Build Thread - 61 SG
Discussion in 'Luthier's Corner' started by w666, Feb 14, 2010.
  1. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    Wow, it sure is infectious in here! I've been hanging around for a couple of months now. I first blundered on by while I was completing a kit build, and I just liked it here. So I thought I would contribute and post my kit build experience:
    http://www.mylespaul.com/forums/luthiers-corner/74264-my-gfs-kit.html
    And then I had "post partum" so to speak, so I began looking for another project. I enjoyed building my Les Paul, and I wanted to try again, but just did not have the confidence to take on a scratch LP build. So when George M started organizing his kit I jumped right in. And when it shows up it's going to become a 69 Deluxe (mini humbuckers) "clown burst".
    http://www.mylespaul.com/forums/luthiers-corner/60806-new-kit.html
    So I found myself rooting around the shop looking for stock that might somehow be suitable for some kind of build. I found some mahogany that started to look like a neck, and some rosewood that began to look suspiciously like a fret board.
    http://www.mylespaul.com/forums/luthiers-corner/75037-rosewood-fretboard-grain-direction.html
    Well, that turned out OK. So the next thing I know I'm at the exotic lumber dealer rooting through the cutoff bin for bits that look like a guitar. I can do this....it's easy! Just get some boards:
    And then cut away the parts that don't look like the guitar!
  2. EtriX
    EtriX Senior Member
    2,335
    197
    Dec 11, 2008
    Hey you can build something cool from that :D:laugh2:
  3. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    Now I should point out at this point that one of the driving themes throughout this build will be "thrift". First of all, I sent pretty much the remainder of my guitar budget to George, but also because this is my first scratch build, and I don't want to throw hundreds of dollars worth of lumber in the firewood pile if I screw it up.
    So the fretboard, frets, and binding were all "laying around" in shop, therefore "free". I spent ~$20 for MOP inlays.
    I found a nice piece of African mahogany ~ 5" x 1 + 3/4" x 56" for $20. This became a 3 piece body blank (and it looks OK, I don't mind saying). After I glued it up, I rigged up a router sled and made one side flat, and then flipped it over for a final thickness of 1 + 5/16"
  4. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    Yeah....maybe if I mix up some sawdust and glue I can pour it like a mold and get a nice body shape!
  5. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    Well that went well. Hardly any tear out. I'll bet curly maple won't be nearly as forgiving when I try that.
  6. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    I cut up one of my blueprints and glued (Elmer's spray adhesive) it to a piece of 1/4 MDF (because that's what I had laying around):
    I used a band saw to cut to the outside of the line, and then used a sanding drum to finish the edge right to the line, leaving a nice smooth edge for the bearing to follow.
    Now I had a template, which I used it to mark the rough outline of the body shape:
  7. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    I used the band saw to cut out the body shape, stay well away from the line (we'll clean that up late with the pattern bit):
    Note: Here's an amusing anecdote I'll share, because I'm sure that nothing like this has ever happened in your shop.
    Before I could use the band saw for this job, I had to change the blade from a 3/4 " x 4 tpi that I had been using for re-sawing to one more suitable for these curves. While doing so I noticed that the drive wheel was a little loose, so I got a wrench to pull it off and re-seat it. When the wheel came off the "key" flew away in some direction or another, and landed I know not where (since the floor in every direction was covered with saw dust, I didn't hear it land). I spent the next 2 hours crawling on my hands and knees with a hand broom and a magnet, sifting through the mess, but without success (although my floor is much cleaner now). I found an unused motor with a pulley (yep, just laying around), and so I scavenged the key from it, making a mental note to order some more from somewhere.
  8. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    Voila!
  9. PoorMan
    PoorMan Senior Member
    1,203
    33
    Jun 21, 2007
    Nice...where'd you get the blueprint?
  10. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
  11. PoorMan
    1,203
    33
    Jun 21, 2007
  12. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    Maybe it's this one then....
    gUitarREN: SG blueprint
  13. monsterwalley
    monsterwalley Senior Member
    2,421
    1,323
    Jan 31, 2009
    Cool, I've been wanting to do an SG build myself! :thumb:
    Those look like pretty detailed prints. Do they seem pretty accurate in
    your opinion?
  14. SG Lou
    SG Lou Senior Member
    2,677
    1,820
    Apr 3, 2009
    Lookin great bud ! :thumb:
  15. Ska_4th_Wave's_Coming
    Ska_4th_Wave's_Coming Member
    65
    1
    Jan 6, 2010
    Can't wait to see how it comes out! The suspense is killing me
  16. jonny
    jonny Senior Member
    979
    317
    Nov 29, 2009
    :dude:Yes! I love SG builds!
  17. crushmorgan
    crushmorgan Senior Member
    349
    1
    Apr 3, 2009
    This is gonna be good
  18. Drew224
    Drew224 "Obvious BS Artist" V.I.P. Member
    16,575
    7,768
    Oct 11, 2009
    Totally.
  19. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    I routed out the body shape using my template. I went slowly and carefully, taking small cuts in multiple passes:
    After a while I began to gain some confidence, so I was able to proceed at a faster pace. And of course that's when the dreaded tear out occurred:
    Should be easy to fix :)
  20. w666
    w666 Senior Member
    1,910
    450
    Nov 25, 2009
    I drilled undersized holes to locate the controls while the template was still stuck on. Later I'll re-drill them to the actual size.
