Best interface <$200?
Discussion in 'Recording Studio' started by Ph03n1x, Mar 21, 2013.
  1. Ph03n1x
    Ph03n1x Senior Member
    1,549
    901
    Dec 29, 2009
    Ok, so I ruled out the Sapphire 2i2 because of clipping.
    I am currently looking at the Roland UA22.
    Does anyone know about it?
    First hand experience?
    LIBERTYMACHINE likes this.
  2. Freddy G
    Freddy G V.I.P. Member
    11,052
    22,725
    Mar 18, 2007
    Clipping? Are you clipping the input with a really hot mic? If that's the problem just build a simple pad in an XLR connector. 3 resistors...about $1.
    Or if you're not good with a soldering iron just buy an inline pad like this one:
    Whirlwind IMP Pad (20 dB) | Sweetwater.com
  3. Ph03n1x
    1,549
    901
    Dec 29, 2009
    It's a known issue with the 2i2. The lowest gain setting on the preamp is still too high for many guitars plugged straight in. The solution is to buy a DI box to put in front of the 2i2. But that seems stupid and cluttered when the device should have worked as a DI box itself. If you google about this device you will see several posts about the issue.
    I am trying to find out if the Roland device has any similar problems because I suspect their preamps might be similar.
  4. Freddy G
    11,052
    22,725
    Mar 18, 2007
    I see. Good to know, thanks.
  5. nitrodc
    nitrodc Senior Member
    307
    194
    Sep 14, 2012
    I'd probably look at something from PreSonus or Tascam, they seem to be the most reputable among USB interfaces (I have a Tascam myself).
  6. blues_n_cues
    blues_n_cues Senior Member
    1,802
    1,005
    Jun 29, 2010
  7. rubbieh
    rubbieh Premium Member
    115
    151
    Jun 12, 2012
    I use a Mackie Blackjack, simple and effective with no issues so far.
  8. northernguitarguy
    northernguitarguy SWeAT hOg
    27,985
    46,069
    Feb 22, 2009
    No expert here, so take this with a grain of salt. I really liike my Presonus Inspire 1394. Very simple to use, bulletproof-built, and 'virtual controls' will keep this working for decades. I see them for sale on ebay for $50. I may buy a couple more, because they are 'stackable' up to four units, giving the user 8-track capabilities for under $200.
  9. John Ucol
    John Ucol Senior Member
    3,641
    1,517
    Dec 26, 2008
    I've used a Roland Tri-Capture since '11 with no hassle so far.
  10. John Ucol
    3,641
    1,517
    Dec 26, 2008
    Interesting... I did not know that about the 2i2
  11. Mexicanbreed
    Mexicanbreed Senior Member
    3,369
    5,791
    Nov 21, 2010
    Does anyone have experience with the Alesis iO2 or iO4? I am between one of those, or one of the Tascams (us 122 or 144). The main diffrences are the number of inputs; the four devices do MIDI as well, I believe.
    A guy who did a video review on the Alesis said it felt flimsy, but that the sound quality was good. Does anyone have any preference between the Tascams and the Alesis?
    I use PCs, by the way, in case that makes any difference.
  12. BigDipper15
    BigDipper15 Hack Guitarist
    4,324
    3,749
    Jun 27, 2012
    Does this work with mac and garageband? I've been looking for a simple interface to make basic cover tracks and basic lessons. Haven't had any luck.
    1 person likes this.
  13. blues_n_cues
    1,802
    1,005
    Jun 29, 2010
    I wonder why they're discontinued.
    24bit & firewire not for me but the stackable part was appealing.
  14. northernguitarguy
    27,985
    46,069
    Feb 22, 2009
    Yessir, that's how I use mine. I recorded the track in my sig with it, some other stuff as well. Works like a charm. If you have a new mac, you will need to buy a firewire 400 to 800 adapter. but they sell for under $10. To daisy-chain additional units, you only need firewire 400 cables.
    I dunno, I suppose something better replaced it. Is 24-bit 'low' or something? I really don't know the diff.
  15. BigDipper15
    4,324
    3,749
    Jun 27, 2012
    I have a 2009 Macbook Pro 13 inch as well as a 2010 imac desktop. I can't connect directly with USB? Does it come with any cables initially?
  16. northernguitarguy
    27,985
    46,069
    Feb 22, 2009
    Hey BD. The Presonus is firewire only. I believe your mac has a firewire 800 port and the interface has a 400. This is why you need the adapter cable. At first, I was using 400 cable with an adapter with a but found it wasn't always working properly. I finally just bought the proper cable off of ebay and I haven't had any problems since. If you decide to purchase one, contact me and I'll send the ebay link for the adapter cable I bought.
  17. BigDipper15
    4,324
    3,749
    Jun 27, 2012
    Understood. Is it worth looking for an interface with a firewire 800 cable?
  18. northernguitarguy
    27,985
    46,069
    Feb 22, 2009
    Others can better answer this one. I would imagine that a newer interface will sell for more. But I'm not certain it's any 'better' to buy a newer interface for simple projects.
  19. blues_n_cues
    1,802
    1,005
    Jun 29, 2010
    24 is good but my comp doesn't like 24/96 much.
    this will explain it better than I can-
    Does Bitrate Really Make a Difference In My Music?
    Sample Rate and Bitrate: The Guts of Digital Audio | | Music Production Tips - The Stereo Bus Blog
  20. jrm
    jrm Member
    48
    21
    Nov 21, 2012
    This one falls slightly above the price range ($249 list), but I am happy with the NI Komplete 6 interface. USB connection and has worked well for me. As a bonus, it comes with some virtual instruments, including a version of Guitar Rig.
    I am using it on a Mac and have had zero problems. (My previous interface was an M-Audio which was nothing but problems).
    FWIW, i have used this interface with a few different guitars, a dynamic mic and a condenser mic (unit has phantom power). No clipping issues that I have seen with this unit.
    edit to add: looks like it sells for $229. Since it comes with a $30 coupon on future purchase, it technically put the NI interface right at the requested $200 price point.
