Bees for Corksniffers Test
Discussion in 'Tonefreaks' started by Dilver, Nov 5, 2017.
  1. Dilver
    Dilver Senior Member
    693
    809
    Apr 26, 2011
    So I went ahead and bought some used 50’s Sprague Bumblebee caps (.022) off eBay just to see if I could hear a difference. Supposedly, they were measured to be within range and since I don’t have a way of measuring them, I took a gamble. Didn’t pay a huge sum (I think they were like $30.00 for the pair), fired up the soldering iron and installed in a matter of seconds.
    My basis for comparison were the Gibson fake bees, RS PIO “guitar caps” and the Mojotone Vitamin Ts. I thought the RS PIOs sounded a bit better than the Vitamin Ts; Vitamin Ts had a better taper than the fake bees. Not a huge difference among all of them, but since I had them I could choose. So it was the the vintage bees vs. the RS PIOs. All of this going into an R8 with good pots/wiring, 50’s wiring, played though a high quality short cable into 3 amps (tested separately): Fender DRRI, Swart STR Tweed and Supro 1616T. Not exactly scientific, but good enough for me.
    To be honest, I was skeptical. There’s the rational part of me that understands the logic that every engineer will offer: a capacitor does the same thing whether it’s PIO, ceramic or Mylar, as long as the values are the same. You should not hear a difference. There’s also a part of me that believes that some things defy logic. All I can offer is that I’m told I have a pretty good ear and I can usually hear things if they’re there.
    The vintage bees sound a little “smoother” than the RS caps. I notice a difference in the taper; the range of usable tones now seems to be “wider”. It’s now from 8 1/2 to about 5 on the guitar’s tone control when comparing the bees to the RS PIOs, which was more like 8 to 6. This probably means the cap has veered off .022. Which could/would happen anyway if the caps were still inside a guitar from the 50s. What I thought was interesting was that the tone knob has a little less noticeable effect on the volume (as 50s wiring typically does) than before. I’m not sure this sounds better, but I can hear a difference. Not a huge difference, but it’s there.
    Would anyone hear any of this at stage volume or f’ing care? Hell no. How the tubes in my amp are reacting to the temperature will probabaly have more noticeable effect on my live tone that these caps ever will. It’s all corksniffing. But I’ll live with these bees for a while to see how I feel. Anyone else care to share their Bumblebee cap experiences?
    5F6-A likes this.
  2. 5F6-A
    5F6-A Senior Member
    9,419
    1,979
    Aug 16, 2007
    Your observations are correct. Old Bees sound slightly better and different to current production but the difference albeit real, is not as pronounced as some people might expect.
    Dilver likes this.
  3. ARandall
    ARandall Senior Member
    11,523
    6,776
    Apr 16, 2012
    The testing - edit - (random person who doesn't want to be formally ID'd) - did on cap materials showed about the same.....subtle. His was on an oscilloscope so didn't take dynamic factors into account of course.
    It depends on how your particular setup and live situation is, but subtle tone shifts early in the chain can indeed make a difference....if say you can avoid manipulating later eq which is nowhere so precise in its scope of operation. So you might indeed find that you can cut through the mix better or similar if you can turn up the amp without an annoying treble artifact for example.
  4. moreles
    moreles Senior Member
    2,540
    1,122
    Apr 16, 2011
    Unless you metered the caps, which you didn't, it is not possible to attribute the differences you heard to construction rather than cap value. The latter is infinitely more likely -- in fact, virtually certain. Individuals will argue to the death as to the effects of composition, and I stay out of those debates because I have never been in position to test multiple caps in a reliable setup. But most people who know will agree that value is critical, and that comparisons of caps with even slight differences in value is bogus. All this being said, ARandall's comment about small differences at the front end of your signal chain is really important. I simply suggest that you are likely to be hearing value at least as much as composition in your situation.
    northernguitarguy and spitfire like this.
  5. Have FUN
    Have FUN Senior Member
    1,241
    1,122
    Apr 27, 2011
  6. Dilver
    693
    809
    Apr 26, 2011
    Oh, I agree, which is why I said “this probably means the cap has veered off .022”.
    mdubya likes this.
