Anyone heard of a Volume Box Attenuator
Discussion in 'eBay Deals' started by Fretboard, Aug 20, 2009.
  1. snaredrum
    snaredrum V.I.P. Member
    23,056
    13,771
    Feb 14, 2009
    i can't see how you're risking anything apart from the attenuator. i run my 50w amp at about half stretch on the power tubes with an output leash, and it's awesome. there really isn't any sound like power tubes stretching out.
    if my amp blew from being run at half stretch it'd be a sad thing...
  2. Fretboard
    Fretboard Senior Member
    374
    9
    Jan 5, 2009
    What would I tell the guy if I wanted the same setup as you?
  3. Fretboard
    374
    9
    Jan 5, 2009
    Also I am runing it through 4 different speakers so how would it work with that?
  4. snaredrum
    23,056
    13,771
    Feb 14, 2009
    i presume the amp you want to use it on has an 8 ohm speaker output, right? get one of those, and ask him if he could make you a wire to go from the tamer to the speaker. he hooked me up, so you never know, he may hook you up too :thumb:
  5. snaredrum
    23,056
    13,771
    Feb 14, 2009
    in that case, you are using a 1/4" speaker cable to go from amp to cab, right?
  6. AngryHatter
    AngryHatter Senior Member
    17,185
    13,096
    Jun 19, 2009
    In my super six when the channel volume is on 10 all the tubes are burning at max.
    Even when the master is on 2.
  7. 970harris
    970harris Senior Member
    925
    420
    Mar 21, 2008
    Snaredrum, thanks for this post. For $55, I am taking a swing at an Output Tamer as a backup for my Ultimate Attenuator. Be interesting to see the tonal comparison between the $55 unit and the more expensive solution. Thanks again...
  8. snaredrum
    23,056
    13,771
    Feb 14, 2009
    good for you, man. i'd love to see what your opinion is of the cheap versus the expensive. i took a punt on the cheaper option to go with my cheap guitars and cheap amp, and am very happy.
    thanks for the thanks!
    :thumb:
  9. monroe
    monroe Senior Member
    1,276
    9
    Mar 14, 2008
    Re: "burning"... The heater current does not change, it's always 6.3 VAC
    Check a schematic for your Super Six (same as Master Volume Twin Reverb and Master Volume Dual Showman) and you'll find the master volume is before the inverter tube (V6). Fact.
    Super Six Schematic
  10. singlecut
    singlecut Senior Member
    7,960
    6,150
    Jul 11, 2007
    i agree, used 1 with a hot rod deluxe with great results
