Best mud-free neck pickup
Discussion in 'Pickups' started by 50WPLEXI, Nov 20, 2015.
  1. rockinlespaul
    rockinlespaul Oxblood Addict V.I.P. Member
    10,026
    9,989
    Aug 12, 2007
    If you like the Dr. Vintage, you need to try Wolfe's Legends.
    Sublime. The absolute best Wolfe has to offer. Legends are my preferred pups.
    Brutus and Mr. Satchmo like this.
  2. LpCustom2007
    LpCustom2007 Senior Member
    942
    652
    Dec 20, 2012
    Sounds like a strange thing to say. For example Sheptone uses A5 for most of his models, and I never experienced a muddy Sheptone neck bucker..
    1 person likes this.
  3. Otto tune
    Otto tune Senior Member
    2,325
    1,811
    Jul 19, 2014
    I have a set of sig. JB's in my LP. They are so different, switching from the bridge to the neck requires major re-tweaking. They definitely jump out at you.
  4. Mr. Satchmo
    Mr. Satchmo Senior Member
    3,267
    3,389
    Dec 20, 2010
    Since I already bought the marshallheads (I was saying that would be my next set and then I got them the next day) My next guitar will definitely get those legends!
  5. AJK1
    AJK1 Senior Member
    697
    220
    Apr 19, 2014
    Yep, i have the antiquity jazz in one of my guitars and it is divine
    So much character and piano quality tones
  6. Angus Blackmore
    Angus Blackmore Member
    90
    45
    Aug 15, 2011
    + 1 with my main band.
    brianbzed likes this.
  7. Angus Blackmore
    90
    45
    Aug 15, 2011
    I don't know the Jazz but I my band often requires cristal cleans from my Paul's ... that I can get out of the SD Full Shred and SD59s (see signature)... but I do find myself maxing the amp's treble pot on the Classic 30 and Hot Rod, not on the DSL or the Champ.
  8. C_Becker
    C_Becker Dat Gibson smell
    1,870
    1,753
    Jul 7, 2015
    Duncan SH-2 is the cleanest pup I've played so far in the neck position.
    You can try coil-splitting the neck pup as well.
    Also height adjustment can make a huge difference, try adjusting the polepieces as well.
  9. Caretaker
    Caretaker Senior Member
    5,435
    3,335
    Mar 27, 2007
    Al Dimeola had this issue with his Customs. I was in a shop in NJ when he was trying various pickups. He finally decided on Dimarzio Super Distortions in BOTH postions on his Les Pauls and it cured the issue. This was in 78 or so. I`m not sure if he still uses them, or Customs for that matter.
  10. mdubya
    mdubya Senior Member
    16,357
    24,991
    Jan 25, 2010
    I wonder if anyone makes a single coil mounted off set on a humbucker baseplate with a cover, so it looks like an hb? :hmm:
  11. Zoobiedood
    Zoobiedood Senior Member
    861
    294
    Sep 1, 2015
    The Stag Mag is really 2 singles on a humbucker baseplate. The series wiring is thick, but split, it *is* a single coil (rods are staggered magnets), so there's that.
    mdubya likes this.
  12. Antigua
    Antigua Senior Member
    499
    148
    Oct 15, 2016
    I see nobody has mentioned a low value capacitor in series yet. IMO, that's the best way to tighten up the neck PU's tone. It especially improves the overdriven tone of the neck, and you can wire the cap with push pull pot, so that you can bypass the cap if you decide you don't want it in circuit.
  13. freefrog
    freefrog Senior Member
    1,230
    674
    May 21, 2011
    Yep, there's many ways to "demud" neck PU's...
    Series caps are a clever trick, cheap, simple and efficient, although some capacitive values might add a "Ricky vibe" to the sound (it's in Rickenbacker's that I've seen for the first time stock 4.7n caps in series with the pickups and it contributed largely to their specific sound, IMHO)...
    Wiring the PU in parallel works too, albeit it obviously makes it weaker...
    Personally, I like to solder a dual (humbucking) high inductance dummy coil in series with a resistor, then to wire the whole in parallel with the PU: it lowers its inductance without altering too much its DCR nor the overall volume/response and tightens the tone accordingly.
    That said, I've here a vintage LP Custom in maintenance and its neck T-Top doesn't sound muddy.
    This Custom has a light aluminium tailpiece, BTW. Changing the stop bar costs less than mounting a new pickup and might help to cure muddy tones with neck PU's on a LP...
    FWIW. YMMV. I wish you all a nice day full of music.
  14. bluefrog
    bluefrog Senior Member
    945
    228
    Mar 15, 2009
    come on ... A5 is NOT per se muddy sounding. it is all the system winding, material, magnet and setup etc.
    my sheptone tribute is A5 but very open and the SD sh-2 is A5 and the jazz neck known as very clear indeed.
    the Classic 57 I dont like so much a bit too thick ... I will check a SD59N with A5 ( maybe A3)
    soon...
  15. gtr-tek
    gtr-tek Fumble Fingers Premium Member
    2,587
    860
    Mar 24, 2010
    50's wiring and maybe a Seth Lover or Antiquity. I like a .015 uf cap to help it along.
  16. Brutus
    Brutus Senior Member
    575
    577
    Jun 22, 2010
    I do love the Wolfetone Legends I have in my R8. However a set of ECP Hallowed Ground's would be a sweet choice. Unbelievably Good!!
    jcsk8 likes this.
  17. Mark V Guitars
    Mark V Guitars バナナフライング...
    6,082
    6,988
    Apr 20, 2011
    Well for me at least...Skatterbranes ended the search for me. Great neck...articulate, never muddy, and the bridge pup is just perfect. Both pups are very musical, lots of harmonics. Great set.
    framos likes this.
  18. Eric R
    Eric R Member
    42
    19
    Nov 22, 2016
    Dimarzio From hell indead, and let's not forget the Dimarzio Bluesbucker. Highly reccomendable!
  19. brianbzed
    brianbzed Senior Member
    2,160
    966
    Aug 14, 2008
    +1! I like to set up the overall tone with the neck pickup. That way, your contrasting bridge pickup will melt their ears!
  20. Starman
    Starman Senior Member
    227
    129
    Mar 16, 2014
    If you don't mind the continual Sweet Child O' Mine flashback's it offers, the Duncan APH-2N Slash Alnico II is absolutely wonderful, clear, articulate and sweet sounding.
