Bridge and tailpiece question for '93-'98 Reissue owners
Discussion in 'Historics & Reissues' started by bosnialove, Sep 21, 2017.
  1. bosnialove
    bosnialove Senior Member
    2,948
    2,036
    Dec 8, 2011
    I got my guitar back from a set up and noticed that the underside of the ABR1 says Pat. No. with a number, however the underside of the tailpiece says Made In Germany.
    I think the guitar tech has accidently swapped my bridge for an other one, because as far as I know, Historics in the '90ies used Schaller hardware and therefore it hould say Made In Germany. Also, as far as I know, Pat. No. hardware has been used in the '80ies and not in the '90ies.
    For all '93 - '98 Reissue owners who know their bridge and tailpiece are the ones that originally came on the guitar: what is written on the underside of your hardware?
  2. Sct13
    17,047
    19,913
    Sep 18, 2011
    NOT made in Germany....
  3. bosnialove
    2,948
    2,036
    Dec 8, 2011
    What do you mean with that?
  4. Sct13
    17,047
    19,913
    Sep 18, 2011
    The tail piece should not be made in Germany if it is supposed to be from Gibson...
  5. d1m1
    d1m1 Senior Member
    2,357
    2,538
    Oct 30, 2012
    it was no schaller hardware back then. i owned couple 93-94 historics and all of them had standard hardware gibson used in the 80s.
    what happend to your 93 gt replica? i remember a luthier in croatia started making it for you. is it ready yet?
  6. bosnialove
    2,948
    2,036
    Dec 8, 2011
    I have found someone else for that job and it is almost ready for paint.
    It is a '59 Replica with the only changes being 1. my name on the headstock in stead of Gibson and 2. two added granite strips/rods in the neck next to the truss rod that continue into the headstock for better strength of the neck/headstock area.
    RAG7890 and d1m1 like this.
  7. L96A1
    L96A1 Senior Member
    411
    345
    Oct 8, 2012
    If I'm right the 90s stop bar was brass, if that helps.
  8. Dilver
    Dilver Senior Member
    794
    1,019
    Apr 26, 2011
    My 93 LP Studio Lite came with a bridge that as stamped Made In Germany. Granted, it was black hardware, and it was on a Studio. But Gibson has used hardware made in Germany in the past. A pic of the stamp would help to identify it.
  9. d1m1
    d1m1 Senior Member
    2,357
    2,538
    Oct 30, 2012
    Yes but not on historics. The question was about historics.
  10. Left Paw
    Left Paw Senior Member
    3,771
    2,067
    Dec 29, 2013
    Not sure if brass, but it wasn't lightweight.
  11. bosnialove
    2,948
    2,036
    Dec 8, 2011
    OKay, so we can be shure the tailpiece was not made from aliminium.
    I'll take some pics at the next string change.
  12. bosnialove
    2,948
    2,036
    Dec 8, 2011
    I went back to the luthier and got the original ABR-1 one back.
    I have done research lately on the type of ABR-1 and tailpiece that came on several low Serial number Historics and I can conclude the following.
    On several fully stock and untouched low serial number 1993 Historics I found:
    - a nickel wired ABR-1 bridge that says "ABR-1" on the bottom, without the mark after the 1 like the ABR-1's from the '60s;
    - a nickel heavy tailpiece that says "Made In Germany" on the bottom;
    - nickel push in bushing tuners that say "Gibson Deluxe" on the casing;
    - two of those small orange caps that say "MP 203M 100V" on them;
    - two '90s '57 Classic pickups with a small black sticker that say "Patent Applied For" on the bottom.
  13. Les Kiwi
    Les Kiwi Senior Member
    112
    103
    Apr 21, 2016
    Did your luthier explain why he swapped your hardware out and kept your original stuff. Seems odd and a little dodgy to me.
  14. bosnialove
    2,948
    2,036
    Dec 8, 2011
    Doesnt seem dodgy to me because the bridge he put on my guitar has a bigger value than the original bridge on my guitar. :p guess its just mistake. Never had any problems with him and he is well known here in the Netherlands.
