Axe FX Footcontroller
Discussion in 'Amp Modeling' started by kfowler8, Dec 25, 2017.
  1. kfowler8
    kfowler8 Senior Member
    4,934
    4,671
    Mar 1, 2011
    Merry Christmas gents.
    What your thoughts on the Axe FX MFC-101 controller? Is it a nice to have or must have to fully unlock the Axe FX? Obviously it's a hefty chunk of change to drop.
    I've got an old Art X-11 midi controller that I've been using on my other midi rigs. Simple and works well enough. The biggest thing it lacks is any type of tap temp. That's one think I'll want to do with the Axe FX.
    Thanks,
  2. NeubyWanKaneuby
    NeubyWanKaneuby Senior Member
    1,419
    557
    Jun 21, 2008
    I have it. It didn't change my life, but it is nice to just step on the button to get the tuner.
    I'd definitely want it if I played out anywhere. Otherwise, you could probably get along with a regular midi controller, although I'm not sure which ones work with the Axe, as I haven't done any research on them.
  3. kfowler8
    4,934
    4,671
    Mar 1, 2011
    Thanks. It should work with any midi controller since it’s midi capable and has the midi jacks. I guess it’s just limited by the options on the controller.
    It would be nice if they made a smaller board. All I need when I play out are 5 presets, tuner, and tap tempo.
  4. Pwrmac7600
    Pwrmac7600 Premium Member
    8,016
    6,262
    Jun 17, 2014
    I agree, I was hoping they would eventually come out with a smaller board with built in EV1 expression pedal. Almost like the line 6 boards they sold for the POD line.
    I really wish the Line 6 board was midi so I could just pick one of those up and use it. But from everything I have read there is no way to make them work with the Axe.
    kfowler8 likes this.
  5. kfowler8
    4,934
    4,671
    Mar 1, 2011
    The Axe does have a Cat5 connection. Is it not compatible with the Line 6 boards? I think I still have the one with the volume and expression pedal.
  6. Pwrmac7600
    8,016
    6,262
    Jun 17, 2014
    I was told by numerous people over at the fractal forum that it's been tried and just doesn't work.
