Bridge height question
Discussion in 'Gibson Les Pauls' started by Nate Henderson, Nov 14, 2017.
  1. Nate Henderson
    Nate Henderson Member
    75
    26
    May 24, 2017
    My understanding is that the height of the bridge required to achieve a given string height is primarily determined by the neck angle. I've noticed that on some guitars I've looked at the bridge seems very high. Are ones that are too high problematic, and if so how high is too high?
  2. MSB
    MSB Senior Member
    2,314
    2,316
    Jan 21, 2015
    several factors play into it (neck relief is one), so it's not cut and dry.
    too high? that's fairly subjective and each player is going to have their preference
    Nate Henderson likes this.
  3. Nate Henderson
    75
    26
    May 24, 2017
    I know there's an element of subjectivity, I just wondered if needing it too high could indicate an actual problem like an improperly set neck, and if so how high that would be.
  4. grumphh
    grumphh Senior Member
    788
    478
    Oct 10, 2015
    Yes.
    No. Not as long as you don't run out of adjustment room.
  5. ARandall
    ARandall Senior Member
    12,293
    7,845
    Apr 16, 2012
    The neck being improperly set would be immediately noticeable - in that you would have gaps under the fretboard to the body. No QC would pass such an instrument.
    So if the fretboard is flush with the body then the neck is properly set for that guitar.
    So bridge height as a test for poor setup is no reliable metric - assuming you even found a single point where a person could say 'too high', if you applied that then not a single archtop would qualify. The ES Les Paul has a similar type of setup and none of them would qualify either. And finally over the years the LP has had a few different neck angle ranges too......so do you base your target height on the higher or the lower??
    And finally.....a setup is based on relief, buzz and playability. Notice there is no mention of the bridge. Its an 'adjustable' in order to achieve those tactile elements.
    MSB, endial, PierM and 1 other person like this.
  6. Nate Henderson
    75
    26
    May 24, 2017
    Ok, I was just wondering because I found one that I like, but the bridge looked really high so I brought in a tool to measure it and it's like 46/64" from the body to the flat part of the top of the bridge (not including saddles). Seems high to me.
  7. Cjsinla
    Cjsinla Senior Member
    3,638
    2,922
    Jul 7, 2014
    48/64ths translates to 3/4 inches, that seems high. What is the measurements from the top of the guitar to the bottom of the adjustment wheel? That’s more telling to me. Most of mine measure there from 1/8 to maybe 3/8 inches at most. A high bridge would only be a problem if you plan on decking your tailpiece for the most part. A bridge that is too low can cause a problem setting up the action.
  8. Nate Henderson
    75
    26
    May 24, 2017
    I think the distance between the top and the wheel was about 2/8".
  9. mudface
    mudface Non-Deadbeat/Non-Prominent Double Platinum Supporter Premium Member
    6,012
    18,960
    Aug 29, 2016
    2/8 =1/4.......... not bad
  10. Nate Henderson
    75
    26
    May 24, 2017
    I know, I gave the number in 8ths because Csjinla gave the expected range in 8ths.
  11. DarrellV
    DarrellV About as sharp as a bowlin' ball! -NPM Premium Member
    18,304
    42,992
    Nov 1, 2016
  12. Nate Henderson
    75
    26
    May 24, 2017
  13. Kaicho8888
    Kaicho8888 Senior Member
    744
    345
    Jul 27, 2008
    The neck angle is not be glued to the body at the correct angle? Hate having the bridge too high off the body... could contribute to possible bridge posts bending for ABR type.
    Picture looks ok.
  14. DarrellV
    18,304
    42,992
    Nov 1, 2016
    From what little I know, that doesn't look too bad at all.
    OP! Are you aware that the neck is set at a back angle to the body?
    It is not straight in like a Fender, it is tipped back a bit.
    This is why the bridge must be higher like this one. The carved top and neck back - angle needs it like this to work.
  15. PierM
    PierM Certified Naysayer Premium Member
    3,833
    6,567
    Aug 19, 2016
    I see nothing wrong here.
    endial and DarrellV like this.
  16. Nate Henderson
    75
    26
    May 24, 2017
    Ok thanks.
    Yes I know the neck is supposed to be at an angle.
    DarrellV likes this.
  17. MSB
    MSB Senior Member
    2,314
    2,316
    Jan 21, 2015
    I wouldn't worry about that bridge height, but the TP looks higher than I'd care for
  18. MSB
    MSB Senior Member
    2,314
    2,316
    Jan 21, 2015
    here's 3 LPs and a Travis Bean for reference... hope it helps. All play with no buzz and if I didn't use picks could go a bit lower w/o buzz on the neck
    edit- it's funny, the red one has the highest "string height" off the body but easily has the lowest action on the neck (neck angle I suppose?)
  19. scozz
    scozz Senior Member
    3,816
    4,579
    Sep 3, 2007
    Yup...I would deck that tailpiece and topwrap!
    medic24 likes this.
  20. moreles
    moreles Senior Member
    3,015
    1,657
    Apr 16, 2011
    This thread is yet another example of the need for pictures. As soon as the OP provided a pic, members could readily see that the setup falls into the norm. Without pics, we end up speculating unnecessarily about what "high" means, and the numerous possible causes. Your guitar looks fine, though the posts look a bit bent. Now you can explore one trillion opinions about top wrapping, snugging down, bridge composition, etc., etc., etc! Good luck getting the action you want.
