Camel les Paul
Discussion in 'Other Single-Cuts' started by BKS, Nov 17, 2018.
  1. BKS
    BKS Senior Member
    982
    1,208
    Jul 8, 2018
    Went to other side of country to pick up this one. Not much to be found on the interweb on these. I have no idea what is original and what not. If anyone can tell me the function of the mini switch ....
    Could this be a CLP-60CS?
    Body is Mahogany type wood build in layers. Maple top. 3 piece neck i believe. There is a huge volume difference between both pickups . Plastic humbucker:shock:
    Nice playing guitar tho. Might gut it and maybe put my Onered paf in the bridge. Neck is weak only have a '61 neck and a Burstbucker Pro neck Pickup. Might op for a p94....?:hmm:
    Pictures DSC_4874.JPG DSC_4874.JPG DSC_4872.JPG DSC_4870.JPG DSC_4864.JPG DSC_4863.JPG DSC_4861.JPG DSC_4859.JPG DSC_4856.JPG DSC_4858.JPG DSC_4855.JPG DSC_4854.JPG DSC_4853.JPG DSC_4852.JPG DSC_4850.JPG DSC_4849.JPG DSC_4848.JPG
    endial, Bobby Mahogany and smk506 like this.
  2. therealfrogman
    therealfrogman ill Eagle Silver Supporter Premium Member
    195
    216
    Apr 1, 2018
    Gorgeous guitar. I will guess it is either a coil splitter or a phase changer that would change of the the pups to out of phase. I do not know enough about wiring to decipher the pics but if you simply play it one either pickup and switch it you will answer the question. You easily disable that micro switch as well and see if the volume between the pups changes.
    BKS likes this.
  3. BKS
    BKS Senior Member
    982
    1,208
    Jul 8, 2018
    No coilsplit i guess. It seems to be connected to the pot via a capacitor (the yellow one in the picture) there are also two green ones on the tonepots.
    But have to play a little more with it to. But i guess I clean it first and put a new fresh set of strings on.
    If anyone could put a date on it?
  4. Bobby Mahogany
    Bobby Mahogany Senior Member
    21,250
    31,305
    Feb 25, 2012
    Not a fan of the Clown burst but it looks like a nice guitar.
    And what a brand!
    The main thing here would be to make sure everything is lined up,
    that the scale is right, that the intonation can be spot on,
    all this before gutting it and putting value parts in it.
    Otherwise it's never gonna sound good.
    Nice find!
    :thumb:
    BKS likes this.
  5. mrdannyboy
    mrdannyboy Senior Member
    723
    718
    Jan 19, 2014
    Anyone know Japanese or whatever language it is
    endial, BKS and AK Epi Player like this.
  6. BKS
    BKS Senior Member
    982
    1,208
    Jul 8, 2018
    In real the contrast between both colors is more subtle . Actually pretty nice.
    The bridge sounds okayish, it is the very very big drop in volume between bridge and neck. I will play with it first as for me i am still learning. And I guess I can learn a lot from playing around with it first.
    Any idea what the role of the yellow cap could be?
    Never seen pickups like these....
    Wish there was more to find on these. The guy i bought it from also had a Fresher lp, he did not know they were family .
  7. endial
    endial Senior Member
    2,494
    2,367
    Oct 23, 2014
    That's just cool.
    BKS likes this.
  8. BadPenguin
    BadPenguin Senior Member
    893
    661
    Jun 13, 2015
    The switch with the cap could be a tone switch, which would make the pickup sound as if the tone pot was rolled down to zero. Kinda stupid in my opinion. OR it may be a coil tap, sending just one coil thru the cap, which would sound as if it was off. Again, on the stupid side of things. The best bet is that bridge pickup is a replacement, since that's where the switch is wired to.
    BKS likes this.
  9. Bobby Mahogany
    21,250
    31,305
    Feb 25, 2012
    As far as I'm concerned, I would lose the toggle switch and fill the hole.
    Put a '50s wiring harness with a pair of SD '59s and call it good to Rock!
    :D
    BKS likes this.
  10. Neffco
    Neffco Senior Member
    950
    1,326
    Sep 23, 2013
    That’s Smokin! Back when smells like smoke and covered in nicotine was a good thing. Nice find.
    BKS and endial like this.
  11. BKS
    BKS Senior Member
    982
    1,208
    Jul 8, 2018
    My idea, might put my OneRed paf (or Steffsen paf)in the bridge with neck still open for ideas.
    These are boutique handwound pickups from Europa btw (Dutch/belgium) and come out of a Brandin JA personal II.
    Both are bridge pickups but i might use one in the neck anyway? Both are paf with similar output if i remember correctly. But maybe that is overkill?
    Might also just put another combo in....
  12. Bobby Mahogany
    21,250
    31,305
    Feb 25, 2012
    If you have nice pickups to use, why not?
    BKS likes this.
