Can’t figure out the OHM switch on Ampeg?
Discussion in 'The Squawk Box' started by mrdannyboy, Oct 18, 2018.
  1. mrdannyboy
    mrdannyboy Senior Member
    723
    718
    Jan 19, 2014
    371C55A1-05A3-4D7D-8BD0-A97602199279.jpeg Hey guys I bought this head it’s the AMPEG reverbrocket re-issue In the pic I don’t know which ohm setting is on when it’s flat across like it is there on there on the 16 ohm setting. Anybody know how those particular ones work Would it be when the flat pieces across like it is on 16 right now or when right now on 8 ohm it’s all in infented. I can’t find information anywhere on the web on this.
    It’s going into a 212 cab wired at eight ohms. When I have it set so that flat piece is in front of the 16 ohm like it is now it’s louder than one that flat part of it is in front of the eight ohm if that helps at all. Don’t want to wreck anything so if anybody knows i’d really appreciate it Thanks
  2. ARandall
    ARandall Senior Member
    12,459
    8,063
    Apr 16, 2012
    Its only got 2 settings - so then the switch will have 2 settings. As 16 is on the left the switch will be on 16 when in the left posi too.
    mrdannyboy likes this.
  3. mrdannyboy
    723
    718
    Jan 19, 2014
    I just don’t know if I’m explaining it right
    See how right now there’s a flat part across the 16 and the eight is it’s a dig out area So what I’m trying to find out is whether the setting is on when the flat part is beside it ,like now on the 16 ohm. It literally doesn’t tell you in the manual
    The only thing that I can tell that might help is when the flat part is on 16 the cab is louder when the flat part is on 8 it’s lower volume
    Would I hurt anything bedroom levels if I have the wrong setting selected It’s just thrown me for a loop and everybody who I know who seen it who aren’t bands they’ve said I don’t know it could be either one I’m hoping on the guitar form that some people have this style of ohm switch
  4. ErictheRed
    ErictheRed Senior Member
    4,719
    5,487
    Dec 8, 2009
    In your picture, it's in the 16 ohm setting. You can verify that by measuring the resistance with a multimeter. All you have to do is stick a speaker cable in the amp output but don't connect it to a cab, and measure the resistance between the center conductor and outer conductor of the connector. Of course, the amp should be off.
  5. ARandall
    12,459
    8,063
    Apr 16, 2012
    Its a 2 position switch......you can literally only move it one direction from wherever its sitting now - surely its not so hard to put your hand on it and physically figure out the L and R directions???
    Rotorhead, lakeburst and mrdannyboy like this.
  6. mrdannyboy
    723
    718
    Jan 19, 2014
    I understand that man it’s not hard to switch or whatever I’m just trying to figure out which Way the switch needs to be on that particular ohm setting. I don’t know whether the One setting is selected one that Flat piece is beside it or whether it’s activated when the indented piece is beside it. That’s why I asked if I’m running an eight on carb and I put it on eight on what’s going to be loud or 1608 on because when I switch back-and-forth from whatever it is 8 to 16 or 16 to 8 there is a significant improvement or loudness in it So I’m trying to figure out whether it should be louder or less loud
    Like I said the manual doesn’t tell you whether it’s 16 ohms is selected one that flat pieces beside it or when the flat piece is away from it beside the 8 ohm I’m not sure whether you’re getting what I’m saying. Just trying to find out what activates eight and 16 ohms whether it’s the flat piece or the piece that is dug out piece. From the picture I posted what did you say what do you think is selected up there a ohm or 16 a ohm
  7. lakeburst
    lakeburst Senior Member
    546
    663
    Apr 17, 2016
  8. Cjsinla
    Cjsinla Senior Member
    3,707
    3,042
    Jul 7, 2014
    Slide it to the left for 16, slide it to the right for 8.
    mrdannyboy and northernguitarguy like this.
  9. Big John
    Big John bigger is better V.I.P. Member
    7,385
    6,850
    Mar 18, 2007
    Output volume changes happen all the time with head-cab ohm mismatches. Not a big deal, and I really wouldn't dwell on it too much. Just set it to the right for your 8 ohm cab and run with it.
  10. mrdannyboy
    723
    718
    Jan 19, 2014
    Tell me that seems logical I just where is the manual would say it because there’s so little of me on a room for error sorry information on the Internet about these amps. And they’re absolutely fantastic Thanks for the reply
  11. mrdannyboy
    723
    718
    Jan 19, 2014
    from the picture I have up there To get the flat plastic thing in front of that 8 ohm you push to the left so that stuff that’s in front of 16 home right now goes underneath and the 8 ohm is covered flush to get the flat plastic thing in front of that you push to the left. thanks for your reply. I think I’ll try it with the multimeter. Cheers
  12. mrdannyboy
    723
    718
    Jan 19, 2014
    This is the unit. It’s real solid. Great tones
    lakeburst and RAG7890 like this.
