Best mud-free neck pickup
Discussion in 'Pickups' started by 50WPLEXI, Nov 20, 2015.
  1. 50WPLEXI
    50WPLEXI Senior Member
    2,422
    2,531
    Apr 4, 2013
    So since the neck humbucker seems to be the achilles heel of a Les Paul type guitar. Which humbuckers have you used to cure this ill?
  2. Frogfur
    Frogfur Senior Member
    16,805
    28,479
    Jan 18, 2013
    50, almost any modern PAF style will sound perfectly fine if at the
    Most basic level, if most just lower the pickup some and raise the poles to your liking.
  3. northernguitarguy
    northernguitarguy SWeAT hOg
    28,342
    47,032
    Feb 22, 2009
  4. Ph03n1x
    Ph03n1x Senior Member
    1,549
    905
    Dec 29, 2009
    I liked the new custombuckers for this. PAF style pickups should be lower output and more clear but some winders still manage to make them muddy. I like alnico III in neck but that is my preference.
  5. morbidalex666
    morbidalex666 Senior Member
    1,051
    330
    Jan 7, 2013
    Tyson TTL-2 neck
    Suhr Thornbucker neck
    There are others that I have tried and achieved that, but I didn't like their tone.
  6. 50WPLEXI
    2,422
    2,531
    Apr 4, 2013
    I agree up to a point. My guitar (I've seen others) is super picky when it comes to the neck pup for some reason. Wrong mag/just a little too hot and it's mud city.
    No amount of tweaking will make it go away. But then you have the guitars that can just take anything. I have a A3/PAF type in my guitar now and it's perfect.
    Just wondering what you all thought/have used.
  7. LtKojak
    LtKojak Senior Member
    4,050
    2,779
    Aug 26, 2009
    If the guitar itself is not a complete dud, any well-wound p'up should be able to be set-up to sound mud-free.
    Having said that, there are two grades of alnico that time and time again come to the rescue in case of a pesky muddy neck: A3 and A4, depending on the desired basic tone-footprint.
    I don't have the science to back this up; I'm just stating the facts of over fifteen years of guitar-teching.
    HTH,
  8. theycallmetex
    theycallmetex Senior Member
    422
    179
    Oct 26, 2011
    ReWind Low Output
  9. Zhangliqun
    Zhangliqun Senior Member
    1,598
    752
    Apr 10, 2007
    Almost any A5 neck bucker will bring the mud.
  10. Quill
    Quill Senior Member
    4,548
    3,038
    Sep 15, 2009
    I have never in decades of playing and with all kinds of different humbuckers ever had trouble getting a good sound out of any humbucker in the neck position, regardless of wind or magnet. Yes, it's possible that for certain specific applications one pickup might be better than another. But. I like to choose amps and speakers and any gadgetry that work on the bright side, or adjust the set-up so it works that way, and then roll back whatever seems too bright with the tone controls on the guitar or on an overdrive pedal or an eq or whatever works. If one habitually sets up the amp using the bridge pickup on the guitar as the reference point - which usually offers a narrower and sometimes brighter range of sounds to work with in the first place - it can be hard to get good sounds in performance with any other pickup. This applies to any guitar with multiple pickups, not just humbuckers.
    I mean ... this is something I figured out as a kid the first time I ever sat by myself in a music store somewhere and picked away a little on an electric guitar plugged into an amp, within about five minutes of flipping switches and turning knobs ... but it's a more complicated world now, with lots of distractions ... it takes longer to figure stuff out, these days. :cool:
  11. zoork_1
    zoork_1 Senior Member
    1,190
    539
    Apr 22, 2009
    So far I've tried a Shed (6.9k), a Leslie (7k?) and a stock Gibson pu reading 7k (490?) but I think any decent low wound pu (with offset coils) does the trick...
    1 person likes this.
  12. Elkoki
    Elkoki Senior Member
    439
    126
    Mar 4, 2015
    Even les paul admitted the neck position was kind of muddy ... So you're not wrong ...
    If you're playing music with higher gain , you might be into the humbucker from hell, super 2 or d-activator neck .... The super 2 will completely clean up all the notes especially the higher notes on the low e string... That thing is super super clear. But it may not be for everyone ...
  13. kboman
    kboman Senior Member
    6,458
    5,699
    Jun 19, 2011
    I've got an OLD set of K10s (mid-late 1970s - Super 2 before the name change) and those things are seriously clear, probably the clearest I have ever played in a pickup that still sounds fully like a humbucker. A different cup of tea indeed from a PAF type pickup (high headroom, low resistance, ceramic magnet, hotter than a PAF but with a lot of the low end shaved off), but absolutely worth investigating.
  14. Progrocker111
    Progrocker111 Senior Member
    3,361
    2,379
    Oct 30, 2011
    T-Tops are great for neck position, especially late 60s/early 70s ones. They are very clear, dynamic and articulate sounding pickups.
  15. Al Walker
    Al Walker Senior Member
    1,191
    1,215
    Sep 14, 2014
    Humbucker size P-90 (Brand of your choice).
  16. morbidalex666
    1,051
    330
    Jan 7, 2013
    Nope
    4 people like this.
  17. rockinlespaul
    rockinlespaul Oxblood Addict V.I.P. Member
    10,282
    10,436
    Aug 12, 2007
    Peter Florance Voodoo '59 or Wolfetone Dr. Vintage.
    jcsk8, Mr. Satchmo and 50WPLEXI like this.
  18. Zenatty1
    Zenatty1 Premium Member
    482
    214
    Jun 20, 2011
    The best neck hum bucker made IMHO (I like Bare Knuckle, Suhr, Dimarzio as a general rule)... is.... the Dimarzion "Humbucker From Hell"... very clear, very articulate, and very responsive ...and it will save you some $...
  19. mdubya
    mdubya Senior Member
    16,807
    26,163
    Jan 25, 2010
    P-90 or Mini-humbucker.
    But I love 57 Classics in the neck, too. No muddy problems for mdubya.
    Maybe it is a too much gain problem?
    I tend to lower the neck pickup to balance with the bridge, volume wise. I don't like one to be louder than the other and I tend to play fat lead tones on the neck, so I don't mind if it sounds a bit wool-y with OD.
    Best cure for a muddy neck pickup? Flip the selector switch to the bridge pickup. Mud gone. :)
    2 people like this.
  20. garybaldy
    garybaldy Senior Member
    1,732
    932
    Apr 10, 2011
    DiMarzio H from H or EJ?
