Benefits of upgrading circuitry?
Discussion in 'Other Epiphones' started by CaineIsCarter, Mar 21, 2017.
  1. CaineIsCarter
    CaineIsCarter Member
    54
    35
    Mar 17, 2016
    Hi all
    I love my new Epi FB and am very happy with how it sounds, but I read a lot about how some folk upgrade the wiring and pots and caps etc.
    Can someone explain please what is the benefit of doing this? Does it improve the sound?
    thanks
  2. 07rogersg
    07rogersg Senior Member
    240
    75
    Aug 29, 2008
    Posting this to tone freaks would really open a can of worms, but I'd argue that there's little to no difference in sound. Half of my guitars have upgraded pots/wiring the others stock. If your Epi was made in China it should have Alpha (good) pots and relatively neat wiring, the only thing that tend to go is the output jack and the switch eventually.
    People tend to look at it as if you're changing the jack and the switch you may as well upgrade the wiring for the extra cost. It's really up to you, honestly the only difference I notice between Alpha and CTS pots are that the latter feel a little stiffer and have a different sort of log on the volume pots.
    Jymbopalyse likes this.
  3. paruwi
    19,906
    26,512
    Dec 24, 2009
    I am from the 'don't fix it if it ain't broken' crowd :D
  4. jdto
    jdto Pretend Human Premium Member
    2,681
    3,338
    Sep 8, 2015
    Are you sure you want to mess with this...
    ...for only a possibility of this?
  5. CaineIsCarter
    54
    35
    Mar 17, 2016
    Thanks for the replies folks, appreciated. I won't be messing with my guitar's circuitry :)
  6. PierM
    PierM Black & Gold Premium Member
    2,750
    4,039
    Aug 19, 2016
    Changing pots and or caps, with same wiring as before, isn't changing too much.
    Changing wiring to '50 scheme does change the tone when you are under the 10 volume and 10 Tone levels, giving you way more brightness at lower volumes but with the tone pots acting on the final level.
    You should try these things as there are no words capable to describe a sound. :)
    But in general, if you don't need a '50 wiring, you should not fix what's not broken.
