Can anybody explain suspended chords to me?
Discussion in 'Guitar Lessons' started by NewDayHappy, Nov 30, 2017.
  1. NewDayHappy
    NewDayHappy Senior Member
    1,838
    2,815
    Dec 18, 2016
    I have a very good understanding of minor chords, major chords and power chords but lately I've had the desire to start dressing up my chords and taking my learning further. I found a chord in a song I like, it was a B9sus2 and it just had a really beautiful sound that I liked and wanted to implement in my own songs. Can anybody tell me how to write songs with more suspended chords or just cool chords in general?
    Yofresh likes this.
  2. jeff_farkas
    jeff_farkas Senior Member
    32,850
    21,240
    Nov 1, 2008
  3. jeff_farkas
    32,850
    21,240
    Nov 1, 2008
    I know it's not perfect but it's a good start and that was a good question.
    NewDayHappy likes this.
  4. NewDayHappy
    1,838
    2,815
    Dec 18, 2016
    That was very helpful! Now I know how to make suspended chords up from scratch. Any idea on how to implement them in a progression?
    jeff_farkas likes this.
  5. jeff_farkas
    32,850
    21,240
    Nov 1, 2008
    No.. that's all I got for now. I'm just learning and that video is a big help for me.
  6. frankv
    frankv Have You Ever Lost A Love? V.I.P. Member
    14,553
    13,001
    Aug 25, 2011
    Just use your ears. Forget theory
    Sct13 and NewDayHappy like this.
  7. Sct13
    Sct13 Premium Member
    17,467
    20,828
    Sep 18, 2011
    Ears ....is right....
    Hint:
    Suspended means hanging
  8. Thumpalumpacus
    Thumpalumpacus Senior Member
    76,014
    186,249
    Nov 28, 2010
    Suspended chords are great for setting up tension in a progression. If you want to get a good resolution, put a sus chord in the last beat prior to the resolving chord or cadence. If you want the listener to be unsettled, resolve to a sus chord.
    The thing is that because they are neither major nor minor, the listener is kept on edge -- and that is the feeling you're wanting to use when writing something.
    Pete Townshend, Alex Lifeson, and Andy Summers (amogst others) have built careers on using sus chords to balance between major and minor chords, setting up tension for release, or, in the case of Summers, resolving to a sus chord and leaving the listener wanting more.
    I generally use them as passing chords (very easy, either hammer on the fourth, or lift a finger for the sus2) to impart motion to an otherwise-static chord progression. I rarely stay on them, myself -- in that sense, the sus part of it is almost melodic grace-notes rather than a chord I'll sit on. If you do sit on them, do so understanding that that passage will impart irresolution that wants to be cleared up.
    parts, jeff_farkas, frankv and 2 others like this.
  9. huw
    huw V.I.P. Member
    3,534
    4,759
    Jul 13, 2007
    Well, the short answer is (as always) that you can use them anywhere that you like the sound. As frankv says "...use your ears - forget theory..."
    However, it might help to see a couple of standard "traditional" uses to help you recognise the sound in a progression. Then, because you know the sound, you really can forget the theory.
    Classic (and "classical") use: elaborating an A > E chord change with an Esus4
    A major = A C# E
    E major = E G# B
    So when the chord changes A > E three things are happening:
    A falls to G#
    C# falls to B
    E stays the same
    Ok? Two notes move, one stays the same. Now to stretch that out & make more of the change, we could have the two different changes happen one at a time instead of together.
    So lets do the C# > B move first, then the A > G# move. (This will introduce a third chord, between A & E)
    So, starting with A major
    A = A C# E
    move C# to B = A B E (mystery middle chord)
    move A to G# = G# B E (which we can rearrange to E G# B, our E major chord)
    Now let's identify that mystery chord in the middle:
    A B E can be rearranged to E A B which, following the description in that video, you should be able to see is Esus4.
    The "suspended" name comes from the fact that the note A (the 4th up from the root of the target chord, E, is literally suspended - or held over - from the previous chord.
    You can hear that exact change as the intro & verse of "I'm A Boy" by The Who.
    The process works the other way around too. We could pull that same trick (move one note at a time instead of both together) when going from E > A:
    E major = E G# B
    raise the G# to A = E A B
    raise the B to C# = E A C# = A C# E = A major.
    There's one difference this time - strictly speaking that middle chord would now be called an Asus2, because this time it's the B that is suspended from the previous chord (& B is the 2nd from the root of the target A major).
    However, in practice Esus4 & Asus2 contain the same notes and you could see it written either way.
    Ok, so much for the classical history lesson, where else can you put one in a progression?
    Well, another classic use is, as Thump said, to add a bit of life to a static chord.
    Think of the intro to Crazy Little Thing Called Love by Queen. Would four bars just on a D major have been as effective as that D > Dsus4 > D figure?
    There must be hundreds of other examples - The Beatles, The Who, Tom Petty, The Byrds etc etc all have songs where the main riffs are just using sus4's and/or sus2's to decorate an otherwise static chord.
    Due to the way the guitar is tuned, and the fingering shapes that we get as a result, the keys of D & A are particularly rich for this sort of thing!
    Both of those types of use resolve the suspension - ie the Esus4 does fall to E major etc, but leaving a sus chord unresolved can make a particularly powerful effect as well. Think of the opening of Rush's Hemispheres, or Coldplay's Politik. In both cases the tension & energy is created by unresolved suspensions.
    So really you can put them wherever you want, but you might find you get a better grip on the sound by looking at the more traditional uses first.
  10. NewDayHappy
    1,838
    2,815
    Dec 18, 2016
    Thank you so much all of you, I wish I had more detailed questions but this is a lot to take in, I keep going back to this thread for a point of reference. Appreciate the detailed responses, the information here will be enough for me to ponder for a few weeks. Thanks for your time guys. :)
    huw and Thumpalumpacus like this.
  11. NewDayHappy
    1,838
    2,815
    Dec 18, 2016
    It's amazing how many chords you can make by just moving one finger. I came up with 4 chords by moving the pinky around while playing an open C major. Cmajor7, Csus2 and Csus4. I'm really starting to understand how to use the suspended chords, they sound great with majors and minors. Sus chords with major chords sound like something you'd hear in a church. Sus chords paired with minor chords sound more like rock n roll to me, although I'm sure sus with major chords has been done in rock countless times, maybe it was because I was playing D major/Dsus4/A major/Asus4. Sounds great but not what I'm going for, very churchy but great practice.
  12. Thumpalumpacus
    76,014
    186,249
    Nov 28, 2010
    They're useful for leading tones.
    Another guy you want to listen to if you want to hear sus chords used in context is Ty Tabor. He's really good at setting up tension and resolution.
    huw and NewDayHappy like this.
  13. Yofresh
    Yofresh Junior Member
    27
    23
    Oct 12, 2017
    Hey! Good job on learning those sus chords :)
    I'd like to enlighten you a little in how to implement sus chords in a progression. Maybe you know that in the key of C major, these chords are "normal/standard":
    C - Dm - Em - F - G - Am - Bdim
    following the "rules" (rules are for breaking ;) you can change them to:
    C: Csus2 or Csus4
    Dm: Dsus2 or Dsus4
    Em: only Esus4
    F: only Fsus2
    G: Gsus2 or Gsus4
    Am: Asus2 or Asus4
    Bdim: ... yeah this is a complicated story, let's for now NOT get into this :) *note: Bdim often is replaced by G/B. x20003
    I hope this helps :) This applies to every key, but then with different notes of course.
    Let me know if you have any further questions or when this helped you! Cheers, James
  14. NewDayHappy
    1,838
    2,815
    Dec 18, 2016
    This is why I love MLP! Thanks to all of you, thanks for your time.
    Thumpalumpacus and Yofresh like this.
  15. Thumpalumpacus
    76,014
    186,249
    Nov 28, 2010
    One of my favorite tricks with a VIIdim is to substitute it beat-by-beat with the min3 inversion (slide it up three frets, then another three frets, etc). The notes don't change; you're simply moving through inversions, but the act of sliding it up the neck builds tension begging to be resolved.
    You can also do this with a min7b5 in a minor key -- say, in Amin, substitute Bmin7b5 for the E(m)7 (the V7 in Amin), and then beat-by-beat slide it up to Dmin7b5, then Fmin7b5. So you get B-F-A-D, then D-Ab-C-F, then F-B-Eb-Db (if you root it on the fifth string.) As you can see, you get a lot of little half-step motion which is pretty unsettling, and again sets up a strong resolution.
    HogmanA likes this.
  16. HogmanA
    HogmanA Senior Member
    973
    665
    Jan 2, 2009
    Coincidentaly, this is one of my favourite things too, and as I'm sure you know, you can tonicize anything with vii or half diminished and using the slide 3 frets technique is a great way to create movement and strong resolution, and you don't even need to slide 3 frets - you can 'jump' a few positions.
    I use it often to get to a different position on the neck - it's easy to get anywhere from anywhere and keep it sounding natural. I do it with dom 7ths too (whether dominant or not) - obviously, works the same as vii, just how I think about it.
    Thumpalumpacus likes this.
  17. Thumpalumpacus
    76,014
    186,249
    Nov 28, 2010
    Yeah, using a fragment of a dom7 and moving it around is cool. I think it's because all of the chords we're discussing right now have a tritone in them?
  18. JonR
    JonR Senior Member
    2,889
    2,572
    Sep 29, 2010
    I suspect what you're getting by moving that pinky around is C7, Cadd9 and Csus4.
    x-3-2-3-1-0 = C7 (not Cmaj7)
    x-3-2-0-3-0, or x-3-2-0-3-3 = Cadd9 (not Csus2)
    x-3-3-0-1-x, or x-3-3-0-1-1 = Csus4
    More:
    x-3-3-0-1-0 = Cadd4
    x-3-2-0-0-0 or x-3-2-0-0-3 = Cmaj7
    x-3-2-4-3-x, or x-3-2-4-3-0 = Cmaj9
    x-3-2-3-3-3 = C9
    x-3-2-3-4-x or x-3-2-3-4-3 = C7#9
    x-3-2-3-2-x or x-3-2-3-2-0 = C7b9
    x-3-3-3-1-1 = c7sus4
    x-3-3-3-3-3 = C9sus4
  19. NewDayHappy
    1,838
    2,815
    Dec 18, 2016
    Some of those I was not aware of so I'll save them for later use! Thank you!
  20. JonR
    JonR Senior Member
    2,889
    2,572
    Sep 29, 2010
    Well, sus chords don't have a tritone... ;)
    The tritone needs to resolve a particular way for the chord to have a dominant function.
    E.g., the tritone D-Ab needs to resolve to Eb-G, or C#-A.
    So if you have a Dm7b5 and it moves to Eb major or A major, then it's acting (essentially) as a rootless Bb9, or altered E7 (E7b9#5).
    If it's moving to G7, however - as it commonly would in C minor - it's a pre-dominant (or subdominant) not a dominant. The D-Ab tritone is resolving differently, to D-G.
    Dm7b5 could move directly to C or Cm - and in the latter the tritone does resolve to Eb-G (in the former it's E-G or C-G). But it's debatable whether that's a dominant function. I'd call it a "minor plagal cadence" - Dm7b5 = Fm6, minor iv chord of C.
    Even if you put a G on the bottom of the Dm7b5 (giving you G7sus4b9*), it's still not quite a dominant function, because the chord lacks the leading tone of C (B). It's a mix of dominant (G-D-F notes) and subdominant (F-Ab-C). Like going from F/G (G9sus4) to a C major. Great sound, but a mix of V and IV.
    This is all just about defining what's happening, of course. Not saying what you can and can't do! ;)
    * Yes, OK, this sus chord does have a tritone.... ;)
