Bumblebee question
Discussion in 'Tonefreaks' started by 5F6-A, Aug 16, 2017.
  1. 5F6-A
    5F6-A Senior Member
    9,464
    2,016
    Aug 16, 2007
    I have found some old Sprague caps
    Is this 1200 pF? Cannot read the bands too well... I'm thinking of using it in an Eldred mod Esquire for the forward position...
  2. Kris Ford
    Kris Ford Senior Member
    4,754
    4,035
    Dec 17, 2011
    I'd read the capacitance with a quality multimeter..god knows what it reads now...
  3. judson
    judson Senior Member
    2,762
    2,690
    Jan 26, 2016
    you know i was just going to ask how do you know if it is working as it should or what is expected due to age....so what number to you think it should be, will be, or is acceptable for something like the above?
  4. 5F6-A
    5F6-A Senior Member
    9,464
    2,016
    Aug 16, 2007
    My multimeter can't read capacitance.
    1000 pF to 3000 pF should be okay.
  5. C.J.
    C.J. Senior Member
    174
    88
    Dec 28, 2015
    I don't believe you need a special capacitance setting on you multimeter to measure a cap/evaluate if its any good. Any setting above 1m ohms should give you a read from zero to ~
    If you don't have a capacitance setting on your multimeter - strongly recommend stumping up for a quality multimeter. You don't need to pay $100 but the $20 generally blow for features. Cheap ones are always a false economy in the long run, I find. As the proud owner of a box full of the things .. :)
    5F6-A likes this.
  6. cooljuk
    14,102
    17,994
    Mar 12, 2009
    The bands show specs as:
    .0012uF, 10% tolerance, 400V
    BUT, that is not likely the case at all. VERY few Bumblebees floating around in the market read anywhere NEAR the stated capacitance and I would not trust them with anything other than low signal voltages, either. If you see those in an amp, don't even turn it on.
    The only way to know the capacitance of a Bumblebee is to meter it. Then, after some time, or under a different temperature, it could have changed again, anyway.
  7. el84ster
    el84ster Senior Member
    115
    53
    Jan 25, 2014
    I can vouch for that. I've tested dozens of these, and they're mostly higher capacitance now, usually way higher. Also usually the dialectic has broken down and these pass DC now in most cases. That makes no difference in a guitar (since that's AC) but in an amp, passing DC through the caps is a big problem.
  8. el84ster
    115
    53
    Jan 25, 2014
    BTW, caps sound different depending in which way you orient them in the circuit, try it both ways.
  9. bulletproof
    10,921
    25,067
    Jun 1, 2011
    Yaaaa,thats not entirely true,brother.....lots of goofy info out there.
  10. geddy
    geddy Senior Member
    650
    586
    Dec 30, 2012
    If a capacitor is passing dc it's not a capacitor. And you don't have a tone circuit.
    Of course the voltage across it is relevant to my state ment
  11. Brutus
    Brutus Senior Member
    575
    577
    Jun 22, 2010
    Actually brother it is true. Sometimes. I alligator clip in the cap to see if it sounds better in one direction than the other way. Then I use the clip as a heat sink and solder that cap in place. Sometimes there is a distinct audible difference, other times not so much. The older caps most always sound better one way than the other. If you do your own work give it a try sometime.
    SemperFi!
    bulletproof likes this.
  12. bulletproof
    10,921
    25,067
    Jun 1, 2011
    Ya know,I sure will,man. Ive heard this many times before,just never experimented for myself. HOOAH!!
    Brutus likes this.
  13. ashbass
    ashbass V.I.P. Member
    657
    484
    May 3, 2007
    Old bumblebees are dead. If you need them, get LUXE repros. Got the look, got the sound, got you covered.
  14. el84ster
    115
    53
    Jan 25, 2014
    They definitely aren't dead for ac signal (guitar) use, just ask any of us using them!. And man, I wish it were true, but nothing really sounds like the old bees.
  15. cooljuk
    14,102
    17,994
    Mar 12, 2009
    I can see Ashbass's point.
    Nearly all of the ones out there in the market have drifted off into oblivion and probably have been bought/tested/discarded already. It's not like someone can just go on eBay and buy a set of two .022uF / 400v / 20% original Sprague Bumblebees for their guitar and expect them to be anywhere near in spec. Not unless the seller guarantees their real-world-metered-value and there's a reason that pretty much no sellers do that.
    How often have you seen "guaranteed working" or "tested in a guitar circuit" or "I don't have a meter to test these so sold as-is" in a FS listing of Bumblebees? All of those quotes may as well mean "marked on the case as .022uF 60+ years ago but actually reads 1MFD and not suitable for your intentions."
    Wish I could say the Luxe Bumblebee caps sounded and looked the same as the originals but I don't find either to be true, in person, unfortunately. I do like their other wax paper and NOS ceramic caps.
