Back to Building! Let's See What I Remember ;)
Discussion in 'Luthier's Corner' started by dickjonesify, Nov 27, 2017.
  1. dickjonesify
    dickjonesify Senior Member
    4,742
    4,615
    Apr 16, 2010
    I’m picturing these at the moment...
    Since I already have my TV Yellow.
    Satellitedog and Pesh like this.
  2. WhiteEpiLP
    WhiteEpiLP Senior Member
    1,226
    881
    Nov 29, 2012
    Aged Pelham is awesome
    dickjonesify likes this.
  3. fatdaddypreacher
    5,750
    3,768
    Feb 5, 2011
    looking good for sure. as far as finding center, i do something similar. i use a small adjustable slide square and shoot for setting the square to the center point, but if i miss it, it does exactly what you say. it gives you a double center line which creates an alley way of sorts to use as center. you got things going your way. me liking.
  4. randomguitarist
    randomguitarist Member
    93
    32
    Feb 25, 2011
    I'm liking those neck carving photos. I'm trying to get inspired to start planning a new build. This thread is definitely motivating, thx for posting it all.
  5. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Agreed :dude:
    Thanks, preach. Some things are going my way but I was looking closely at some other things and got a little discouraged. There’s plenty of ‘fixing’ yet to do on these builds. But, they will rock either way.
    You’re welcome. That’s what forums are for. I’ve been on the bench for years looking for some motivation and started visiting this forum again. Sure helps :cheers2:
  6. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Second neck carving.
    After I rough file the first facet, I use the smoother side on the next facet and it's easier to see what I'm doing...
    Lots of that. Then block sanding
    Pretty lopsided, actually. For whatever reason, this one is taking much more measuring and checking.
    Getting there
    A little Naptha
    Satellitedog and nuance97 like this.
  7. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    This Okume is pretty soft. Gonna need to steam this. Both sides of the waist have one.
    Before:
    After:
    Then I take this thing...
    And do that...
    Then I need some rosewood dust.
    And do a little of this with CA glue
    Finally got around to fixing my crappy routing. Made this slightly oversized cavity cover template.
    Then I taped the fretboard off and did some more dye. They've gotten pretty dusty in the last few years haha
    Looking good!
    kboman, WhiteEpiLP and nuance97 like this.
  8. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Today's theme. Scraping, scraping and more scraping.
    nuance97 likes this.
  9. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Ok, should've done this maaaaaaaany steps ago. It would've been so much easier. I don't have any Maple but Poplar will do. Need to switch to the bigger blade...
    Sliced off as thin as I could but it needs some serious time on the belt sander.
    Closer
    Beveling the edges
    Checking the fit
    Taped up
    Glued on
    It's like the song... "Everything I dooooooo, I do it for twooooooooo" haha
    Did I mention I was scraping? :lol:
  10. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Pain in the butt. I don't want to use the router at this point in the builds. So it's:
    1. rough cut with a saw
    2. spindle sand close to the line
    3. razor it closer
    4. scrape and sand
    The headstock needs a little thinning at this point.
  11. FF_Pedals
    FF_Pedals Senior Member
    2,125
    216
    Jan 22, 2009
    I remember watching these start. The progress is looking great. I have always wanted a Pelham blue sg standard.
  12. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Thanks. This could yet turn into a 2-pickup SG! We’ll see.
    I found a bunch of pics I took when making the SG body. Get ready for a time warp post haha.
  13. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Last day of my Christmas vacation and decided to work on... something else :fingersx:
    Haven't made templates in a long time. It was oddly refreshing.
    kboman likes this.
  14. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Ok, as promised. The origins of the SG Junior.
    *the origins of the DC can be found here*
    I found this "scrap" of mahogany at a local woodshop.
    Exactly 13" wide :shock: A little too short for an LP or that's what it would've been. I had them resaw it for me and run both pieces through the drum sander.
    Stunning wood
    I printed out the '63 Junior drawing to scale on regular paper and borderless. Worked out well, actually.
    Marked the pickup location
    And marked control locations
    Saw time
    A little tight in there haha
    Spindle sanding
    Bevelage by spindle
    And a rasp
    I found a 4" by 4"-ish Mahogany turning blank. That's where the two 1-piece necks came from. Forgot about that.
    And my last Stewmac order circa 4 years ago :shock:
    Back in this garage
    and this is about how they sat for years
    nuance97 and 61LPSG like this.
  15. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Did I mention this thread was pic heavy? :lol:
    nuance97 and WhiteEpiLP like this.
  16. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    I also built this thing just now. I was tired of my Parrot vise not being able to hold my guitar flat.
    Which goes here
    and does this...
    Very cool. But of course. Other guitars are different thicknesses and this needs to be adjustable. Oh well. Another day.
    imyourmutter likes this.
  17. WhiteEpiLP
    1,226
    881
    Nov 29, 2012
    Problem solved.
  18. nkd
    nkd Junior Member
    11
    15
    Feb 5, 2017
    More pics the better. Thanks for sharing.
  19. dickjonesify
    4,742
    4,615
    Apr 16, 2010
    Grrrrr. Frustrating day. Tried making TWO jigs for drilling perfect tuner holes. Neither worked.
    I’m going to need to ream out these holes. Having a really hard time :doh:
    :hyper:
  20. cain61
    cain61 Senior Member
    855
    231
    Sep 16, 2009
    You'll make it, man. I subscribed to make sure!
