Black Beauty Middle Pup
Discussion in 'Epiphone Les Pauls' started by Andrew J Betry, Aug 4, 2017.
  1. Andrew J Betry
    Andrew J Betry Junior Member
    13
    0
    Jul 9, 2017
    I want the middle position of my BB to fire up all three pickups.... how is that done?? Thanks
  2. thatF-INGflyingVguy
    thatF-INGflyingVguy Senior Member
    2,271
    2,557
    Dec 5, 2015
    DONT DO IT !!!! It will rip a hole in the fabric of both time and space .
  3. Andrew J Betry
    13
    0
    Jul 9, 2017
    .. Just seems goofy to have a beautiful pickup that doesn't work. The middle position USED To light up the middle And the bridge, but the shop re-did some soldering and now no-worky.
    I always like the idea of all three... Isn't that how Ace's are set up?
  4. thatF-INGflyingVguy
    2,271
    2,557
    Dec 5, 2015
    no ace only has the bridge wired middle and neck are not wired , and slammed down to the bottom .
    the best way to do this is to look at the explorer 3 wiring diagram but you will need 1 more switch . it will give you every possible combination
  5. thatF-INGflyingVguy
    2,271
    2,557
    Dec 5, 2015
    look at the pick ups
  6. Andrew J Betry
    13
    0
    Jul 9, 2017
    Thanks for the explanation... I didn't know. I'll drop the middle one down and out of the way.
  7. fumblefinger
    fumblefinger Senior Member
    1,193
    485
    May 10, 2012
  8. Pflug
    Pflug Senior Member
    168
    455
    Mar 23, 2013
    I actually ended up rewiring the toggle switch on mine for "normal" bridge and neck operation g and have the middle "on" all the time- I blend it in or out with a volume pot. I have separate volumes for each of the three pickups with a single tone and push-pulls for all 4 pots giving a coil split option for each as well as phase change.
    My pickups are a Duncan '59 neck, Custom Custom middle , and Custom 5 bridge
  9. cooljuk
    13,774
    16,971
    Mar 12, 2009
  10. fry
    fry Senior Member
    1,965
    2,284
    Jan 10, 2011
    I saw a recent video in which Ace said he only has the bridge pickup wired.
