Are Custom Buckets Really Using A3 Mags
Discussion in 'Pickups' started by GT40, Jul 26, 2017.
  1. GT40
    GT40 Senior Member
    177
    285
    Jul 1, 2017
    I always thought that A3 were weaker mags with lower output. But the Custom Buckers in my RI kick ass like a pair of mofos into my PRRI.
    The DCR is around 8K on each one so not really high winds.
    I'm surprised.
    And Grrrrr to the spell check on the thread title
  2. ARandall
    ARandall Senior Member
    11,526
    6,777
    Apr 16, 2012
    A3 is wildly misrepresented. Not to mention there is not just 1 grade (like all other mags the actual casting varies considerably between suppliers).
    And mere strength of the magnet seems not to be directly related to output......as in there I've found the swapping from various alnico grades tends to be an eq thing rather than pickup strength.
    I have many different pickup types with A3 and save needing to be slightly closer to the strings I find no appreciable strength dip in any of them - and some read low K by comparison to similar type with stronger mags.
    GT40 likes this.
  3. Mr Alarm
    Mr Alarm Senior Member
    151
    36
    Sep 10, 2013
    I have thought that it the secret is to compensate the magnet's weakness with higher DC value. I have tried A3's in many 'normal' PAFish pickups, but since their DC velies are around 7,5~ they have sounded lively but thin and weak.
  4. LtKojak
    LtKojak Senior Member
    3,960
    2,596
    Aug 26, 2009
    Which p'ups have you tried in? Neck or Bridge?
    I can understand if you talk about bridge p'ups exclusively, mind you, but I ask 'cause that's not been my experience at all with neck p'ups.
    Care to share?
  5. Mr Alarm
    151
    36
    Sep 10, 2013
    It was in the past so now I should remember some details, hmm!
    Mostly Gibson pickups and for the neck position: 490T, Burstbucker 1, Classic '57. But also some Seymour Duncans, at least SH-1N. None of the swaps were convincing.
    Now I have a Gibson humbucker (apparently Custom Bucker or some kind of MHS pu) in an ES-175 1PU which reads about 8kohm but since it has A3 magnet it sounds open and balanced.
    Or maybe the reason to these findings is the nature of that particular guitar in which I tested these, not the Alnico/DC -relation?
  6. Guitar Rod
    Guitar Rod Senior Member
    1,433
    683
    May 29, 2016
    I love my Custom Buckers. As you say, both 8k and open and airy. But as the OP said, they have an amazing aggressiveness to them with gain. Sound higher output than they are. And even though they are the same output, they are very well balanced between neck and bridge.
  7. framos
    framos Senior Member
    920
    707
    Oct 9, 2008
    The Duncan Bonamassa Skinners set was the first A3 pickup I have ever tried. I love how they behave under gain, very agressive, lots of bite (to my surprise).
    Not only it stayed, but another set arrived a few weeks later.
    Not very fond of the CBs, though.
    BlueCajun likes this.
  8. Zhangliqun
    Zhangliqun Senior Member
    1,595
    747
    Apr 10, 2007
    Going by sound, if they're weaker than A2, it's not by much, and even that is probably just the slight drop in low mid.
  9. riffsmachine
    riffsmachine Senior Member
    640
    451
    Sep 18, 2010
    Exactly what I was about to write! A kind of mirror post :laugh2:
    framos likes this.
  10. Antigua
    Antigua Senior Member
    452
    103
    Oct 15, 2016
    A3 tends to have a lower Br value than A2, but they're close enough that it should be difficult to actually perceive an output difference. You can surely overcome the small difference just by raising the pickups a little. A5, by contrast, is much stronger and A2, A3 or A4, and then ceramic or A8 is much stronger than A5.
  11. ARandall
    11,526
    6,777
    Apr 16, 2012
    ^ And this is essentially what you do with A3 pickups, have them very slightly to a fair bit closer to the strings.
  12. LtKojak
    3,960
    2,596
    Aug 26, 2009
    That's a pretty accurate description, with the added tightness of lows, overall clarity and note separation, not to mention added response to picking dynamics.
    The A3 mag revealed itself as the perfect mag for a Duncan '59n that, in conjuction with pairing it with an A2 mag for the '59b, this A3/A2 mod makes this p'up set the arguably best-sounding "non-breaking-the-bank" set in the market today for a LP and/or 335, specially if provided with nickelsilver covers.
    I have this very modded set in my current #1 instrument for a Smooth Jazz project, an Epi 339 Pro, and even I was surprised to find out how they sounded and felt so good in this specific context, although I can very well imagine being quite the perfect solution for the enormous Blues-playing, vintage tone-loving crowd that's not completely at ease with their own p'ups.
    Highly recommended, folks.
    HTH,
    framos, Mr Alarm and ntotoro like this.
  13. Zhangliqun
    1,595
    747
    Apr 10, 2007
    Be careful choosing the covers -- most are tone-killers, especially in the neck!
