Any substitutions to soldering pickup covers?
Discussion in 'The Custom Shop' started by The Notorious DJ, May 5, 2017.
Tags:
  1. The Notorious DJ
    The Notorious DJ Member
    35
    26
    Jan 18, 2017
    Hey MLP! This is probably done a million times but I'm still HELL new to guitar and after 5 months I'm finally ready to make my first mod.
    I want to change my pick-up covers on my 335 to some gold metal ones I purchased which means I'm going to have to solder them. But my friend was telling me he just uses a silicone/adhesive in place of solder. I know that not soldering will likely cause grounding issues but he says he doesn't occur them.
    Is this a good method? Are there any good methods in replacement to soldering? Or because it's a metal cover I'm left with no choice?
    pillbug likes this.
  2. T00DEEPBLUE
    T00DEEPBLUE Senior Member
    381
    346
    Nov 25, 2014
    He must've been referring to applying a small amount of silicon on top of the pickup coils before fitting the replacement cover to prevent microphonics caused by the cover vibrating. You'll want to do that regardless of whatever you choose to do.
    Buy a soldering iron and do the job properly. They're ubiquitous tools that everybody who works on anything electronic should always have.
    yamariv likes this.
  3. Sct13
    17,289
    20,543
    Sep 18, 2011
    If you bend the sides in slightly you won't need to solder them, they sorta snap right on...I place masking tape on the inside, I suppose you could use double sided tape instead...but they stay put.
  4. moreles
    moreles Senior Member
    2,874
    1,517
    Apr 16, 2011
    Solder it. And do the silicone thing. Unsoldered covers can become microphonic in a really ugly way, and more importantly, signal and ground continuity is really important, and you should never rely on friction or simple physical contact alone. Just do things right. If solder wasn't really necessary and advisable, the budget builders would leave off that step, but they all do it because it's necessary.
    The Notorious DJ and yamariv like this.
  5. blackat
    blackat V.I.P. Member
    1,169
    983
    Nov 21, 2010
    Jim from WCR pick ups says silicone alone is just fine.
    I have done it that way with no problem
    rockstar232007 likes this.
  6. ARandall
    ARandall Senior Member
    12,016
    7,484
    Apr 16, 2012
    ^ And other winders say solder.
    And people have had issues especially at high volume with covers. Silicon is often not a fantastic glue.
  7. Have FUN
    Have FUN Senior Member
    1,451
    1,495
    Apr 27, 2011
    You can use double sided tape but soldering is stronger.
  8. The Notorious DJ
    35
    26
    Jan 18, 2017
    Ok thanks guys, I found a soldering gun at a local hardware chain for $20 so can't go wrong. Just seems a bit of a pain that everytime you want to change the cover you need to solder it. Does double sided tape really work?
  9. chasenblues
    chasenblues Senior Member
    21,202
    31,895
    Apr 2, 2007
    If the wattage is to low it can be frustrating.
    How often do you plan on changing the covers?
    northernguitarguy likes this.
  10. The Notorious DJ
    35
    26
    Jan 18, 2017
    Just once hopefully, what I meant was just in general
  11. T00DEEPBLUE
    381
    346
    Nov 25, 2014
    Meh, not really. It's easy to do and it isn't like you're going to be doing it very often.
    And you really ought to get a soldering iron if you don't have one anyway. They're ubiquitous tools in guitar repair. A 40 watt iron is fine for general purpose.
  12. blackat
    1,169
    983
    Nov 21, 2010
    Whatever. Pup covers weigh soooooo much.
    Silicone works just fine and is also an adhesive.
    I really don't care what anyone does but to say silicone doesn't work or isn't a good way is wrong.
  13. guitarjoem
    guitarjoem Double Platinum Supporter MLP Vendor
    497
    258
    Dec 15, 2014
    Gaaaaahhhh!!!! The cover is metal. It should be properly grounded, It is NOT a question of adhesion, or snapping the cover in place, or any of that! Silicone simply helps to dampen vibrations of the cover. Solder it. Jeez.
  14. pedecamp
    pedecamp Senior Member
    142
    91
    Jun 29, 2013
    solder the covers on and wax pot the pickups. Job is done right and will sound good.
  15. Sct13
    17,289
    20,543
    Sep 18, 2011
    Right, they should be grounded, cant argue with physics ....but I have never had any extra noise that wasn't "normal" from a loud Marshall....
    I didn't say this earlier, should you choose to solder your pickup covers on, make sure to use flux sparingly, and be very careful,NOT allowing the solder to drip onto the coils, you'd short it out forever....especially on a non potted or one with compromised tape.
    Good Luck
  16. blackat
    1,169
    983
    Nov 21, 2010
    Gaaaaahhhh.
    Your pups are already grounded.....
    Triple ground them.
  17. Freddy G
    Freddy G V.I.P. Member
    11,341
    23,660
    Mar 18, 2007
    yes the pickup may be grounded but soldering the cover to the pickup guarantees that it is also grounded and providing shielding.
    guitarjoem likes this.
  18. renegade87
    renegade87 Junior Member
    20
    14
    Jun 16, 2016
    For the sake of The Notorious DJ and others considering the same thing, I'd like to help save you some time, trouble and possibly money. Just to remind everyone here that the pickup manufacturers are using lead free (ROHS compliant) solder to attach the pickup covers (which at 219-221c has a much higher melting point that typical 63/37 tin lead solder -183c). And they're not shy about using it either. On a typical Humbucker you not only have the cover acting as a heatsink, but the baseplate as well. Evenmoreso in fact. Which will make it very difficult to get that solder to reflow and ultimately allow you to separate the cover from the baseplate it's soldered to. So basically, if you plan on doing more cover swaps in the future (or other heavy duty soldering), then invest in something other than the 40 watt special at Home Depot or Lowe's (which should be fine for most of your basic wiring related soldering duties. Especially with 63/37 tin lead solder). Otherwise, your local luthier should have a good Metcal, Pace or other similar professional soldering system that will do the trick. Or, if you know someone in electronics manufacturing who does rework for a living, even better!
  19. Sct13
    17,289
    20,543
    Sep 18, 2011
    Good info !!
    I use a razor blade ....heat the area and shove the blade between cover and the pick up
    guitarjoem and renegade87 like this.
