Broken neck or Finish Crack ?
Discussion in 'Gibson Les Pauls' started by lespaultobi, Mar 8, 2018.
  1. lespaultobi
    lespaultobi Member
    63
    117
    Jan 15, 2013
    Hi my Les paul fell from the "Security lock" and hit the floor . So is the neck broken ?
  2. PierM
    PierM Black & Gold Premium Member
    2,726
    3,997
    Aug 19, 2016
    Unfortunately looks like a wide headstock crack, that probably has some internal fracture in the grain.
    Do you have a similar crack on the other side?
    bulletproof likes this.
  3. gcbike
    gcbike Silver Supporter
    462
    563
    Mar 11, 2012
    yep it's a break
  4. bufbills
    bufbills Senior Member
    3,831
    2,026
    Feb 26, 2009
    break for sure. Very fixable though. Value will take a hit but guitar will play and sound like it did.
  5. Herr Dalbergia
    Herr Dalbergia Senior Member
    521
    289
    Nov 25, 2012
  6. Mockbel
    Mockbel Senior Member
    2,154
    1,799
    Nov 2, 2015
    Looks like a break yeah... sorry for that !
    As a "warning to others" message: What strap locks have you been using?
  7. lespaultobi
    lespaultobi Member
    63
    117
    Jan 15, 2013
    I always use Schaller. Hmm its a break okay... well i'll go and fix it by a Luthier. Thanks for replies
  8. northernguitarguy
    northernguitarguy SWeAT hOg
    27,352
    44,384
    Feb 22, 2009
    So sorry for OP! That can easily be fixed and will give you titebond tone!
    Schallers can't be trusted. Beer washers and a fat leather strap is the way to go.
  9. Mockbel
    2,154
    1,799
    Nov 2, 2015
    I have been always under the impression that Schallers are the best because of their design; even when the lock fails, it is still holds the guitar with the U shape carve.
    JamesD, GibsonKramer, yamariv and 2 others like this.
  10. northernguitarguy
    27,352
    44,384
    Feb 22, 2009
    Obviously not in this case. I've heard other horror stories. But not with Grolsch washers and a thick strap. My straps are actually a PITA to remove so I just leave them on all the time.
  11. AlanBiker
    AlanBiker Member
    52
    109
    Dec 8, 2017
    Schallers are fine when fitted correctly and checked for tightness every once in a while, they are not "fit and forget". You don't drive a car without sometimes looking at the tyres to make sure they aren't flat or bald, so like anything with moving parts they should be checked.
    Alan
    yamariv, Oldskoolrob and endial like this.
  12. northernguitarguy
    27,352
    44,384
    Feb 22, 2009
    For me, beer washers are fit and forget.
  13. JesseXGibson
    JesseXGibson Senior Member
    209
    332
    Aug 24, 2017
    +1 for a break. Sorry to see that man
  14. jc2000
    jc2000 Senior Member
    6,212
    2,973
    Jul 16, 2013
    OUCH!!! sorry to hear about that!
  15. Cjsinla
    Cjsinla Senior Member
    3,182
    2,269
    Jul 7, 2014
    I want to hear what your luthier finds. That is not where headstocks usually seem to break and the cracks usually follow the grain in a straight line. Did your guitar hit something on the way down that could have scratched it? If that crack was bad enough to go across the grain you would expect to see damage on both sides. Do you see any movement at the spot of the damage?
  16. PierM
    2,726
    3,997
    Aug 19, 2016
    Could be the neck still has proper structural proprieties, so you don't need (yet) to fix it. Check your relief now, and if you can tune it properly.
    If you see the crack opening while tuning, or while tweaking the neck relief, then you need a luthier asap. He will open that crack to inject the glue and clamp. Will be stronger than before.
  17. musicmaniac
    musicmaniac Senior Member
    6,465
    2,506
    Aug 11, 2012
    I always use a dab of locktite on my schallers. Even then you have to make sure they lock. Sometimes they're a bugger to snap on.
    Ooops and +1 on the break.
  18. bossaddict
    bossaddict @david.beason on IG Premium Member
    6,421
    8,239
    Apr 4, 2013
    Another vote for it being a legit crack. Sorry that happened.
  19. Thumpalumpacus
    Thumpalumpacus Senior Member
    74,919
    181,419
    Nov 28, 2010
    Bummer about your guitar. Get 'er fixed and play 'er loud, and yes, get strap-locks. I too use Grolsch, but have used Schallers before as well, they're fine so long as you lube the locking pin every so often.
    northernguitarguy likes this.
  20. scozz
    scozz Senior Member
    3,177
    3,517
    Sep 3, 2007
    Unusual area for a break...but it certainly appears to be a break. I’m feel for you @lespaultobi.
    I hate seeing cracked necks.
