Boss DS-1... like it/hate it/DIY mods/ANYTHING
Discussion in 'Pedals' started by quentin, Apr 11, 2010.
  1. diceman
    diceman V.I.P. Member
    29,932
    5,214
    Jul 5, 2007
    You mean, 80% of players have crappy tastes.
    zontar likes this.
  2. firesgt911
    firesgt911 Senior Member
    3,074
    2,737
    Jan 24, 2010
    It's not a pedal I keep on my board and does nothing for me, but there are a lot of big name rockstars that have sworn by it. Chavelle, Nirvana, Satch and Vai to name a few.
  3. Benjammin
    Benjammin Senior Member
    19,308
    13,257
    Jul 4, 2009
    for the record, the modded DS1 sounds great as a bass OD/distortion :dude:
  4. PurpleFlanger
    PurpleFlanger Member
    99
    8
    Jan 2, 2011
    I wish it retained mids, then I'd use it more.
  5. theruns
    theruns Senior Member
    223
    69
    Jun 26, 2010
    would anybody happen to know how to get rid of the horrible trebley-ness of this pedal? like what things do i need to change? i did the teledog mod on it and i love the sound! it just still has that shrillness though.
  6. Benjammin
    19,308
    13,257
    Jul 4, 2009
    where do you have the tone control set usually? I find myself setting it lower now after the mod than I used to before
  7. PurpleFlanger
    99
    8
    Jan 2, 2011
    Damn, never thought of that!
  8. ddevil
    ddevil Senior Member
    171
    4
    Jan 23, 2011
    Im sorry...can you explain this a little more? The sound you are getting is pretty sweet in the video...do you have a diagram or visual? Thanks!
    Cheers,
    DD
  9. theruns
    223
    69
    Jun 26, 2010
    generally it is between 9 and 11. anywhere after that it gets pretty shrill (to my ears anyway). i have noticed a nice bass boost from the pedal when you crank the gain. just sayin.
  10. Sirzach
    Sirzach Senior Member
    2,846
    1,367
    Jul 21, 2009
    Hmm, I run mine around 7-9. Then i roll up the tone on my guitar or amp. Not really all that shrill anymore for me.
  11. theruns
    223
    69
    Jun 26, 2010
    yeah i can tame it, but i would like the tone control to be a little bit less dramatic. do you kinda understand what i mean? im kind of a wierdo when it comes to certain things:)
  12. Benjammin
    19,308
    13,257
    Jul 4, 2009
    If i'm understanding you right, I think thats just the way it is. I dont mind it too much because I generally use it as a lead boost and for that it works wel i think. If I'm using the pedal alot, like for rhythm it can be too bright
  13. MrNed
    MrNed Junior Member
    1
    0
    Apr 14, 2011
    Hey Guys... I stumbled across this forum and thread, and I found all this to be very interesting. I bought my DS-1 when I was a kid. Somewhere about 25 years ago. Back then I liked the buzzy, thin sound, but for the last 20 years, the pedal has been sitting gathering dust because as i got to understand what *good* tone was, this pedal simply didn't cut it anymore. The tone I have forever been chasing since is the legendary "brown sound" of EVH.
    Anyhow, since I thought I had nothing to lose, I thought I'd give this mod a go.
    I opened it up, clipped the 2 diodes, closed it back up and put it my signal chain and the first words out of my mouth were: "WTF!!" (non abbreviated version).
    As many others have confirmed, this changes the whole characteristic of the pedal. It is something I can now use again.
    For those who doubt or worry about this mod, just try it. It's reversible if you don't like it, and as others have suggested, put a DPDT switch in.
    I tried the pedals on 2 setups:
    1) Les Paul -> DS-1 -> Marshall 50W Plexi head -> Celestion G12M
    2) Les Paul -> DS-1 -> Marshal JMP-1 -> Intellifex -> Mesa Boogie 50/50 -> Celestion G12M
    In both these setups, the pedal sounds totally sweet!
    The tone a lot have already described on this forum is the result. Adjusting the knobs also seems to get you a very wide ranging variance of sound.
    If I get some time, I'll record and post some clips.
    If your DS-1 is sitting around anyway, just do this mod. You won't be disappointed.
    Thanks guys! Cheers!
  14. quentin
    quentin Member
    95
    0
    Apr 11, 2010
    +1 for the clip mod ^ right you are
  15. jokun
    jokun Senior Member
    103
    9
    May 10, 2010
    The DS-1 was my first pedal and I absolutely hated it!
    In a good tube amp you could get a OK sound of it, but I had a massive drop in volume when I kicked it in due to my high output pickups(Yes, I had the level maxed).
    I did the "Teledog-mod" today and WOW, it is finally usable!
    I really just klicked into this thread to rant over how bad this pedal was, but instead I learned how to make it into a really nice pedal!
    Thanks a lot!!! :D
  16. pickerrr
    pickerrr Senior Member
    699
    468
    May 22, 2011
    DS-1 is too "sandy" to me, and too compressed.
  17. theruns
    223
    69
    Jun 26, 2010
    have you tried the mod? its super simple, reversible, and free!
  18. rjshare
    rjshare Senior Member
    4,935
    5,035
    Feb 13, 2011
    holy necro etc etc
    but...
    i just ressurected this one because i picked up an as new mint ds-1 the other day for 10 euros an having tried it, decided that the diode trick needed doing.
    i have put in a three way toggle switch connected to the two diodes so i now have the option of stock/one diode off/two diodes off.
    like it!
    as you were...
  19. gibsonguitar1988
    gibsonguitar1988 Senior Member
    11,833
    9,765
    Feb 10, 2008
    Just did the D4/D5 mod... Makes it into a very lower gain kind of pedal - more booster than anything. Not so good through a clean tube Fender amp like I use. I don't use amp dirt so maybe it's better for boosting a dirty amp. It is a good mod though - I DO like it better than stock. Also love the C6 removal for an SD-1 Super Overdrive. Nothing for the BD-2 that's similar AFAIK.
    Generally speaking the DS-1 was my first pedal. I've always played with gain and am more into classic rock and blues based though rather than shred/metal/hard stuff.
    But the DS-1 turned me off because I associated it with Nirvana and neoclassical shred players, both of which I don't like at all. But maybe now I could use it as a booster with another dirt in front of it.
  20. Tobacco Worm
    Tobacco Worm Senior Member
    380
    448
    May 13, 2012
    Well folks, as with others, I stumbled upon this thread and found the diode mod of real interest. Had a DS-1 long ago and was never a real fan. Traded or sold it ages ago. Got a new one in a trade last month, as it was part of the deal. I thought to myself, ok...now what ya gonna do with it? It sat as others here said, collecting dust....Then.....
    Poped it open. Clipped D4 and D5 and put it back together. Plugged it into my board next to the new Joyo Ultimate Overdrive (a great pedal by the way) and did an A/B with the two. Impressed! Tamed it down to use, and the tone and drive is quite good in fact. Now with the Joyo UOD and the DS-1 next to each other, my distortion/OD is 100% complete. The DS-1 doing a great job with a mild OD and the Joyo taking up the stronger drive duties with ease.
    Glad to have this pedal back in it's new and improved form. Really makes a difference with these two diodes out of the circuit. Took all of five minutes to get a pedal I hated turned into one that is welcomed to the board!
    Thanks!!
    Wade
    1 person likes this.
