Best way to determine when you need new tubes
Discussion in 'The Squawk Box' started by irocdave12, Sep 14, 2017.
  1. irocdave12
    irocdave12 Senior Member
    2,394
    2,903
    Jun 22, 2011
  2. Dick Banks
    Dick Banks Senior Member
    513
    599
    Apr 27, 2017
    When the neighbors stop bitchin'
    thatF-INGflyingVguy and DarrellV like this.
  3. LPPILOT
    LPPILOT Senior Member
    1,060
    534
    Jun 22, 2010
    Right after you brag about How long the present tubes have lasted.
  4. DarrellV
    16,397
    36,570
    Nov 1, 2016
    When one of your bandmates comments on how cool the blue glow looks in your amp....
    yamariv likes this.
  5. KenG
    KenG Senior Member
    6,269
    3,336
    Sep 13, 2009
    Usually they have to degrade quite a bit before you notice because it happens slowly over time (I'm talking wearing out here not tube failure). Tube testers used to be so common in the 70s and even to degree in the80s and you simply pulled your tubes and tested them. I was in the Miltary back in the 80s as a tech and had access to a nice Stark. Now the only hi voltage testers left are reconditioned ones and theyare expensive. You could probably find plans and build the circuits to test the most common tubes but it would still be expensive. There are low voltage testers out there, or at least there used to be, but they don't test at working voltages so they may miss some issues.
    yamariv likes this.
  6. DarrellV
    16,397
    36,570
    Nov 1, 2016
    Yeah, I remember every Radio Shack had one at the front of the store... Oh, wait! They're not around anymore either!:mad:
  7. rogue3
    rogue3 Senior Member
    1,344
    1,676
    Apr 22, 2017
    I have a nice rack mount unit.Navy tester,i think.That grey colour they used on the US. Navy ships.High voltage.Chicken head knobs:D. It worked last time i used it,which would be probably 15 years. Point to point.I installed it in a home made inclined mahoganey frame.Its a nice display piece.I have the manual,and may boot it up to test some output tubes that went south on me recently in a Hiwatt Dr504.Need to test for shorts.
    Its no biggie to call the ball when the amp starts sounding like uncle donald.As for the slow deline,usually when i become dissatisfied with the sound, that raises a flag.It helps to have other amps around that are in prime condition to compare too, that's my benchmark.And a whack of tubes to substitute.I'm good there.;)
  8. ehb
    ehb Chief Discombobulator Premium Member
    24,829
    114,497
    Feb 20, 2013
    Listen for odd change...
    One of my combos, I started hearing a bit over a second of motorboating very soft in background, gtr output was all normal during it, and it might not happen again for an hour or two...
    Replaced power jugs, rebiased, and no mo moboat..... Very very low dB hiss in clean chan was gone too...
