Can a toggle switch be damaged by heat?
Discussion in 'Luthier's Corner' started by mentaldisorder3, Sep 14, 2017.
  1. mentaldisorder3
    mentaldisorder3 Junior Member
    11
    2
    Aug 28, 2017
    i had to remove a some wires from a switch, and in the end the thing was extremely hot. So hot that I had to let it cool down for about 10 minutes. I checked to make sure it was clean, and the mechanical switching seems to be fine. Since there isn't any electronics inside the switch, it should be fine right?
  2. 61LPSG
    61LPSG Senior Member
    1,685
    447
    Oct 31, 2007
    If it's a metal frame style like a Switchcraft it should be fine. You'd have to burn the phenolic insulators away to ruin it.
    If it's a plastic housing like some Asian cheapies, then you could have damage. Borrow a multimeter and test it.
    mentaldisorder3 and DarrellV like this.
