Amps 101...A How To For Everything Amplified
Discussion in 'The Squawk Box' started by rocknhorse1, Mar 24, 2011.
  1. rocknhorse1
    rocknhorse1 Senior Member
    8,780
    2,757
    Feb 22, 2010
    Someone asked for an "Amps 101" thread. Well I saw this posted somewhere else and thought it would do someone some good. There is a lot of reading, but pretty much everything you would need to know about tube amps, and how to use them....good luck!
    Guitar Amp Tone and Effects Placement
    I am going to add this link too. Lots of good stuff here as well!!
    http://www.harpamps.com/micKdiy
    herbalist, Frankg11, 12Rant and 63 others like this.
  2. rocknhorse1
    8,780
    2,757
    Feb 22, 2010
    Only 7 views? Sure glad I didn't take the time to type all that out myself, LOL!:laugh2::laugh2:
    Udonitron likes this.
  3. b-squared
    b-squared Banned
    21,123
    9,172
    Jan 21, 2008
    Thread is stuck...we'll see how the response is...thanks for the post!
    BB
  4. rocknhorse1
    8,780
    2,757
    Feb 22, 2010
    Sweet BB!! Hopefully someone will benefit. There is a lot of info there.:naughty:
  5. acstorfer
    acstorfer Senior Member
    19,608
    21,126
    Oct 21, 2008
    Wow, tons and tons of interesting stuff!
    Thanks
  6. rocknhorse1
    8,780
    2,757
    Feb 22, 2010
    I just added another great link to the original post. :thumb:
  7. rocknhorse1
    8,780
    2,757
    Feb 22, 2010
    I wish I could add this to the OP because it's a really good way to learn what certain value caps and resistors do in certain spots of the circuit of the amp. It tells you the exact affect it will have on what part of the sound, and is explained in a way even a novice like me can understand it.
    Modifying Guitar Amp Preamp Circuitry
    here is a link to the main page
    Regis Coyne's Tech Page
    JeffBlue likes this.
  8. Lurko
    Lurko Senior Member
    5,429
    7,147
    Jan 12, 2011
    Great link. Bookmarked. Thanks!
  9. rocknhorse1
    8,780
    2,757
    Feb 22, 2010
    This is a great link that Liam posted for a tone stack calculator to see what frequencies your tone stack operates at. This is great information to have in your head, especially if you are running an EQ pedal in the chain. This way you are not boosting, and cutting the same frequencies...kind of redundant, and canceling each other out. Or for just knowing what you are boosting or cutting period.
    The program is free, and takes up little space. Enjoy, and thanks to Liam! :thumb: TSC
  10. rocknhorse1
    8,780
    2,757
    Feb 22, 2010
    Here is another really good page for learning about amps. Some stuff you may know, some may be new to even an old amp "Veteran".
    Click on the different categories under where it says "Guitar Amplifiers" in the menu in the upper left of the page...really cool stuff. :naughty:
    http://www.gmarts.org/index.php?go=210
    Joe Dirty likes this.
  11. Thumpalumpacus
    Thumpalumpacus Senior Member
    76,014
    186,253
    Nov 28, 2010
    Subbed. Thanks, 'Horse.
  12. sonar1
    sonar1 Senior Member
    16,488
    59,313
    Apr 7, 2011
    Thanks.
    Wealth of good links too inside some of these links.
  13. GuitarMechanic
    GuitarMechanic Senior Member
    952
    449
    Dec 9, 2010
    Yes that is awesome and pretty easy to understand for sure
  14. Mookakian
    Mookakian Senior Member
    6,248
    2,363
    Jan 18, 2010
    I will get lost in this:D Thanks rockinhorse:thumb:
    rocknhorse1 likes this.
  15. rocknhorse1
    8,780
    2,757
    Feb 22, 2010
    Well enjoy guys! :thumb:
    There is so much stuff here it takes a while to read it all, and as said, there are several other links within these links.
    If you had a specific question about something, I would search for just the answer to that question. Whatever else you learn along the way is gravy.
    Here is another link that should be on this page. It can get a bit technical, and I have had to read some things more than a few times to understand them, but the info is spot on and from a very respected guy in the amp world, Randal Aiken...check it out. It's a "question and answer" type of format.
    Tech Info
  16. Newcom
    Newcom Member
    66
    9
    Nov 18, 2010
    great read
  17. rocknhorse1
    8,780
    2,757
    Feb 22, 2010
  18. 2themax
    2themax Senior Member
    662
    262
    Sep 26, 2011
    This is great thread, thanks RH1
    After about a fifteen year break I've been playing regular again and just can't seem to get a repeatable sound that I'm happy with. I know that part of the issue is my guitars have minor issues that are being resolved slower than I'd like but they are quality instruments and should be able to get something close to a decent tone. I rarely use pedals and basically stick to the canned amp sounds on my VT's.
    My old 70's gear is long gone and now I've got a couple of Vox ADVT's (a 30 & 50, the 50w I keep just in case a band gig happens :D), a Vox AC4TV head with a 12" Egnator cab, and a fender Frontman 25r. All I can figure is that I haven't really worked with these amps enough to learn how to fine tune them - the Fender seems to be the most consistent for a decent tone at low volumes. The Vox VT's are all over the place, sometimes they sound great, sometimes you can't buy a good sound. The AC4 is pretty marginal on the 1/4w and 2w settings (could be the 12" speaker cab), on 4w it's acceptable but the sweet spot is from 1/2 vol and up which is pretty loud (for something I bought to use as a bedroom amp).
    I think that playing again now without the "extra-curricular activities" :slash: of the old days my older ears may not be as sharp but they are more selective. And age has taught me that the issue is probably with me, not the amps -
    Thanks dude for the informative thread, these links should be very helpful...
    :dude:
    2 people like this.
  19. Max_
    Max_ Senior Member
    114
    54
    Aug 13, 2011
    Bookmarked!
  20. rocknhorse1
    8,780
    2,757
    Feb 22, 2010
    No problem guys. I have been adding some stuff as I find it.
