Best Pedal For Solo Volume Boost?
Discussion in 'Pedals' started by longjaw, Nov 30, 2008.
  1. longjaw
    longjaw Senior Member
    520
    56
    Aug 29, 2008
    Hey guys, looking for a pedal to boost my volume for solos on my Peavey Classic 30. My band play classic rock/blues a la ZZ Top - I'm thinking of getting a Marshall Guvnor 2. Anyone recommend them or any other reasonably priced pedal? Thanks
  2. VictorLazarus
    VictorLazarus Senior Member
    1,221
    7
    Dec 24, 2007
    Try a drive pedal or an overdrive pedal set really low distortion for a good clean boost. (if thats what your after)
    MVL.
  3. JLH
    JLH Senior Member
    850
    133
    Apr 22, 2007
  4. PraXis
    PraXis V.I.P. Member
    24,906
    24,329
    Dec 14, 2007
  5. Gibsonblues
    Gibsonblues Senior Member
    841
    57
    Oct 5, 2007
    Fulltone OCD works for me... Gibsonblues...
  6. Splattle101
    Splattle101 V.I.P. Member
    8,643
    4,149
    May 30, 2008
    My take on the Guvnor: nah, don't do it. I don't like the sound of the Guvnor in either its original or new forms through any amp except an old Marshall.
    Anyway, for boosts there's a better option. The Boss GE-7 graphic equalizer pedal. This or any similar graphic EQ will have 6 or 7 bands of EQ and (roll drums) a volume slider. The sheer boost from this will increase the saturation of your dirty channel, and give you a bigger volume boost than most distortion / overdrive pedals. It also gives you a lot more control over your tone: you can actually sculpt it the way you want it.
    It also means that all of your distortion remains valve distortion. No nasty clipping diodes.:thumb:
  7. Splattle101
    8,643
    4,149
    May 30, 2008
    That looks cool.:naughty:
    And while we're on the subject of big +35 dB boosts, there's this:
    New Page 2
    I have their Crunch Box, and it is superb. In fact, this thread has prompted me to go and try a Boost n Buff at a local shop. Hmmmm.:hmm:
  8. briggs
    briggs Junior Member
    10
    0
    Dec 1, 2008
    AMZ Mosfet booster. The Catalinbread pedal previously mentioned is based upon it. Great booster circuit!
  9. Blues Power
    Blues Power V.I.P. Member
    2,129
    25
    Oct 25, 2007
    clean boost? use a GE-7 keep the sliders neutral and just use the vol lever
  10. longjaw
    520
    56
    Aug 29, 2008
    Thanks chaps - think I'll try the Boss GE-7 option. Gonna keep my eyes peeled on eBay and see if I can get one cheap there! Thanks again!
  11. Blues Rocker
    Blues Rocker Senior Member
    177
    14
    Oct 23, 2008
    +1 Fulltone OCD. From my experience even with Drive set to min (fully CCW), it provides rich harmonics. It may even be a little much, even set to min. You may wish to consider just a boost such as a Fulltone Fat Boost set to min.
  12. PraXis
    24,906
    24,329
    Dec 14, 2007
    +1 on the OCD set to minimal gain. It sounds so... perfect!
  13. longjaw
    520
    56
    Aug 29, 2008
    D#mn! Don't know wether to try the OCD now! :)
  14. soloben347
    soloben347 Senior Member
    375
    5
    Jan 25, 2008
    i own the classic 30 head and speaking from exp id say either the OCD or my personal favourite a tubescreamer...both are good overdrives
  15. PraXis
    24,906
    24,329
    Dec 14, 2007
    Give in to the GAS attack!
  16. Big John
    Big John STFU and play V.I.P. Member
    7,262
    6,487
    Mar 18, 2007
    I'm a little confused.
    Are you talking about boosting the guitar signal at the input of the amp (which would more than likely increase preamp distortion and not the volume), or are we talking about increasing the volume of the amp without changing the tone of the preamp (by using the effects loop)?
  17. Big John
    7,262
    6,487
    Mar 18, 2007
    Whenever I gig, I always run the amp(s) one of two ways for volume changes. I either boost the signal in the f/x loop for solos, or I cut the same signal for rhythm parts. I usually end up boosting the majority of the time because I like the idea of making the power section work slightly harder. In the rare situation that the amp is already louder than piss, I'll go the rhythm cutting route. Also, I put the boost (or cut) at the end of the chain if I'm running effects in the loop.
    For solo boosting, I try to use something with a broad & flat response that boosts all frequencies evenly. I've been using the discontinued DOD FX-10 Bi-Fet preamp pedal for years. They're cheap & plentiful, don't color the sound, and work everytime I step on it.
    For rhythm cutting, there's a couple ways to do it. The easiest is to pick up an Ernie Ball 25K volume pedal. You want the 25K model because 99.99% of the f/x loops out there run at low impedance. If you gig with a couple of amps, get the stereo version of the pedal. The other way is to just build a volume cut box yourself, which is what I have (hiding in a box somewhere out in the garage). I made mine with two 25K pots for use with two amps, and also with a 3PDT switch so that I could use two status LEDs.
    And if you haven't figured it out yet, you will need a couple more guitar cables if you're not currently using the loop.
    Rock on. :dude:
  18. madams17
    madams17 Senior Member
    202
    3
    Jul 9, 2008
  19. lightningmonkey
    lightningmonkey Senior Member
    212
    3
    Apr 17, 2008
    Durham Sex Drive
    Keeley Time Machine Boost
  20. longjaw
    520
    56
    Aug 29, 2008
    The Peavey Classic 30 doesn't have an effects loop so I'll be going through the input socket.
