Any ideas on how to keep the G string in-tune w/Bigsby?
Discussion in 'Gibson Les Pauls' started by Wyatt Earp, Jan 12, 2019.
  1. Wyatt Earp
    Wyatt Earp Member
    64
    74
    Jan 3, 2019
    So, I've taken my Bigsby B7 on and off of my LPC twice now. I can't seem to keep the G string from going out of tune. Actually, it goes out of tube without the Bigsby. The tuners are Schaller clones of the original Grover Rotomatic tuners. I don't recall ever having and issue with the stock tuners, but I know the German made Schaller's are some HQ tuners. I'm just sort of stumped on what's causing it.
  2. Jymbopalyse
    Jymbopalyse Senior Member
    2,966
    6,218
    Oct 3, 2016
    Just for shits and giggles,
    Replace the nut. It's not that expensive, or difficult.
    If you are near a good Luther, have a custom nut made.
    XpensiveWino and Wyatt Earp like this.
  3. ARandall
    ARandall Senior Member
    12,462
    8,076
    Apr 16, 2012
    The nut will be the culprit if your are not using the trem.
    But for a Bigsby in use, a roller bridge is almost a must.
    Juan Wayne and Wyatt Earp like this.
  4. Roxy13
    Roxy13 Senior Member
    4,348
    15,302
    Dec 27, 2017
    Wyatt Earp likes this.
  5. Wyatt Earp
    Wyatt Earp Member
    64
    74
    Jan 3, 2019
    Thanks! I have a bone nut in my stash, but it would need string slots cut into it.
  6. Renegade
    Renegade Senior Member
    144
    164
    Nov 26, 2011
    The nut seems to be the culprit on a lot of tuning issues...I have had pretty good luck with folding a small piece of 1500 grit sandpaper in half and using it to just polish the nut slot.
  7. Roxy13
    4,348
    15,302
    Dec 27, 2017
    ABM has gold roller nuts, too. I just wasn't sure if they were the right width for LPs, but you could check. With those you definitely want the exact width since filing the metal would be a problem.
    A good luthier should be able to cut you a bone nut with proper slots.
  8. Cjsinla
    Cjsinla Senior Member
    3,710
    3,050
    Jul 7, 2014
    Just widen the G string slot a little before you try replacing the old nut, easier to work on one slot than 6 new ones. And, the other posters are right, it’s usually the nut and almost never the tuners.
    PierM likes this.
  9. Les Paul John
    Les Paul John Senior Member
    892
    1,451
    Jun 26, 2018
    Three things.
    Good nut self lubricating or yourself
    Locking tuners
    Roller bridge if you don’t wish to make unGibsonified looking - or lube the roller tension bars on the trem itself. I use sewing machine oil. 3 in 1 oil etc.
  10. 1all's Pub
    1all's Pub Senior Member
    3,403
    3,474
    May 26, 2015
    I put one of these on my Epi Johnny A Custom and it really helped tuning stability a lot!
    https://bricksbiggsfix.com/
    Super nice guy to deal with too.
  11. TradPro2
    TradPro2 Senior Member
    310
    257
    Oct 23, 2014
    While I do not have a Bigsby installed, I do have both a roller bridge and roller nut.
    The roller bridge is around $30 and the roller nut $50, think about it - NO stickshun anywhere, all string ride on
    turning little rollers, impossible to bind, stick, tuning stays put, period, honestly these are best upgrades
  12. Subterfuge
    Subterfuge Senior Member
    1,026
    1,469
    Aug 18, 2017
    don't Bigsby's stay in tune better with flat-wound strings??
  13. Rob the Photog
    Rob the Photog Member
    41
    61
    Jun 22, 2013
    I feel your pain, I always have a problem with my G-string slipping! :Ohno::rofl:
    All joking aside, I just picked up a set of Mitchell Abrasive Cord from StewMac. I was having a similar issue; my G string would often slip out of tune while playing, and had that "ping" sound when re-tuning that indicates the string sticking/binding in the nut slot. I ran a little bit of the abrasive cord back and forth through the G string nut slot a few times (a lot like flossing), and it really did the trick - no more "ping" noise, and the tuning holds steady! Maybe it'll work for you, too? Maybe not, but I feel like it's a handy thing to keep in the tool box, and it's MUCH cheaper and easier than replacing the nut, or even re-filing the slot.
    Just my 2 cents, and I hope it helps!
  14. Thunder Dump
    Thunder Dump Premium Member
    4,643
    6,551
    Mar 10, 2009
    1. Replace nut
    2. Enjoy Bigsby
  15. TradPro2
    310
    257
    Oct 23, 2014
    We are really talking about sticking to the bridge or nut, that round wound strings have a problem with.
    Round wound strings are smooth and do not have that sticking problem I play GHS 9-42 round wounds, love em.
  16. zombiwoof
    zombiwoof Senior Member
    401
    303
    Feb 24, 2008
    One string going out of tune is not a Bigsby problem IMO, you just need to have the nut worked on so the string doesn't bind. Bigsby's DO need frequent lubrication at all points of contact and moving parts, it's just regular maintenance.
    Al
    Les Paul John likes this.
  17. scozz
    scozz Senior Member
    3,966
    4,843
    Sep 3, 2007
    Yeah,.....get rid of the Bigsby!
    (I’m sure @Christosterone would disagree!)
  18. Frogfur
    Frogfur Senior Member
    19,184
    33,813
    Jan 18, 2013
    There is no issue with your G string that pertains to a bigsby.
  19. Kaicho8888
    Kaicho8888 Senior Member
    754
    358
    Jul 27, 2008
    As many say... If your G string gets into a bind, adjust your nut slot. :cheers2:
    Side note:
    Many times the G string does not sound correctly in tune with respect to other strings as you go up the fretboard. If this is a perceived problem, try to tune the open G a percent lower than what your tuner indicates.
    :band:
  20. Axis39
    Axis39 Senior Member
    1,013
    513
    Dec 1, 2009
    Most tuning issues are the nut, as other have stated. But, you should also try to load as few wraps as possible on the tuners. Having a bunch of strings allows it to loosen up and reseat every time you push down and let up on the Bigsby.
    I really recommend using the string wind that works like a knot... You slip the end of the string through the tuner. Wrap the loose end back around the tuner shaft the wrong way. Then, tuck it under the string coming from the nut, and bend it up tightly. Then tighten the tuner. This keeps the end of the string tightly tucked under the string under tension. You can literally use less than a whole wrap of string and it will hold and stay solidly in tune.
    https://reverb.com/news/how-to-change-electric-guitar-strings
