Amp drive or pedals ?
Discussion in 'Tonefreaks' started by Mockbel, Oct 11, 2017.
How do you get your dirty sound?
  1. Amp dirty channel exclusively
    30 vote(s)
    31.9%
  2. Pedals exclusively
    14 vote(s)
    14.9%
  3. I can't live without both
    50 vote(s)
    53.2%
  1. Mockbel
    Mockbel Senior Member
    2,443
    2,292
    Nov 2, 2015
    Hi guys.. it is a simple poll just to get an indication how majority of people do... and accordingly, I may change my current setup :D
  2. StillLearning
    StillLearning Senior Member
    1,014
    957
    Dec 2, 2014
    Need 4th option for depends on my mood...I tend to be moody
  3. ARandall
    ARandall Senior Member
    12,101
    7,588
    Apr 16, 2012
    For the volumes I play at the amp drive is slayed by pedals.
    bulletproof and I Break Things like this.
  4. Mockbel
    2,443
    2,292
    Nov 2, 2015
    So you can't live without both !
    I didn't mean that it is necessarily you are using both at same time !
    StillLearning likes this.
  5. T00DEEPBLUE
    T00DEEPBLUE Senior Member
    386
    355
    Nov 25, 2014
    I do both. Namely using a Green Rhino as a clean boost for my 5153 when nailing a tight progressive metal tone. I think most people here are going to say that they use both.
    I think the question you're asking is too simplistic for any information to come out of it to be very meaningful. More often than not, people are aiming for a different tone to what you're aiming for and they're doing it with different gear. So unless they're coincidentally aiming for the same tones you are and they just so happen to have the same gear as you, what they do is unlikely to be indicative of what you should be doing.
    I think your answers are going to be more meaningful if you give the question some context. "Do you use a drive pedal or just the amp by itself when nailing a SRV-style tone and why?"
  6. Thumpalumpacus
    Thumpalumpacus Senior Member
    76,014
    186,241
    Nov 28, 2010
    Depends on the amp. Some amps give me the goods without help ... others, not so much.
  7. mmd
    mmd Senior Member
    2,460
    2,401
    Sep 24, 2012
    My preference is to always work with what the amp provides first. I can usually get to 95% of what I want to hear straight from an amp. From there I will add a boost of some sort, more often than not an MXR DynaComp set like this:
    Works well with pretty much every amp. Of course, small tweaks need to be made for different amps. I leave the DC on all the time. It's just part of the sound. If I need to add a little more gain for leads or whatever, THEN I go to an OD pedal - but MOST of the time the DC hitting the front of a driven amp gets me where I need to go.
    These days there are too many flavors of OD/Dist. It takes forever to find one that matches well with EVERY amp....
    Mockbel likes this.
  8. Alderbeck
    Alderbeck Member
    84
    72
    Mar 10, 2012
    I think a lot of people may be turning to the sound alike options amp sims give you now. I have the boss katana 100/212. With it you get tone studio and you can download a sound a like option to put in a preset on your amp. So for example you can download a set of hendrix tones one of which is called " purple fog " and in seconds you have a tone that mimics exactly the setup hendrix had for purple haze. Unless you like the challenge of twiddling knobs and experimenting this is the way to go. Personally I want as much time on playing my guitar rather than spending too much time trying to get the sound right from scratch.
    mmd likes this.
  9. penguinchit
    penguinchit Senior Member
    1,564
    1,722
    Jul 20, 2015
    All pedals for me. I can't play loud enough to get that great grit sound, so I rely on pedals. I have a mean clean tone though!
  10. freefrog
    freefrog Senior Member
    1,251
    697
    May 21, 2011
    I do both.
    I also tend to play the game according to my own rules: diverting the logic of FX send/return and the stereo capability of some MFX's, I use the preamp of a Marshall amp as a kind of big dirt box feeding the guitar input of other amps, in order to have a stereo signal... Obviously, it requires some level matching and EQing but it works well enough to be one of my main tricks on stage for 10 or 15 years now.
    EDIT - I also use amp modeling but only if the situation allows to coax good tones (a modeler plugged in a crappy local PA can be extremely frustrating IME/IMO).
  11. bossaddict
    bossaddict @david.beason on IG Premium Member
    6,695
    8,906
    Apr 4, 2013
    This is pretty much me as well. I'm currently using a Marshall Astoria Classic (no built-in drive) with the KoT, Spark Mini, and (occasionally) Sunface for my dirt signal. I use a completely different amp for cleans.
  12. gball
    gball Senior Member
    609
    525
    Feb 23, 2016
    I get the vast majority of my gain from my amps (both Mesa Boogies, so they have more than enough gain), but there are times when I use a pedal in front of the clean channels to get a certain texture, usually when I need something low-to-medium gain.
    Mockbel and mmd like this.
  13. northernguitarguy
    northernguitarguy SWeAT hOg
    28,651
    47,846
    Feb 22, 2009
    I get my dirt in three ways. I keep my Orange Tiny Terror set at medium gain (noon). I will use this for a moderate Rock distortion. When I want a bit more, I use my Bad Monkey OD or Soul Food pedal to goose the TT. If that isn't enough, or I want a bigger low end sound, I run my Cornish G2 clone through my clean VOX Night Train.
    Dun Ringill and Mockbel like this.
  14. Tobin1634
    Tobin1634 Senior Member
    736
    515
    Oct 4, 2016
    I get the pedal thing, but I feel like a good rock amp should have good distortion on its own! Like a marshall! though I know plenty use drive pedals with them..
    Benjammin and mmd like this.
  15. mmd
    mmd Senior Member
    2,460
    2,401
    Sep 24, 2012
    An add-on to what I said earlier....
    I never try to get an amp to do something it is not designed to do. If I want balls-to-the-wall gain, I will go to an amp that does that. If I want classic jangle, I don't try to play a 5150. If I want a clean amp, I will play a Fender.
    At one point I kept 35 amps around for varying uses, volumes and genres. I am aware not everyone can do that (or wants to). My main point is to start by looking at the tool (amp) you are using to achieve "X" sound.
    I spent my early years using Fender amps (could get Fender heads all day long in the pawn shops for less than $200) to play metal. I was using multiple gain pedals to get over the top distortion (my thrash and death metal days....87-90). It was "ok" at best. I never sounded as good as the guys using amps that were DESIGNED for extreme music. Once I started moving up the "food chain" and got a Mesa and then my Rivera I was in a better place for distorted tones.
    Even today, my Rivera still sounds better using the natural gain characteristics over hitting the front with different drive pedals. However, my Fenders always sounded AWESOME with drive pedals.
    What is your current rig, and what are trying to achieve?
    Mockbel and zamdrang like this.
  16. zamdrang
    zamdrang Member
    91
    125
    May 2, 2009
    I prefer the grit comes from the amp. I have always felt pedals were to augment tone not be the tone. Over the years more and more I have noticed the idea that the only way to get good tube amp drive is to turn it up, and if you can't do that you rely on pedals. To me that sounds like an idea put forth by pedal manufacturer propaganda and the rise of lunch box amps with power attenuators a' la EVH.
    Don't get me wrong power tube break up IS great, but it's not the be all end for grit/gain. An amp with a well designed pre amp (geared towards such a thing) still kills any pedal i've heard and doesn't have to get you evicted to do it. Pedals have their place but they still sound like pedals....to me.
  17. lung plunger
    lung plunger Senior Member
    800
    1,041
    Mar 20, 2017
    I run my spitfire clone dimed. It doesnt get heavy saturation, but thats what my germ fuzz is for.
  18. Bobby Mahogany
    Bobby Mahogany Senior Member
    20,470
    29,630
    Feb 25, 2012
    Both.
    If you can "open" the amp, fine.
    Then you can also kick it with a pedal for solos.
    If volume is an issue, no choice but pedals.
    azzapeel and northernguitarguy like this.
  19. freefrog
    1,251
    697
    May 21, 2011
    FWIW, something like the Blackstar HT-Dual fills the gap: it is a 300v powered tube preamp in a pedal and it sounds as such IME/IMHO (even if it's not a "pure tube drive" unit; but after all, many amps don't rely on "pure tube drive" either and those still doing that don't always sound good, like the Fender HRD).
    I prefer the Blackstar to my OCD, albeit the OCD is one of the least "pedal sounding" drive boxes that I've owned.
    But I agree: most drive pedals sound like pedals and many are more convincing when used to push an amp than if they feed a clean channel. :)
    zamdrang and northernguitarguy like this.
  20. Mockbel
    2,443
    2,292
    Nov 2, 2015
    I have Laney ironheart studio... it is a high gain amp.. 3 channels.. i rely on it for all clean and drive sounds.. i just noted that there are tons of drive pedals.. and sone of them really sound good so i thought of replacing my head and get a super clean single channel head and rely on pedals for drive.. but i think i am not going for that extreme after this thread.. i will keep the amp but i may try pedals as well
    mmd likes this.
