Back to Building! Let's See What I Remember ;)
Discussion in 'Luthier's Corner' started by dickjonesify, Nov 27, 2017.
  1. pshupe
    pshupe Senior Member
    3,345
    2,170
    Jan 19, 2012
    Do you have a printer? I usually just print out the outline and holes with center marks and use a punch / awl to locate. Then I use the drill press with a 1/4" diameter brad point bit. I have all of the Stew Mac peg head bushing reamers. I actually bought the Stew Mac 3 in a line tuner jig but frankly it was way more trouble than what it was worth. It's this one - with 1/4" peg holes.
    or maybe you need one of these -
    Cheers Peter.
  2. dickjonesify
    dickjonesify Senior Member
    4,742
    4,615
    Apr 16, 2010
    Hahaha. Thanks! Glad to have you. I’ll have an update or two later tonight :cool:
    Thanks, Peter.
    I do have a printer. I actually printed out some headstocks and spray glued it to a think maple block for the jig, which I drilled on my press. It looks straight and square but it didn’t come out that way on the other side :/
  3. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Welp. I've been trying to use guitar building to mature a bit, slow down, be more careful. Hasn't worked yet :420: Need to slow back down. I made a lot of "progress" in the last couple days but now I have to plug and move one bridge :doh: and steam off one neck :doh:
    I started by trying to make a jig for the tuners.
    I probably should've just glued this to the headstock. Instead, i glued it to a thick block of maple and predrilled 1/4' holes.
    I don't know how they got off. The holes were drilled on a drill press and the jig was a snug fit and the center lines matched up. But, the tuners were super tight.
    I had to enlarge them to 5/16" and they're still a touch more snug than I'd like. On the 2nd one, I tried to just use the jig to mark the holes and then measure and drill through without it. But I was impatient and drilled by hand and they turned out almost exactly the same. That's 2 out of 2, genius.
    Anyway, they're on. Onto bridge placement...
    Regardless of where you believe the center line to be, mark both sides of the neck (after it's glued) to be sure.
    Then mark the center of that.
    My perfect straight edge is only 24" so I mark that first from the nut.
    According to the Stewmac calculator I need to be at 24.625-ish" on the treble side.
    Then the bass side is 1/8" back
    Marked
    X2
    Strings
    It's alive!!! Don't worry, it will have a dogear cover and that pickguard is only taped on at the moment. Couldn't resist a mockup.
    Here's the problem, though...
    Ouch. Too high. I could get away with that but I don't want to. Looks like I need to steam the neck off and slightly adjust.
    The DC is looking better!
    Except for this...
    Grrrrrrrr. The bridge is dead centered, I swear. But I just read about how you need to fudge the bridge to the bass side a notch when using a wrap. Looks like I need to either get an adjustable bridge OR plug and redrill.
  4. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Even so, they are still HAWT
    Happy New Year!
  5. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Hit me with it.
    How difficult will it be to get the neck off the SG? Going to do it today. It’s hot hide glue. I’m thinking a damp rag and an iron
    cain61 likes this.
  6. cain61
    cain61 Senior Member
    855
    231
    Sep 16, 2009
    What angle did you use for the neck? Can you not lower the bridge further?
  7. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Already steamed off my man :cheers2:
    Good lord that was horrifying.
    The angle was ~3°, turned out to be slightly over and no, that bridge height was with low action. I’ve already rerouted and sanded to ~2.4° And rechecked the action.
    Pics incoming.
  8. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Here it goes. An iron and a wet rag.
    I ground the end of this ruler extra slim so I could get it into the glue joints. I was even able to hammer it in and BONUS*, I could tell exactly how far in I was because the measurements were printed on it :lol:
    Lots of this. So scary to be pulling and prying on a neck. I do not want to do this again.
    I raised a little bit of grain along the way but it's off.
    Here's what it was...
    Too much. Rerouting the floor.
    After checking a couple times, I ended up with this...
    I dig it.
    Ready to be reglued. It's warming up now!
    geoffstgermaine and nuance97 like this.
  9. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Ready
    Done
    While I had the glue hot, I made some plugs
    Scraped flush and remarked, moving it over 1/16”
    Boom!
    Success!!
  10. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Wow, this place is quiet today! I'm using this day off to get some crap done, dangit.
    This guy is back in business.
    I have one bone nut blank from Stewmac which I'll use somewhere along the way but I forgot I had this.
    A scrap of Corian from a jobsite.
    It's tall enough for the nuts to be upright and wide enough for two rows. I can probably get 8 nuts from this little piece. I should've grabbed more.
    Spent some time on the belt sander getting to this.
    You all know this trick
    First time using this ruler I ordered years ago haha
    Better get some more family stuff done today. All in all, I'm really pleased. 2 major problems corrected today and then some!
    After I get two nuts going, I need to remove all the hardware, fill a few small nicks and bumps and whatnot and sand until my arm falls off. And actually, the DC's neck carve still needs some closer examination :hmm:
  11. GreaseBox
    GreaseBox V.I.P. Member
    4,625
    934
    Jan 31, 2009
    This thread makes me smile. :)
    dickjonesify likes this.
  12. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Glad to have you! Have you done any building?
  13. geoffstgermaine
    geoffstgermaine Senior Member
    386
    948
    Feb 7, 2013
    Good on your for making those corrections to the build. They look well executed and I'm sure you'll be much happier with the results. Looking good!
  14. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Thanks. I agree. I was close to leaving it (on both guitars) but I definitely would’ve regretted it in the long run.
    :cheers2:
    cain61 likes this.
  15. cain61
    855
    231
    Sep 16, 2009
    It's never better to settle. Go for the best. Looks like you did.
  16. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Trying to level some frets
    I got a couple things from Stewmac in today! Here’s my medium 3-corner file for crowning.
    Going well, I think :hmm:
    I swipe it with 400 grit and then this buffing compound. Pretty shiny results but I need to review @Freddy G ’s fret series.
    Shiny!
    Now on to some nut filing.
  17. Archer
    Archer Senior Member
    889
    450
    Apr 18, 2011
    I've been itching to build an SG for a while, so I'm enjoying the thread. But what really inspires me is how you cleaned up your work space. That's what I really need to get started on.
    cain61 and dickjonesify like this.
  18. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Thanks man! That was definitely a big step in the right direction to get my butt out there. Do it. It feels great.
    Speaking of feeling great, I couldn't resist a little jam :dude:
  19. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Question:
    Has anyone tried a hidden pickup under a pickguard? Does it work? I’d kind of like a Tele or Strat neck pickup but I don’t want to change the aesthetic.
  20. mux164
    mux164 Senior Member
    2,625
    1,879
    Sep 1, 2012
    Fender did it on a model but I don't think it was long lived, maybe the marauder but don't quote me on that
