Any Bugera G5 Infinium owners? Effects loop question
Discussion in 'The Squawk Box' started by lespaul89, Sep 18, 2017.
  1. lespaul89
    lespaul89 Senior Member
    154
    40
    Nov 1, 2011
    Hi,
    i have a G5 Infinium which does the job fine for what i need but today i've been trying to add some pedals through the effects loop and it literally will not work at all, when i plug into either the send or return it completely cuts the sound of the amp, i've tried different pedals and cables etc. so just wondering does anyone have any suggestions?
    Thanks
  2. apfelbaum
    apfelbaum Senior Member
    158
    203
    Sep 28, 2016
    I have one of these, the effects loop works fine. Make sure you are hooked out of the send to your pedal in and the out to the return. Maybe try the db adjustment that helps with pedals that have lower or too high output. Send a pic of your cabling and I'm sure someone can help figure it out.
  3. lung plunger
    lung plunger Senior Member
    775
    1,043
    Mar 20, 2017
    The signal has to go from send, thru the pedals, and from the pedals back into return. Double check the orientation of the pedals input/output as well.
  4. lespaul89
    154
    40
    Nov 1, 2011
    cheers for the input, i'll have an investigation and report back
