oil to be applied to the bore of a clarinet that is made of Grenadilla wood. I used to play the clarinet and picked up a nice vintage one made of wood. I spoke to a repair tech about getting some bore oil. He said that he could never recommend oiling a fine clarinet and that the instrument could be damaged.
    As far as using a stain on the board, it is a huge crap shoot as it may stain everything else too, especially your inlays. A friend used stain on his fretboard. It looked great until he used lemon oil on the fretboard a few months later. The oil softened the stain and it dyed the inlays and fingertips.
    Anyway, this is just a thought. Please take it with a grain of salt (whatever that means).
  14. RavenMadd
    RavenMadd Senior Member
    1,005
    220
    Mar 21, 2010
    I used minwax stain marker ...ebony ...when all else failed.....have tissue paper by you ....let it dry then wipe off excess......might take 4 coats......look on youtube someone has a video on this subject.....my epi standard had same problem
  15. edselman
    1,241
    679
    Mar 19, 2010
  16. vindibona1
    vindibona1 Member
    88
    51
    May 7, 2014
    I've got good news and bad news...
    The good: I used linseed oil and it darkened the fretboard sufficiently.
    The bad: When I took the strings off to clean/oil the fretboard I noticed significant fret wear. As beautiful as it is I'm going to return it today :(. It doesn't make sense to pay for a fret job and have to put pickups in it.
    Thanks for the advice. Wish I had better news.
  17. Colquhoun
    Colquhoun Senior Member
    308
    279
    Nov 22, 2012
    Check out fingerboard dye from Stew Mac:
    STEWMAC.COM - Black Fingerboard Stain
    Good reviews for this product. NOTE: it seems the product that is sold is actually Fiebings leather dye. If you can find it local or cheaper, go for it.
    Read the reviews for tips on the pluses and minuses of using dye.
    That said, since leather dyes come in many shades, if black isn't what you are after, a dark brown leather dye might be a better match for what you are trying to accomplish.
  18. ben.jammin
    ben.jammin Senior Member
    1,118
    696
    Jan 21, 2014
    Sorry to hear about the fret wear! Hopefully you're able to get your old guitar back and enjoy it until you find something else you like.
    Just in case you need to darken a fretboard in the future, I agree with the post above that says Dunlop 65 works very well.
  19. Curmudgeon
    Curmudgeon Senior Member
    2,273
    2,342
    Jun 24, 2013
    I once saw a youtube guitar care vid by a guy who works for Martin. He recommended 3-in-1 oil. I can't imagine................:wow:
  20. Alty
    Alty Senior Member
    589
    501
    Oct 9, 2013
    I've seen and read about all sorts of oil being used....Olive, Walnut amongst the many and 3-in-1 is Mineral based with a 'cleaning' agent (Citronella) and a 'corrosion inhibitor' so no reason it wouldn't work really but to each his own.
