CA and Painters Tape Trick not working! (Solved!)
Discussion in 'Luthier's Corner' started by Luthi3rz, Jul 14, 2018 at 4:45 AM.
  1. Luthi3rz
    Luthi3rz Junior Member
    14
    4
    Jul 4, 2018
    Got a problem here guys.
    Every time I try and make double sided tape using Super Glue and
    that Blue painters Tape from Duck it doesn't work for me!
    I have tried thin, Medium, Thick and Gel.
    Like I said I am using that Blue Painter Tape Duck brand name.
    Is there some kind of trick to getting it to work I don't know about?
    Do you ABSOLUTELY have to use Accelerator?
    And how the hell do you press the tape down with out lifting it up cause
    the sticky side is up!!! :confused:
    I'm honestly irritated. Cause I know you guys use this trick all the time.
    I followed this video here.
  2. Colnago1
    Colnago1 Senior Member
    1,037
    943
    Sep 17, 2012
    The sticky sides face away from each other, you’re glueing the non sticky sides together. One piece of tape sticks to the beam, the other piece of tape sticks to the sandpaper. Then you glue the sandpaper to the beam.
    I’m not sure what you’re having a hard time with.
  3. warprider
    warprider Senior Member
    208
    170
    Jan 31, 2011
    Sorry I couldn't be assed to sit through that video.
    Is it a levelling beam? Why not use spray adhesive?
  4. drmmrr55
    drmmrr55 Member
    97
    155
    Jan 18, 2017
    Put the tape on the beam like normal, sticky side down. THEN, put glue on top of the tape, sorta like homemade double sided tape. Then just apply sandpaper to the glue. Viola! That video needs to get to the point instead of all that yammering. apologies to the guy who made the vid...
  5. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    Have you tried double sided tape? Seems a lot easier...
    LtDave32, marksoundguitars and Greco like this.
  6. Freddy G
    Freddy G V.I.P. Member
    10,818
    21,853
    Mar 18, 2007
    seems so.....but it's not. By the time it takes me to lift up a corner of the backing on double sided tape (some are easier than others) I can lay down two strips of masking tape, a few drops of glue and hey presto...
    Seriously....it's a lot faster for me. And the added bonus is that when I go to pull it apart it's easy. Double sided tape can be tenacious as hell....sometimes pulling wood fibres....
  7. LtDave32
    LtDave32 Sua Sponte Super Mod Premium Member
    28,439
    82,995
    Mar 19, 2010
    Guys, I've had great success with Duck brand double-sided tape.
    The film picks up easily off a corner, and it sticks great. But best of all, it comes off when you're done.
    If one uses that double-sided "carpet tape" with the strong fibers running through it, it's a total bear to deal with. Not so with Duck brand double-sided.
    Ps, squirt some naptha/lighter fluid on and around the edges of the tape when you're done. Comes right off.
    I use a flat piece of wood with a good file for a fret leveler, secured with Duck brand DS tape. Every damn time.
    w666 likes this.
  8. Luthi3rz
    14
    4
    Jul 4, 2018
    Ok guys I got it sorted out.
    In the Interest of helping people. Read below.
    Out of five different kinds of tape I have, only this one worked.
    3m Scotch brand general purpose #2020
    The 4 others that didn't work for me.
    IPG brown Packaging Tape = Failed
    3m Scotch Brand #2050 White Painters Tape = Failed
    3m Scotch Brand #233+ Green = Failed
    Duck Brand Blue Painters Tape #13932/2002 = Failed
    So it turns out that the cheapest, general, thin, stickiest tape you can get
    from like Lowe's or Home Depot with any old Super Glue works great at
    making double sided tape.
    :thumb:
  9. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    I use WOW Tape brand double side tape...I get it from a machinist's supply shop (http://www.actioncnc.com/wowtape.htm). Like Dave says above, easy to peel, sticks great, easy to remove. The skill is in knowing how much tape to use so that the work is secure, but is easily removed. There are lots of double sided tapes on the market, the vast majority of which are unsuited for wordwork. Try this tape, you'll like it!
    Luthi3rz likes this.
  10. Luthi3rz
    14
    4
    Jul 4, 2018
    Thanks. I'll check it out.
  11. cmjohnson
    cmjohnson Senior Member
    1,566
    1,034
    Dec 13, 2012
    Viola? I thought we're making guitars!
    Maybe you meant "Voila", which is a French word that loosely translates as "Taa-daa!" or "There ya go!".
  12. Skyjerk
    5,724
    6,582
    Feb 9, 2014
    I'm confused by the statement "making double sided tape"
    The trick for is not making double sided tape.
    You just use masking tape a CA to stick templates on.
    I'm not sure I understand how this could fail to work. You stick one piece of tape on the wood, stick another piece on the template opposing the first piece. Rub them down real good so they are well stuck. Put a thin line of CA on one piece of tape and press the template firmly on the workpiece.
    Let it set for a few minutes. Done
    It literally works every time regardless of what kind of Masking tape or CA I use, but I prefer slightly thicker CA.
    When you say "making double sided" tape I'm envisioning you trying to glue two pieces of tape together, and then trying to use it like double sided tape.
  13. drmmrr55
    drmmrr55 Member
    97
    155
    Jan 18, 2017
    Yeah, spelling was not my strong suit I guess, all my years, I always read it as "viola".....LOL
  14. Luthi3rz
    14
    4
    Jul 4, 2018
    That's correct.
    I get what you are saying and I now see why it wasn't working for me. Thanks for pointing that out.
