Ask Grumpy Old Luthier BCRGreg Thread
Discussion in 'Luthier's Corner' started by billy, Mar 1, 2008.
  1. billy
    billy Senior Member
    1,328
    386
    Jan 24, 2008
    OKay......Ask Greg.
  2. BCRGreg
    BCRGreg V.I.P. Member
    12,490
    9,716
    Apr 2, 2007
    How can I be of service? I have extensive bench experience fixing virtually any brand and type of guitar and bass, and also do a lot of Croatian instruments like Tamburas and Brac(pronounced Brotch).
    Ask away, and I will gladly offer up my best opinion (and take swipes at Roman) without breaking a sweat.
    onegoodtrick likes this.
  3. Mr Bones
    Mr Bones V.I.P. Member
    1,097
    83
    Apr 8, 2007
    Ok, question #1. I have a korean squier telecaster that I am going to make a new body for. I don't hate the neck, so I am going to keep it, but refret it and re-camber the board to 12" radius.
    Question 1: What are the chances the fret slots are actually the right size for american fretwire? And how do I go about pulling the frets in a way that I won't have to glue the new ones in?
    Question 2: This i an all maple neck, do I just spray right over the frets and then scrape it off (if so, when do I scrape?)?
  4. BCRGreg
    12,490
    9,716
    Apr 2, 2007
    The frets slots probably won't be a problem. Remove the old frets and reradius the board. Then resaw your frets slots(the center area will be too shallow after the radius change). When you are ready to install the new frets, brush water thin crazy glue LIGHTLY into the slots and let it dry. 10 minutes should be enough. The water thin will slightly plump the grain, and then harden, giving you a better seat for the fret tangs.
    I spray over the frets and then scrape the lacquer using a nail with a slot ground in that matches the shape of the fret.
  5. pinefd
    pinefd V.I.P. Member Premium Member V.I.P. Member
    9,162
    13,432
    Mar 23, 2007
    Great idea for a thread, Greg!
  6. BCRGreg
    12,490
    9,716
    Apr 2, 2007
    I'm copying Roman.
  7. Hackubus
    Hackubus Senior Member
    443
    124
    May 26, 2007
    Got any 60s Firebird mini hum rings lying around your parts bin, GP?
  8. Mr Bones
    1,097
    83
    Apr 8, 2007
    What is the best way to remove frets from maple? just up and out? (never done a refret before, only a fret)
  9. Csharp
    Csharp Senior Member
    979
    103
    Dec 31, 2007
    While we're talkin' maple, How do I get residual black paint out of end grain without sanding away the shape that I'm trying to preserve? It was a painted, large Strat' headstock that I've stripped and cut down to the smaller profile. The problem area is above the nut, either side of the truss rod.
    Will stripper draw it out?
  10. BCRGreg
    12,490
    9,716
    Apr 2, 2007
    Jay, call me. I may.
    Removing frets on imports with maple boards is difficult but doable. Heat them with a soldering gun until the finish starts to get shiny around the fret. While it's warm, gently lift each end and work across to tickle it out. When all of the frets are out, if you are keeping the finish, level sand the board with 1000 grit dampened with alcohol to get rid of scooters. Install the new frets, wipe the board down with naptha to remove any grease or fingerprints and lightly spray a reduced coat of finish to flow out the scuffed lacquer on the board. Scrape off the frets carefully and you are done.
    Now, if you are refretting a board with finger digs through the finish and you want it to stay looking played, paint the gouges with paste wax before spraying the finish, and then after the lacquer dries you can just wipe away the wax/finish crap and you still have the wear marks!
    monsterwalley and free2rock like this.
  11. BCRGreg
    12,490
    9,716
    Apr 2, 2007
    Zip Strip. Use Q-tips and apply it, heat lamp it to warm the area(but not so close that you evaporate the stripper). 3 or 4 applications (wiped clean in between) will get the majority of it. If you have to, rub a little tan paint across the area before finishing, the tan will soak into the endgrain and minimize the black.
  12. Roman
    Roman Master Luthier V.I.P. V.I.P. Member
    6,688
    5,754
    Dec 4, 2007
    Mind if I jump in here Greg??
    70s fender frets were "slid in"
    They pushed them into the slot from the side marker side.
    To get them out without ripping up the maple, you dremel a place to dig into the fret and hammer them out in the same direction they were installed with a small dull chisel.
    I'll let Greg elaborate
    :naughty:
  13. BCRGreg
    12,490
    9,716
    Apr 2, 2007
    Yeah. He's doing an import, Greyman!
    50's to 70's Fender frets are better left to pros.
  14. Roman
    6,688
    5,754
    Dec 4, 2007
    ok, baldingman:naughty:
    My bad, I didn't read the whole thread
  15. BCRGreg
    12,490
    9,716
    Apr 2, 2007
    Tell whoever you pay to read this stuff to you that you expect better.
  16. Roman
    6,688
    5,754
    Dec 4, 2007
    Yeah, I am going to have to give Amber crap.
  17. BCRGreg
    12,490
    9,716
    Apr 2, 2007
    you Be Nice To Her, Boy!!!!!
  18. Csharp
    979
    103
    Dec 31, 2007
    Hey! What's Roman doin' in YOUR thread?
    Thanks for the advice, Greg, eye-uh-pre-she-ate-it.
  19. Axeman16
    Axeman16 V.I.P. Member
    2,672
    279
    Jul 2, 2007
    question about pots. i recently got an orville, but it has small 14mm 500k pots in it. so im thinking of changing to full size, but will the 24mm pots make a difference in tone even though they are the same value? also does gibson use 300k or 500k pots in their les pauls?
  20. BCRGreg
    12,490
    9,716
    Apr 2, 2007
    CTS.
    Period.
    I use Hamer's custom taper 500k pots for the volume and regular CTS 500k for the tone.
    CTS uses a wider carbon path than those teensy crap pots, so they are smoother and more progressive.
