Built-In Attenuators Vs External Attenuators
Discussion in 'The Squawk Box' started by MichaelAndrew3435, Aug 8, 2018.
  1. MichaelAndrew3435
    MichaelAndrew3435 Premium Member
    2,746
    2,121
    Aug 23, 2013
    What are your thoughts and opinions on the two? I have a fancy load box (UAD OX) I use mostly for silent practice, but I don't really use it to attenuate any of my amps. I've tried using it with my amps at full power and it sounds okay (could probably use proper/better tweaking), but I prefer built-in attenuation and consider it a must for all my current and future amps.
    I don't know much about the technologies used in either or, but I imagine a built-in unit is designed to work with the amplifier vs an external unit. Not all forms of attenuation are created equal of course. I've always been curious about power scaling:hmm:
    bulletproof and cherrysunburst00 like this.
  2. RAG7890
    RAG7890 Premium Member
    14,904
    23,835
    Jul 11, 2010
    ...............after an intensive weekend with lots of noise & a BE100 I'm getting a Volume Pedal.
    All the rest are a waste of time & money IMHO...............unless you want to hook up Cans.
    :cheers2:
  3. jw3571
    jw3571 Senior Member
    874
    226
    Aug 14, 2011
    How do volume pedals work? Do you crank the amp and then turn the volume pedal down, or how does it work?
  4. northernguitarguy
    northernguitarguy SWeAT hOg
    29,170
    49,099
    Feb 22, 2009
    Basically a volume pot in a pedal.
  5. cherrysunburst00
    cherrysunburst00 Senior Member
    14,386
    26,139
    Mar 15, 2015
    My .02 (and probably worth less) is that the best attenuation is incorporated into the design of the amp by the builder. @V2 really turned me on to this idea.
    Carr's attenuation on the Mercury is just WICKED.
    V2 also taught me about power scaling and dialing back the volume when increasing the amount of power scaling. My Reeves HG10 delivers superb ultra-low volume as does @bulletproof 's Phaez SIBLY Green Meanie
    Classicplayer and bulletproof like this.
  6. dspelman
    dspelman Senior Member
    10,098
    6,142
    Apr 30, 2009
    Personal opinion: The built-in attenuators probably aren't as good as the externals (depending on the external, of course).
    I understand that you would think that specificity would benefit the built-in unit, but I think that most are done on the cheap to have a bullet point in the marketing sheets.
    cherrysunburst00 and bulletproof like this.
  7. Cjsinla
    Cjsinla Senior Member
    3,638
    2,922
    Jul 7, 2014
    Volume pedal? You might as well turn down at the guitar, it’s the same technology. After using several brands of attenuators and amps with power scaling I’ve decided that a good master volume knob works best for me. I’ve also given up on expecting that one single amp will sound good in all situations. My needs may be different than yours, I can make as much noise as I want at home and other places and I never record. So, I have amps of all sizes, they call it GAS for a reason. I have certain amps for practice and other amps for gigging, it depends on my mood or what type of music I’m playing. Just my opinion......
  8. RAG7890
    14,904
    23,835
    Jul 11, 2010
    You must be a pretty awesome player if you can use your Volume Pot WHILE you’re playing. ;)
    The Volume Pedal works better for some Amps than others but cranking the BE100 & trimming the Volume with the Pedal is definitely better than using a Guitar’s Volume Pot.........which I do all the time because I hardly use Pedals.
    I’m going to buy a Lehle & run that. That’s not the only option. You can use the Level on your Send Return or MV etc.
    https://lehle.com/PL/Lehle-Mono-Volume
    :cheers2:
  9. Cjsinla
    3,638
    2,922
    Jul 7, 2014
    Yes, totally awesome :dude: The real reason I don’t use a volume pedal is that I can’t really rely on my foot to work well enough to set the pedal in the right spot and leave it there.
    That Lehle pedal looks like futuristic technology,you’ll have to let us know how that works.
  10. bgh
    bgh Senior Member
    313
    300
    Oct 23, 2016
    I have never played through an amp with a built in attenuator. I have seen a Peavey Windsor combo (years ago) but did not get a chance to try it. For attenuation, I use a Weber. But I prefer re-amping with my Power Station.
    I used to use volume pedals to control the volume going into my amp. But, I had a lot of trouble not so much in getting the right volume, but in keeping it there. I know this sounds kind of weird, but when ever I would pick up my foot, it would change the volume a bit. And, when I put my foot back on it (getting ready to change it again), more often than not it would change it.
    I had (and still have) issues getting my feet to the same angle as the pedal. For example, I set the volume where I want it, and the pedal is at a 37 degree angle. When I put my foot back down on it, I have to match that same 37 degrees, or I am going to change the volume a bit. I had real trouble doing that. Especially when it was semi-dark and I could not see a black pedal too well.
    Now, I use it either full on/off or volume swells.
    Anybody else have an issue like this?
  11. bulletproof
    11,763
    28,532
    Jun 1, 2011
    Man,as I get older, I have become quite the knob fiddler!:laugh2: (That just sounds funny as hell)
    Anyhow, I love the Power Scaling in my Phaez SIBLY,just as much as I love my volume pedal.
    Each has its own strengths and weaknesses. I’m actually looking at the OX as I do intend to acquire a Friedman BE Deluxe and a Dirty Shirley (not to mention the Germino Classic45,I am hopelessly addicted lol).
    If I am just straight out playing,I use the vol/tone controls,I like that. However,if I am playing clean....and I am talking bare-baby-ass-squeaky, I like that volume pedal....I love to leave the guitar volume wide open and turn down with the pedal. I learned this trick aways back from one of the ole boys on here. Just seems to make the tone fatter....
    I personally don’t think one way is better than another....it’s all in what we like to hear and what we are trying to accomplish.
    With all this gear and stuff right now,man,what a great time to be alive!!!!:dude::cheers2::dude:
  12. Stuff
    Stuff Senior Member
    662
    646
    Jul 28, 2013
    The OX is about as good as it gets for external attenuators. Maybe the Fryette Power Station 2 is the best alternative, because it has its own power tubes to offset the tone suck?
  13. bulletproof
    11,763
    28,532
    Jun 1, 2011
    Looking at the Fryette gear as well....nothing but good stuff out there,man!
    cherrysunburst00 likes this.
  14. jam81
    jam81 Member
    91
    141
    Mar 23, 2018
    I have the UA OX and it is worth every penny. Perfect for silent recording and to attenuate a tube amp without tone loss.
  15. northernguitarguy
    29,170
    49,099
    Feb 22, 2009
    Bad Cat Unleash user here. Works well for attenuation, but I’ve mostly used it for reamping. Doesn’t do much for a clean amp, but I can get my Tiny Terror sounding better for private practice with it. Nothing I’d call ‘bedroom levels’.
  16. RAG7890
    14,904
    23,835
    Jul 11, 2010
    I have not used the OX as yet but a close friend has been testing one extensively for the last month.
    We have the same ear & tastes in music / tone.
    He said the OX, as an attenuator is a tone sucker.............& a big pass.
    He also said using Cans with the OX was like using a Cab right under your nose..........& awesome.
    :cheers2:
  17. RAG7890
    14,904
    23,835
    Jul 11, 2010
    Fat is an understatement John. It sounded awesome.
    Bottom RHC of the Board...........2nd Pedal from the right. It is a Dunlop Volume Pedal.
    The BE100 is hooked up to an older rear loaded Bogner Uberschall Cab & the Board is running through the Loop.
    Cheers, Rudi
  18. RAG7890
    14,904
    23,835
    Jul 11, 2010
    Well, I just learned something & now I now why the Volume Pedal sounds better than turning down the Volume Pot on my Guitar.
    It is actually not the same thing because in this case the Volume Pedal sits between the Preamp & the Power Amp.
    The Volume Pot on your Guitar doesn't..............obviously.
    You need to use a good Volume Pedal in to a good Loop not the front end of the Amp.
    :cheers2:
  19. RAG7890
    14,904
    23,835
    Jul 11, 2010
    ............& the winner is?
    The OX.............for Cans & in to a Desk / Interface...............provided you have a great Amp.
    For attenuating, it sucks tone. A Torpedo Reload has aso been tested against these but it is not n the pic.
    Interesting to see the AxeFx III is a big improvement over the II, which many were obviously hoping for.
    :cheers2:
    P.S. Any modelling fans please note this is not a Amp vs. Modelling discussion. It is the result of today's testing & one person's opinion.
  20. MichaelAndrew3435
    2,746
    2,121
    Aug 23, 2013
    Agreed, it’s a great time to be an at home player. Especially in the amp world. There’s so many great low watt amp options and it keeps getting better.
